Stump the Chump!
Discussion in 'Gen 2 Prius Main Forum' started by ZC1, Jun 6, 2008.
  1. ZC1
    ZC1 Junior Prius Owner
    711
    Metro Detroit
    Pat, you did.
    V8CobraKid was kind enough to elaborate on his response which in fact he did get correct. There is no remaining reason why he should not be awarded the victory.
    So the crown is passed to V8CobraKid (again!).
    You've chumped us again, V8.
    ZC1
  2. V8Cobrakid
    V8Cobrakid Green Handyman
    3,790
    152
    woohoo? haha.. j/k.. i'm happy.
    thanks for the PM.. or else i wouldn't have looked at this till.. oh... now ;)
    So i'm victorious again... can i get my name engraved on this crown? :)
    K... running out to my car to pick out a part...
  3. V8Cobrakid
    3,790
    152
    alright... it's a little hard to find a pic i wanted to post.. so here it goes
  4. patsparks
    10,664
    569
    Adelaide South Australia
    That is tough.
  5. Bill Merchant
    Bill Merchant absit invidia
    4,096
    87
    I think I know, but I may not have the accurate terms to describe it.
    That is the screw that holds the throttle flap. If you open up the air cleaner and look down into the throat of the throttle, that's what you see.
    The screw goes through a rod and attaches to a circular metal disk. The rod rotates to open and close the throttle, allowing more or less air to enter the intake manifold by changing how much the disk blocks the throttle passage.
  6. V8Cobrakid
    3,790
    152
    Bill, I accept your answer. I have a zoomed out pic at home.
    Looking forward to see the next picture :)
  7. Bill Merchant
    4,096
    87
    Thanks! I'll post a pic tomorrow since it's dark here now for picture taking.
    I'm surprised Patrick Wong didn't get this. [​IMG]
  8. Patrick Wong
    18,210
    6,517
    Hi Bill,
    I'm not good with fuzzy photos that are zoomed in so tight that you can see the pores! :D
  9. V8Cobrakid
    3,790
    152
    i agree with Bill.. it really is a one of a kind piece.. zoomed or not ;)
    I guess i should have looked online for a better pic. that one was taken earlier by me with everything still on top of it.( which explains why i only show 1 screw)
  10. Bill Merchant
    4,096
    87
    OK, I know I took a long time. But I got a round tuit.
      File size:
      67.3 KB
      621
  11. V8Cobrakid
    3,790
    152
    that almost looks like the bushing for the arm that's located on the bottom of the engine.. motor mount/dampener...
  12. V8Cobrakid
    3,790
    152
    or the hand tightened bolt that holds down the spare tire and accessories....
    hehehe
  13. Bill Merchant
    4,096
    87
  14. galaxee
    galaxee mostly benevolent
    9,810
    471
    MD
    shooting from the hip without going out to look- cap for the brake fluid reservoir?
  15. Bill Merchant
    4,096
    87
    Sorry, not even close.
  16. patsparks
    10,664
    569
    I have seen this somewhere,
    I believe it is a nut which secures a wiring loom and I'll guess it is in the drivers side of the dash.
  17. Bill Merchant
    4,096
    87
    Sorry Pat, the only nut on the driver's side is you... :D
    I'm sure you've seen it before. Somewhere.
  18. patsparks
    10,664
    569
    I know I have Bill, I'll have another stab.
    It is a gromet which fills a hole in the bottom of the spare wheel well.
    Enough already with the nut comments, truth hurts you know.
  19. Bill Merchant
    4,096
    87
    Nope. And it's not "Cheese, Gromit!" :pizza:
  20. ZC1
    711
    Metro Detroit
    What it is: Plastic Grommet
    Where it's at: In the forward lower right hand portion of the rear wheel wells (if you are facing the front of the car). You can see it if you look between the front of either rear tire and the body line.
    I believe if removed it will allow access to a bolt.
    Furthermore, I think there is one on each side of the front wheel wells, harder to see.
    ZC1
