Stuck in the middle of the road. Would not come out of park red triangle!
Discussion in 'Gen 2 Prius Technical Discussion' started by JIM777, May 20, 2017.
  1. JIM777
    JIM777 Member
    162
    24
    Ar
    20170520_182351.jpg Dish picture.
    Battery picture
  2. JIM777
    JIM777 Member
    162
    24
    Ar
    51,784
    did he read the voltages while putting a load on the battery?
  4. JIM777
    JIM777 Member
    162
    24
    Ar
  5. bisco
    51,784
    i'm wondering the same thing.
  6. JIM777
    JIM777 Member
    162
    24
    Ar
    Far as I know he did not put a load on the battery.
    Also is the Techstream
    code reader better than the snap on? And do I need the 21 pin or the 16 pin?
    Thanks
  7. andrewclaus
    andrewclaus Active Member
    993
    326
    Golden, CO
    Techstream is Toyota's proprietary software. Either buy it or take it to Toyota to get a proper diagnosis. There are hundreds of Prius-specific hybrid system codes, and many more INF codes, that most other scanners don't read. It's a 16 pin port.
  8. JIM777
    JIM777 Member
    162
    24
    Ar
    DOSE THIS LOOK GOOD? WILL IT WORK?
    GXG-1987
    GXG-1987 Mini VCI Car OBD Diagnostic Scanner OBD2 USB Interface Scan Tool for TOYOTA TIS Techstream Diagnostic Cable & Software
    314 customer reviews
    | 148 answered questions
    Price: $23.96 & FREE Shipping on orders over $25. Details
    | Details
    Sold by GXG-1987 and Fulfilled by Amazon. Gift-wrap available.
    • High reliability of products using SMD chip
    • Using online feedback function for technical support
    • Enable to read diagnostic trouble codes
    • Upgrade the firmware via the Internet to improve product
  9. ericbecky
    ericbecky Hybrid Battery Hero
    4,415
    3,286
    Madison, Wisconsin
    None of those links go to a product.
    Copy paste the address bar at the top of your screen.
  10. JIM777
    JIM777 Member
    162
    24
    Ar
  11. JIM777
    JIM777 Member
    162
    24
    Ar
  12. JIM777
    JIM777 Member
    162
    24
    Ar
    Is there one of these better than the other?
  13. ericbecky
    4,415
    3,286
    Madison, Wisconsin
    Not in that price range.
    Basically all are Chinese knockoffs with pirated software. Buyer beware.
  14. greasemonkey007
    greasemonkey007 Active Member
    287
    106
    South Central Arkansas
    Where are you located in AR? I'm just south of Little Rock.
  15. JIM777
    JIM777 Member
    162
    24
    Ar
    I'm just south of Branson Missouri.
    Still haven't healed this vehicle. Is it possible if a converter is clogged it would give me these readings? And Cause this problem. Here is a screenshot of the readings I got from it today.
    Still waiting on techstream.
    Got the cable but the disc was bad.
  16. ericbecky
    4,415
    3,286
    Madison, Wisconsin
    Call me this morning and we can talk through some ideas.
    What code(s) are you getting when scan the car with Torque app?
    Also, set up a custom screen in Torque app that displays all 14 of HV battery block voltages.
    If it is the battery it is under warranty.
    I would try to find out where it was purchased/installed.
  17. JIM777
    JIM777 Member
    162
    24
    Ar
    I don't have your phone number.
    If I click on your name it says on expected error occurred.
  18. Prodigyplace
    12,516
    11,739
    Central Virginia
  19. FL05Prius
    FL05Prius New Member
    I won't start a new thread for this because same thing happened to me as OP. First, AC goes warm air, then same warning lights come on, car starts to slow and drag, no acceleration, finally died in middle of road. Shut it down, waited 2 minutes, powered up with AC off, and it drove, slowly, enuf to get it home, 4 miles away.
    My regular mechanic put in new 12 volt battery, new inverter pump, rescanned it and got no codes. He says hybrid battery is @40%.
    He reset the warning lights, I picked up car, drove 30 minutes, AC went hot again, all warning lights came back on.
    Freon is full, compressor was already replaced previously.
    Any suggestions as to what else it could be since there's no codes to guide us, and we know it's not 12volt, inverter, hybrid battery, or AC.
    Thanks, Laura in Florida
  20. bisco
    51,784
    welcome!
    probably the hybrid battery, you need a toyota scanner. how many miles on her?
