stuborn oil filter removal
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by lenjack, Mar 1, 2009.
  1. jreed
    jreed Member
    84
    71
    North Carolina
    I used a large pair of adjustable Channel Lock pliers to grab the oil filter and twist it off. This is really a plumbing tool, but it fit the oil filter well. If you have one, consider giving it a try. :)
  2. patsparks
    10,664
    567
    Adelaide South Australia
    Never use a tool to tighten the filter, just tighten by hand. It doesn't even need to be that tight.
    I take my filter off with my hands, and it never leaks.
    Always put oil on the seal and tighten firmly by hand.
    Yeah I know you get twice as much use from that expensive filter tool if you use it to tighten the filter. Use it to loosen the filter then put it back in the tool box.
    Okay?
  3. HTMLSpinnr
    HTMLSpinnr Super Moderator
    5,341
    920
    251
    Surprise, AZ (Phoenix)
    Been there, done that on a Nissan E16 engine. My brother did the oil change and only hand tightened the filter. By the time the oil light came on, it was already too late. This was in a colder climate where the heat of the engine and the cold ambient allowed things to contract/expand just enough to loosen up the filter. Machining the crank and some undersized bearings were all it needed to get back into service, but it started to suffer from premature cam lobe wear later in life as well.
    Consequently, I used to end up using a tool to go 1/2-1 turn past hand tight. I have had *some* difficulty removing a filter (see ancient posts) to the level where I had to completely cut the filter casing off w/ a dremel and then use a screw-driver/hammer combo to impact/rotate the base of the filter off of the block. Not a fun afternoon.
    I'm now comfortable with 1 turn past contact (hand or tool). I'd rather fight w/ a filter for a bit than drop in a new engine, and will generally error on the side of slightly tigher than "too loose".
    A quality cap wrench makes the job much easier, however if you don't go w/ an OEM filter, various filters will vary in size just enough where the cap filter is slightly too loose and a tight filter will end up with rounded end edges anyway. I've had to get creative w/ some wedging of old bicycle inner-tube between cheaper wrenches to get the job done for lack of being able to find good tools on a Sunday evening.
    On a similar note, some discussion regarding the new cartridge based filters on the 2010 has revealed that using the proper tools to remove the housing is critical to preventing damage and making removal near impossible. Hopefully replacement housings are cheap enough so that if Toyota oil change "techs" strip your housing, the replacement cost to them is "cheap enough" for a good learning experience.
  4. jayman
    jayman Senior Member
    13,439
    641
    Winnipeg Manitoba
    The only issue I ever had was changing the oil in an old Ford V8, late 70's vintage. The oil filters were kept in an unheated shed, and it was around -25 C, previously down to -40
    When I put the new filter on, the gasket actually cracked. So I refilled the oil, started it up, and wondered why the oil pressure gauge needle was bouncing up and down between 0 and 60 psi
    Happened to look through the space between the open hood and the cowl, and had a geyser of oil gushing up. Oh cah-rist what a mess, oil everywhere
    The old filter was still warm, sitting on the bench. I took the gasket off it, removed the new filter, transferred gaskets, and had to refill the oil, as most had been pumped out
    It was a good lesson to learn. Always keep your filters at room temp!
  5. dogfriend
    7,512
    1,190
    Carmichael, CA
    Or live somewhere warmer. :madgrin:
  6. blazer_5154
    blazer_5154 Heh, you said "member"
    106
    Maryland
    What I have done, rather than buy a specialty tool just for removing / installing oil filters, is to use a section of an old belt. If you cut it just long enough to encircle the filter plus about 2 inches, you can wrap it around the filter and use a pair of pliers to grab / twist the loose ends. It essentially works the same as a strap-wrench; it grabs as it turns.
  7. Mr Incredible
    Mr Incredible Chance favors the prepared mind.
    955
    506
    Neb
    +1 on jreed's idea about channel lock pliers. That's what I happen to be using currently. I haven't found a small enough cap or band wrench to work. The pliers have been working so far.
    On other, larger oil filters I have trouble with I might put some skateboard tape (aka step/stairs tape) around the filter or inside the band of the band wrench.
    K&N oil filters have a nut on the end of the filter. That can make things easier, but they're pretty expensive.
    I once was reduced to trying the screwdriver method. It didn't work and I wound up having to tear all the filter casing off with a pair of vise-grips. I then used the screwdriver to tap the filter base holes until it started moving in an off-ward fashion.
  8. jayman
    13,439
    641
    Winnipeg Manitoba
    Yeah, that would probably work too
    :rolleyes:
  9. jayman
    13,439
    641
    Winnipeg Manitoba
    I've used them on a 2000 GMC Sierra and they really are handy with that nut welded on the end. Not sure if they're worth the extra cost though
  10. Mr Incredible
    955
    506
    Neb
    Jayman, with all the hoopla about the nut on K&N filters, imagine my surprise when I found it to be simple formed steel that wasn't very dimensionally strict. I wound up with a big crescent wrench on it, and then went back to the standard strap wrench. It CAN work, but I didn't find it all that useful. With so many others from which to choose, I chose a different filter the next time.
    I, too, find a 1/2 to 3/4 turn past "touching" to be sufficient. Fine tuning the fit is simply a matter of experience.
  11. jayman
    13,439
    641
    Winnipeg Manitoba
    I do recall that a 6 point 1 inch socket was loose on that "nut." I can't recall what size socket I used, but I had to hunt around the toolbox for one that fit tighter.
  12. dorf
    dorf Member
    132
    Little Rock
    Use 65 mm filter wrench and a 2 in extension.
    KD3253 ---- No problems
    Cheers
  13. lenjack
    lenjack Active Member
    804
    114
    Pennsylvania USA
    OP here. Got one of those wrenches with fingers that tighten and dig in to the filter upon removal. Got it at Autozone, under $7. Worked perfectly. Only lost a negligible amount of oil and didn't need to add. I can't believe how much I had to turn it till it got loose. Someone very strong must have put in on...Hey, that's me! Thanks for the helpful responses.
  14. Patrick Wong
    18,210
    6,510
    That's great. I have one of those wrenches as well, it has a square hole for use with a 3/8" extension and ratchet. However I didn't mention it because I thought the band wrench would work better. In any event, now you have another tool to rattle around in your toolbox. :D
  15. Picasso Moon
    Picasso Moon Member
    117
    Phoenix, AZ
    After struggling with slippage on my first Prius oil change with the cheap stamped end cap wrench I had I decided there had to be something better. I ordered this http://www.amazon.com/Toyota-Oil-Filter-Wrench-Assenmacher/dp/B000W1R492
    It is cast Al with flutes at least twice as deep as the stamped models. Never had an issue again.
  16. jayman
    13,439
    641
    Winnipeg Manitoba
    Good to hear. Remember: hand tight is usually good enough for an oil filter. I've never used a tool to put on an oil filter
    Unless you count ME as the tool!
    :rolleyes:
  17. jayman
    13,439
    641
    Winnipeg Manitoba
    Patrick
    I thought you knew that manliness is judged by how many tools you have rattling around in your toolbox?
  18. Patrick Wong
    18,210
    6,510
    Hi Jay,
    So true, and this is why I am tempted to buy the oil filter wrench suggested by Picasso Moon next time I need to place an Amazon book order. That wrench sounds much better than the stamped steel cap wrench that I have which fits loose.
    I had previously tried a composite plastic cap wrench sold by Kragen. This fits very tightly on the filter, but it works about 5 times, then the 3/8" square hole loosens up so that the wrench has to be discarded. If they had a metal center section attached to the composite plastic cap, that would be a good solution.
  19. hyo silver
    hyo silver Awaaaaay
    15,272
    1,604
    off into the sunset
    2025 Prius Plug-in
    XSE Premium
    The first time I changed the oil and filter wasn't much fun. I thought it would be easier with my Dad's 'help' at his place, but of course he knows best, and it was pretty frustrating. The most recent time, I parked it on the slight slope outside my garage and crawled right under. No ramps, no jacks, and I was done in under ten minutes.
    Has anyone else thought of using rubber kitchen gloves for oil changes?
  20. Patrick Wong
    18,210
    6,510
    I use disposable latex gloves that Costco sells in boxes (similar to what you'll find at your doctor's office.) It's good to not allow used engine oil containing carcinogens to get on your bare skin, and of course this makes it very easy to clean up.
