Stuck My Foot In It - REALLY Hard
Discussion in 'Prius c Care, Maintenance and Troubleshooting' started by Mr Incredible, Sep 27, 2012.
  1. RocMills
    RocMills Active Member
    789
    277
    Las Vegas, Nevada
    Sadly, you won't get the MPG on the Jetta you were getting on the C, and the dealership will not reimburse you for gas. I think that's the very worst part about damaging a C at this point, they won't give you another fuel-efficient car as a loaner.
  2. Zythryn
    Zythryn Senior Member
    6,411
    4,412
    Glad ÿou are ok, and a Big 'way to go' on avoiding the driver that pulled out in front of you!
    RocMills likes this.
  3. Revan86
    Revan86 Animal nerd and alt car guy
    286
    84
    All over northern IL
    Tip: If you happen to find any particular user's posts just aren't adding anything to your PriusChat experience, you have the choice to click their name, then click "Ignore" on the info sheet that comes up. Problem solved. Apart from occasionally wondering who people are arguing with. :rolleyes:[/quote]
    You don't really need to unblock anyone. If some one is arguing in the C forum you only need one guess to know who it is.
  4. Revan86
    286
    84
  5. Mr Incredible
    Mr Incredible Chance favors the prepared mind.
    955
    506
    Neb
    The pivot pin support wasn't as strong as it needs to be. They are likely all that way.
    It could just be my innate ability to break things, but this piece should be stronger. NOBODY should be able to mess up a brake support or any other part of the braking system. I'm big, but I'm not The Hulk.
    New2Here likes this.
  6. ageless
    ageless New Member
    38
    What is it with toyota and brake components? Didn't they learn their lesson with the last globally televised brake fiasco?
  7. Mr Incredible
    955
    506
    Neb
    The dealers say they should have my car back to me Thursday or Friday. They will put in the new assembly, make measurements to ensure it was the only thing modified, and give me back my vehicle.
    Or not...
  8. Tracy
    Tracy Member
    171
    101
    Uh....are you SURE? Mr. Incredible :giggle:
    ztanos and Mr Incredible like this.
  9. Mr Incredible
    955
    506
    Neb
    Ha! I adopted that moniker mostly because of poor Mr I's inability be all things to all people, regardless of his awesomeness. I can commiserate, as can any Dad/Husband.
    Tracy likes this.
  10. Mr Incredible
    955
    506
    Neb
    So I thought I'd get the Camaro out and drive it for the next few days. Man-O-Man! I'd forgotten what a real gas pedal feels like!
    Yay horsepower!
  11. Mr Incredible
    955
    506
    Neb
    After two weeks, I got my car back today. Went to pick it up and drop off the loaner at lunch.
    Performance Toyota of LaVista. They did ok as far as I can tell. The loaner was quickly provided, and had only 85 miles on it. One of the nicest loaners I've had. I suppose as the C gets older, so will the loaners. They kept me up to date and were pleasant.
    I paid nothing out of pocket.
    The remarks on the invoice: "Confirmed customer concern. Brake pedal was not coming back far enough to touch brake light switch. ... compared brake pedal height-customer car was lower than new car. ... removed brake pedal bracket assembly from customer car and removed a new pedal assembly from new car inventory. Compared the two and found where bracket bolts to body was bent. Ordered new parts. New bracked assembly from KC. Put it on and measured. Made sure all adjustments were set. Performed health check. Cleared all codes and test drove. All systems working properly."
    No issues driving it back from work. Have been driving the loaner, the truck, and the Camaro and now have to get used to it all over again.
    Back to the Great (Habanero) Pumpkin just in time for Halloween...
    minkus and cwerdna like this.
  12. Tracy
    Tracy Member
    171
    101
    Thanks for the update! You'll have to moderate those super-hero powers ;-) Funny you mention the "great pumpkin" aspect of the habanero color....I've been considering parking mine in the driveway on Halloween and making a big stem to set on the roof and some black triangle features (eyes, mouth) for the front ;)
    ChinchillaGirl likes this.
  13. jsfabb
    jsfabb Active Member
    617
    156
    Medford, NY
    Sounds like a great idea. Please post pictures!!!
  14. cwerdna
    cwerdna Senior Member
    12,545
    2,125
    SF Bay Area, CA
  15. Revan86
    286
    84
    Glad to see you got your car back. Try not to break it Again
  16. Mr Incredible
    955
    506
    Neb
    A couple of photo's of the brake support assembly. They aren't as clear as I would like since it's all so close and hard to discern one part from the next.
    Photo #1 is of the brake light switch and tab. The switch is brown and it's arrows are yellow. Also on that photo is the brake assembly supprt structure. There is a cut-out that I think is what bent. It looks to be the weakest area. It is highlighted in light blue. Those that wish to stick their head in that area with a flashlight can easily make it all out.
    Photo #2 is also of that cut-out from a slightly different angle. It is also highlighted in blue.
    The part was taken back to the Toyota mothership and I was unable to inspect it. Everything is supported by a stamping and I can see that it could be tweaked if human-able force is applied. Maybe the next version will not have that cut-out for "lightening."
  17. bisco
    52,848
    glad all is well. wonder if the suspect was made in usa? 'try not to brake it again.':D
  18. AutoMo
    AutoMo Junior Member
    61
    33
    Eastern WA
    Holy Toledo! You bent your C - from the inside out!.... You da man. I'm glad you saved the exterior, (MAYBE) the idiot who caused the mishap, and yourself. Good Job! Mostly 'because you got Mother Toyota/Stealership to fess up. If it matters, I'm proud of you.
  19. mahout
    mahout Active Member
    655
    116
    NC
    I have a problem with your disconnecting the battery; did you disconnect the ground side or just part of the positive side? without that 12vdc poewer the brake lights must be off.
    Brake pedal went into the battery ?
    The tab is only the connection sensor that tells the ECU and connects 12v to the tailights so the tail lights are on' because the relay is now fixed in closed position. If the tab is bent or misaligned so the relay is now closed the brakes are 'on' unless you truly disconnected the battery.' I cannot imagine you bent the tab so much it cannot be reset. Or perhaps you broke the relay itself. Could be done.
    I suggest you check that relay for proper alignment or broken first.
  20. Mr Incredible
    955
    506
    Neb
    Mahout, I bent the brake pedal support. It was then not aligned with the the brake switch shutoff tab. The tab was on a separate structure and was not affected. Toyota replaced the brake pedal support.
    The battery was unhooked for trouble shooting while I was trying to figure out why the brake lights wouldn't go off.
    It was quite a surprise to see the switch and the tab misaligned. It was like, "That ain't right."
