Stump the Chump!
Discussion in 'Gen 2 Prius Main Forum' started by ZC1, Jun 6, 2008.
  1. Patrick Wong
    18,210
    6,513
    Location: both front doors, at trailing edge of door (visible when you open the door and look at the edge of the door that faces the B pillar)
    Purpose: The grommet covers the access hole for a bolt that secures the door handle to the front door
  2. ZC1
    ZC1 Junior Prius Owner
    711
    Metro Detroit
    Obviously, unknown to the OP, there are multiples of the same plastic grommet on this car. The OP didn't give any location hints, therefore it could be any of the above.
    ZC1
  3. Bill Merchant
    Bill Merchant absit invidia
    4,096
    87
    That's not what I pictured, though there is one on the other side. And it's not hard to see.
    Patrick Wong, you are correct. It is indeed the access cover (I'd hardly call it a grommet) for the door handle lock assembly. No need to look in wheel wells to see it. I think this particular configuration is unique to the front doors, though there are similar covers on the rear doors and maybe in other locations.
    ZC1, you are the Original Poster.
    Both of my puzzles have been in plain sight.
    Over to you, Patrick...
  4. galaxee
    galaxee mostly benevolent
    9,810
    471
    MD
    dang it Bill... it's the lack of size reference that kills me. :p
  5. Bill Merchant
    4,096
    87
    It's still in the rules as laid down by the OP...
    I'm just a chump. I post pictures of Prius parts we've all seen, nothing weird, nothing that has to be disassembled. I just remove the context.
    If you noticed, I masked out all the background around the cover. It looks like a white background in the first post, if you click it the background goes to black, if you click it again you see it in a new window with a white background. It's a circular image with a clear background.
    Yes, I do have an interest in steganography.
  6. Patrick Wong
    18,210
    6,513
    Thanks, Bill!
    What is the location and purpose of the black ridged part?
  7. patsparks
    10,664
    567
    Adelaide South Australia
    Too easy
    Windscreen wiper motor cover.
    Right side (in US models) of fire wall under the black cover across the back of the engine bay.
    I can see the VIN number in the background.
  8. Patrick Wong
    18,210
    6,513
    Hi Pat,
    You are correct! I wanted to quickly forward the ball to another group member, you are "it"!
  9. patsparks
    10,664
    567
    Big mistake, it's 1.15AM and I'm about to go to bed.
  10. patsparks
    10,664
    567
    I have a feeling this will go quick.
    I need the exact location for this round otherwise it is just too easy.
    By patsparks at 2008-07-05
  11. Bill Merchant
    4,096
    87
    WHAT: The Electric Vehicle mode switch.
    WHERE: Not installed in North American Prius.
    ALT WHERE: Installed in the three-switch location cluster next to the steering wheel.
  12. patsparks
    10,664
    567
    Wrong.
    Sorry it's too easy if I give a clue.
    edit; - May as well give you, the "What" is correct.
  13. Bill Merchant
    4,096
    87
    I think the first Where is correct too. But I concede. I await the correct answer.
  14. patsparks
    10,664
    567
    Well yes, the first "where" is correct but this is a global forum.
    In Australia there are no HID headlights so I was out in the cold there too.
    You have the "what" so the "where" might be a search on line away.
    Am I giving too much away?
  15. Bill Merchant
    4,096
    87
    OK, I know I'm right this time!
    WHERE: Installed in PatSparks Prius.
    I can tell you where you got your socks, too! On your feet!
  16. patsparks
    10,664
    567
    Just a little more specific, you are on the right track.
    I only posted this as an opportunity to tease the septic tanks because you don't have the EV switch there as a standard fitment.
    Hahaha I missed that last line hahaha.
  17. Bill Merchant
    4,096
    87
    Well, on your Prius it is to the right of the steering wheel between the column and the Start button.
  18. patsparks
    10,664
    567
    Yes, but....
    Your going to hate me Bill, all in one post.
    I'm a hard bastard, how would you like to come across me on the road when I'm working?
    I can't do it to you Bill, you worked hard for it.
    You're up Bill.
  19. priusuk2008
    priusuk2008 New Member
    289
    CAMBRIDGESHIRE
    Hey Pat you're too too easy on old Bill. It isn't on the right of the steering wheel, its on the LEFT and its the nearest switch to the steering column in the bank that Bill mentioned.... you going all soft on these fellas now ?
  20. patsparks
    10,664
    567
    Not in my Prius. Like all Australian Prius from 2004 on, the EV button is between the key fob port in the dash and the power button on the right side of the steering column. This is very convenient as it allows me to insert the fob, hit the power button then push the EV button before I back out of my driveway all with the right hand.
    The only way I was being soft was allowing Bill to take the win even though he didn't have the correct location and purpose in the one post however it was clear to me he knew the right answer.
