Study Ideas - Battery Degradation
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by markabele, Jun 20, 2017.
  1. jerrymildred
    jerrymildred Senior Member
    11,517
    14,164
    Tampa, FL
    Similar here, which makes sense. Same model year and same neighborhood. But my typical range in the late afternoon commute is about 9.5-10 miles. It's 9.7 miles home from work and most days I make it. But the hotter it is, the harder it is to not run out of juice because the A/C is practically roaring. Mornings going to work, I usually have 1.2-2.4 miles left this time of year.
    BTW, I just did another test run.
    Same temperatures.
    Not wet, so windows open, fan off.
    Slightly less traffic.
    Similar route and speeds.
    14.2 miles.
    Conclusion: At a #2 setting, the fan doesn't seem to make a lot of difference, but there were other factors, so that's not a conclusive conclusion. If you get my drift. ;)
    52,694
    how much difference between l1 and l2, and why?
  3. giora
    giora Senior Member
    1,966
    730
    Herzliya, Israel. Car: Euro version GLI
    2013 Prius Plug-in
    With the PiP I would say L2 (or 230 V here) is about 89-91% efficient (9-11% losses) while L1 is about 82-84% efficient (16-18% losses).
    With the PiP, L1 max. current is ~13 A (and longer charging time due to the low voltage) while L2 max. current is ~10 A (and shorter time due to the high voltage). Losses go with the current squared so this is IMO the main reason for the difference.
    jerrymildred and bisco like this.
    52,694
    thanks, but i'm still not clear. are we measuring the amount of electricity to fill the battery, or the total amount needed to accomplish it?
  5. giora
    giora Senior Member
    1,966
    730
    2013 Prius Plug-in
    The 'payable charge' i.e. from wall.
    The charge the battery can accept was 62% of 4.4 kWh or 2.7-2.75 kWh when new, however, less in time and use.
    I recall members here reporting ~3.3 kWh charge from wall with L1 when new, 2.73/3.3 is 83% or 17% losses.
    I had 3.0 kWh from wall @ 230 V when new, 2.73/3 is 91% or 9% losses.
    The charge the battery can accept is reduced in time and use, so is the amount of charge from wall to charge from 'empty' to 'full'. I am pumping today about 2.55-2.6 kWh from wall - 87% of 3.0 kWh or about 13% reduction.
    P.S. The 62% mentioned is IMO true today as well but the battery is not a 4.4 kWh battery anymore:sick:
  6. bisco
    52,694
    will you please rest this in marks other thread, 'study ideas'?
    Data Daedalus likes this.
  7. markabele
    5,084
    1,782
    Nebraska
    That makes my annual percentage degradation rate not nearly as bad.
    giora and jerrymildred like this.
  8. Yea Right
    Yea Right Active Member
    232
    115
    Seattle
    2014 Prius Plug-in
    Wouldn't a full charge be a full charge regardless, other than the extra time it takes because of efficiency losses of 110 vs 220
  9. bisco
    52,694
    as mentioned earlier, you can start from different points in the hv portion.
  10. Yea Right
    232
    115
    Seattle
    2014 Prius Plug-in
    Guess I'm not a battery technician :cool:
  11. bisco
    52,694
  12. jerrymildred
    11,517
    14,164
    Tampa, FL
    Double ditto. That said, I think the best bet would be to use a scan gauge or something like it to check SOC before and after charging and do it lots and lots of times while recording the power consumed from the outlet at each charge. That should give you a trend, but it's a lot of work.
  13. bisco
    52,694
    my ev estimate hit 15 today, haven't seen that in a long time. the weather has been spectacular.
    jerrymildred and markabele like this.
  14. iluvmacs
    iluvmacs Member
    280
    104
    Madison, WI, USA
    This is totally in line with what my PiP charges every day (my OpenEVSE reports kWh every charge).
    Lithium MPG likes this.
  15. bisco
    52,694
    can you post some numbers in marks other ongoing thread? it would be helpful to other owners.
  16. Tracksyde
    Tracksyde Member
    1,429
    762
    So Cal
    Well, I drive to work every day.. 600ft elevation drop over 12.8 miles (which helps a lot).. I'd say I make it to work on all electric about 98% of the time (so only 2-3 times a year - provided I'm not carpooling or deviating from my 12.8mi daily route). I used to have days where I made it with 2-3mi left.. but my range estimate has kind of settled to around 11.2-11.5 miles year round. Nowadays, if I can make it with 1.2-1.5 miles left, thats pretty good. Some days I'll make it with 0.1mi creeping into the parking lot at work.
    I have a few factors that make it difficult to compare. First, I'm on some lightweight 17" wheels using Bridgestone Ecopia EP422 205/50/17 tires. I definitely dont think these are as efficient as my stock setup. However, I also know my driving has gotten "better" over the past 5+ years and I'm much better equipped mentally to shrug off the one-finger salute now (I guess it comes with age). Although I do drive the speed limit, thats not good enough in my 'hood. And lastly, I hit like 15+ traffic lights. I usually get stuck at the same ones.. but on days where I hit a lot of green lights, I definitely make it farther/end up at work with more juice.
    But having said all that, I dont FEEL like I've lost too much capacity. Subconsciously I'm sure I'm making adjustments since I'm constantly calculating my range/distance/remaining capacity (for example, I know if I make it to Gas Station X with 7miles on the trip odo and have 6mi EV remaining, I'm in good shape). On the way home, I can never make it all the way, but I usually run out around the same spot, give or take 0.25 miles or so.
    So yeah, if we were just going by distance, I'd probably be telling you I dont THINK I lost much range.
  17. Lithium MPG
    Lithium MPG Junior Member
    27
    27
    Inland Empire
    2013 Prius Plug-in
    thats what the PiP is supposed to charge.. they leave headroom on the 4.4 pack as to increase the lifetime of lithium cells.. my Thinkpad laptop does the same thing. This is why the first gen Leaf's have problems with battery longevity as Nissan did not do this.
  18. Tideland Prius
    16,658
    @bisco, it'll be helpful if you paste the directly here lol. Otherwise, people will have to guess which thread you're talking about (y)
  19. bisco
    52,694
    if you teach me how to paste, i will do it. i'm still doing addition on my fingers. does danny know how how to paste?:cool:
    besides, if mark hadn't started 2 threads on the same thing, i wouldn't have to paste in the first place.:p
    markabele likes this.
  20. Tideland Prius
    16,658
    PC or mobile?
