Studdering misfire on startup after cleaning Battery cooling fan air filter
Discussion in 'Prius v Care, Maintenance and Troubleshooting' started by PriusGoonie, Oct 2, 2022.
  1. PriusGoonie
    PriusGoonie Junior Member
    60
    Nowhere, CA
    2015 Prius v wagon
    Any idea where to find that? I guess I'll just look up "toyota warranty book price hourly labor"
  2. ChapmanF
    18,213
    @Elektroingenieur often refers to the Flat Rate Manual, which I suppose is a book version of the info.
    The expected labor times can be looked up on TIS, same place you find the repair manuals and wiring diagrams:
    Toyota Service Information and Where To Find It | PriusChat
    I remember noticing that feature one of the recent times I was signed in to TIS. I posted here about it, but I haven't managed to find that post again. The wiki page above should probably be updated to mention how to do that.
  3. rjparker
    rjparker Tu Humilde Sirviente
    10,156
    6,313
    Texas Hill Country
    #43 rjparker, Oct 7, 2022
    Air_Boss likes this.
  4. PriusGoonie
    60
    Nowhere, CA
    2015 Prius v wagon
    Got head gasket replaced, quick guys.
    Answer about the EGR cleaning:
    The Manteca Gasket Masters does the EGR cleaning as a package deal with removing the existing EGR Cooler and replacing it with anther one they have from other cars, and cleaning the EGR. They let the EGR cooler sit for a while in a bucket of who knows liquid.
    Cost for their EGR Cooler service/EGR cleaning: $385 - $425 depending.
    Mine looks basically brand new now, EGR is cleaned. Gasket replaced.
    Again they said EGR cleaning they don't do by its self as a service, you'd need to do the EGR cooler service that includes cleaning out the EGR.
    They include a list of stuff they've done as part of the head gasket replacement:
    Head gasket
    Head bolts
    Oil
    Coolant
    Spark plugs
    EGR cooler/Clean EGR (not shown on paperwork)
    Runs great I'm happy, unsure who gave me the name of that shop I'm driving but I truly very much thank them for steering me to them. Saved me some $3,000. Toyota service center quoted me $5,100 for that head gasket job.
    Gasket masters also said there was fouling in all 4 cylinders, they replaced with iridium tipped, $9 a piece from Auto Zone....
    Should I be swapping those out
    #44 PriusGoonie, Oct 8, 2022
  5. Tim Jones
    Tim Jones Senior Member
    1,758
    565
    SE Texas
    2011 Nissan LEAF
    Another JUNK toy Head Gasket........the cars are JUNK!
  6. PriusGoonie
    60
    Nowhere, CA
    2015 Prius v wagon
    Getting about 40 mpg at 74 now in the mountains that's pretty good
  7. PriusGoonie
    60
    Nowhere, CA
    2015 Prius v wagon
    HS26515-PT is the gasket kit
  8. rjparker
    10,156
    6,313
    Texas Hill Country
    . Gasketmasters is your friend.
    PriusGoonie likes this.
  9. Tideland Prius
    16,559
    *Moved posts to this thread*
  10. PriusGoonie
    60
    Nowhere, CA
    2015 Prius v wagon
    Going to add one more thing, Gasket Masters, I was pretty clear that they were going to diagnose what was going on and tell me what was going on before doing the head gasket, they called me up on Saturday and said they did the head gasket.
  11. PriusGoonie
    60
    Nowhere, CA
    2015 Prius v wagon
    Going to add one more thing, Gasket Masters, I was pretty clear that they were going to diagnose what was going on and call me to tell me what was going on before doing the head gasket to tell me if it was in fact the head gasket, they called me up on Saturday and said they did the head gasket.
    They didn't inform me of what they found or get my permission. They just did it.
    They said the spark plugs were fouled.
    I always had lots of carbon covering the back from the exhaust, I'm going to wash the entire car and see if it still comes back, after they cleaned the EGR and egr cooler and put in a new head gasket.
    What would cause so much soot coming out of the engine?
  12. PriusGoonie
    60
    Nowhere, CA
    2015 Prius v wagon
    Called them up today, the spark plugs they use are Iridium Autolite plugs because they last a lot longer than the Denso and NGK's, which cools my jets a bit. They're only $9 per plug.
    They also said the soot is from burning oil common in these cars. Said to place only 1/3 bottle of Seafoam in the oil once every oil change to get the deposits off the rings and such, that after about 3 oil changes you'll see a difference, maybe even doing another 1/3 into the vaccume line / heat soak treatment.
    Here I go
    #52 PriusGoonie, Oct 11, 2022
  13. rjparker
    10,156
    6,313
    Texas Hill Country
    You are not going to fix a ring problem with seafoam.
    Tim Jones and PriusGoonie like this.
  14. PriusGoonie
    60
    Nowhere, CA
    2015 Prius v wagon
    B12? Never used it, says to pop it in for just 15 minutes before oil change
  15. PriusGoonie
    60
    Nowhere, CA
    2015 Prius v wagon
    And possible soaking, turning the engine manually....
  16. Air_Boss
    Air_Boss Senior Member
    4,199
    1,184
    New Yawk
    What is anyone going to fix with SeaFoam? Serious question.
  17. rjparker
    10,156
    6,313
    Texas Hill Country
    There have been some videos of a b12 soak working to free the oil rings. There is a real danger of hydrolock when doing a soak which has to be well understood and managed.
    While not discussed here much, thermal cycling is a significant built in design flaw with gen3 engines. I record 20-30f swings in normal city driving and up to 50f swings if idling with ac for longer periods. The problem was a major focus of Toyota in their gen4 engines and combined with other things like egrs taken downstream of a cat seem to have resolved the engine reliability issues.
    Gen4 Cylinder Wall Insulator
  18. PriusGoonie
    60
    Nowhere, CA
    2015 Prius v wagon
    What do you think about placing maybe 3/4 cup of Seafoam in the oil after every oil change, that's what the guy at gasket masters told me. 3/4 cup is just about 1/3 of the can. The regular posts and instructions say to place oz per quart measurement and run it for 100-300 miles, but what about placing a small amount for the full duration
  19. rjparker
    10,156
    6,313
    Texas Hill Country
    Personally I would change my oil every three to four thousand miles for the next fifteen thousand. I would never add and run a solvent like these products to a close tolerance engine. However it is your engine and your choice.
    If I were going to try a solvent, it would be a soak procedure executed by a company with the experience and resources to back up any negative result. They would take the time to rotate the engine, suck it out of the pistons, repeat and finally change the oil, all without driving it.
    Any engine with low tension rings (initially used to improve mpg, not to make the engine more reliable), will suffer from increased blowby into the crankcase and increased oil consumption into the cylinders. The blowby results in fuel and condensates in the oil, already compromising the oil. Without frequent high rpm use, the blowby liquids in the oil masks most oil consumption. A serious freeway excursion then boils off these undesired extras and sends them through the pcv for intake manifold pooling and reintroduction into the combustion chamber. Consumed oil and normal cumbustion products head out the exhaust but some make a right turn before the cat and enter the egr. We all know about the egr. My engine does use oil but I chose to carefully monitor it, top it off and perform frequent changes.
    #59 rjparker, Oct 13, 2022
  20. PriusGoonie
    60
    Nowhere, CA
    2015 Prius v wagon
    1/3 of the 16 oz Seafoam can is 5.33 oz, or 2/3 cup
    Seafoam instructions online recommend 1 oz per quart, or maximum 1.5 oz per quart. This Prius V has 4.4 quarts, so that'd be between 4.4 oz and 6.6 oz, but I have 5.33 oz in there now (2/3 cup), 1/3 of the 16 oz bottle like Gasket Masters suggested, going to see how it goes, already seeing improvement the first 50 miles. Isn't as harsh starting or loud/rough idling so.
    Next will be B12 Chemtool in gas tank at almost empty then fillup, 1 oz per gallon per instructions, 11.9 gallons, 11.9 oz, which is 1.488 cups, 1.5 cups for kicks.
    You know on my Subaru H6 3.0 I use Justice Brothers oil with Metal Conditioner, and AT-205. The Subaru was leaking pretty bad before hand, had less than half a stick oil remaining just at the half way mark. After AT-205 in the oil and JB, zero oil loss. It's a rubber conditioner that AT-205. I actually also spray it on all rubber stuff under the Prius, everything's basically brand new looking. Just a couple squirts. Tried it on my tires one time, they looked brand new. Insane.
    Justice Brothers with metal conditioner, put that in starting I think around 250k, it's at 311k now. Also put in some Lucas Oil transmission stuff in my transmission, still works. Before all of this I was putting in Marvel Mystery Oil.. did something.
    Only problem with the JB stuff is that I have 0W-20 oil, won't be able to put it in my prius, but, JB told me use E0S-66P Justice Brothers Oil Suppliment for the Prius. Maybe in the future if I can find it on eBay.
    Sea Foam... do you want the truth? - YotaTech Forums
    #60 PriusGoonie, Oct 13, 2022
