Stump the Chump!
Discussion in 'Gen 2 Prius Main Forum' started by ZC1, Jun 6, 2008.
  1. Qlara
    Qlara New Member
    488
    I thought the Right-Hand Drive (RHD) Prius will equip with a mirrored dash too (Power button will be on the left upper dash), but obviously the Prius Design team treats the Power button like a normal ignition key hole, which is always on the right.....thus Power button is also on the right side still.
    Though the Shift Stick is on the Left in the RHD Prius....but so are other regular RHD vehicles too.
  2. Bill Merchant
    Bill Merchant absit invidia
    4,096
    87
    OK, chumps, enough jibber-jabber about LHD and RHD. Interesting, but this is the Stump the Chump! thread.
    What and Where? (I'll be lenient.)
  3. patsparks
    10,664
    569
    Adelaide South Australia
    I prefer the button under the vent, I'm not keen on trying to showcase it in the middle of an expanse of smooth plastic up in the sun like it is in LHD markets.
    The ignition key isn't always on the right, and the indicator stalk isn't always on the right.
  4. Bill Merchant
    4,096
    87
    That's not a good guess, Pat.
  5. galaxee
    galaxee mostly benevolent
    9,810
    471
    MD
    that's the brake light assembly cover on the inside of the hatch. pretty sure it's RH.
  6. Bill Merchant
    4,096
    87
    Yup.
    GO!
  7. patsparks
    10,664
    569
    Really Bill?
    (I knew the answer. I didn't have time to check which side.)
  8. galaxee
    9,810
    471
    MD
    ok, check back this evening for a new picture.
  9. galaxee
    9,810
    471
    MD
    ok, where is it and what does it do?
  10. Bill Merchant
    4,096
    87
    AC high- and low-pressure lines going through the fire wall from the engine compartment into the cabin.
  11. galaxee
    9,810
    471
    MD
    correct so far.
    purpose? i'm gonna be picky. ;)
  12. Bill Merchant
    4,096
    87
    Provides cooled compressed refrigerant on the high-pressure side which expands inside the cabin box, absorbing heat from the air. The low-pressure side returns the refrigerant to the compressor for the cycle to be repeated.
    I get confused about which is the evaporator coil and which is the condenser coil. The refrigerant absorbs heat when it expands.
  13. galaxee
    9,810
    471
    MD
    i am officially chumped. good answer!
    the condenser is up front, the evaporator is behind the firewall.
  14. Bill Merchant
    4,096
    87
    When the compressed refrigerant expands, I suppose that is evaporation, though since it's in a closed system it's not like water evaporating from a wet car and disappearing. Likewise, when the compressor takes the low-pressure gas/vapor and squeezes the refrigerant into a liquid to circulate through the front radiator, I guess that's a form of condensation, though not like water condensing on the side of a glass of ice tea.
    I've been thinking my pictures have been too easy, so this one isn't (I hope.)
    What and Where? Specifically, the object in the center of the picture.
  15. patsparks
    10,664
    569
    The refrigerant doesn't just expand, it changes state from a liquid to a gas in the evaporator, then after being compressed to high pressure very hot gas the refrigerant again changes state in the condenser where it gives off the heat it absorbed in the evaporator and again becomes a liquid. It is all about the changing state from liquid to gas and back to liquid.
    Good answer though Bill.
    PS, oops wrote this before I had read Bill's last post.
    The refrigerant does condense just like water vapour condenses on a cold glass. It is pressurised and cooled against the tubes of the condenser where, as a liquid it runs down allowing more hot gas to touch the cooler tubes and condense.
    After the liquid is released into the evaporator it boils and as it boils travels through the evaporator tubes taking the heat from the aluminium tubes which in turn draw heat from the fins which draw heat from the air.
    The filter dryer receiver is a reservoir of liquid and gas, it is here any gas is kept from going through the expansion valve. This is why there are bubbles in the sight glass only when there isn't enough gas in the system or on system start-up.
    The high pressure liquid going in through the fire wall is hot and the low pressure gas coming out in the bigger tube is cold.
    I hope this makes a little bit of sense.
  16. Bill Merchant
    4,096
    87
    I posed a question on 07-12-2008 at 02:46 PM.
    I tried to make it hard, maybe too successfully. The OP's puzzle duration time of 72 hours has elapsed without an answer. ZC1 said:
    Since there weren't any real guesses, I don't know if I'm a CHAMP or a CHUMP. In any event, the thread has gone nowhere for the past three days.
    What happens next, ZC1?
  17. patsparks
    10,664
    569
    You killed it Bill :D
    What was the answer?
  18. V8Cobrakid
    V8Cobrakid Green Handyman
    3,790
    152
  19. Bill Merchant
    4,096
    87
    That's what I was afraid of.
    Pictured is the underside of the floor panel that goes over the battery in the right rear corner of the Gen II Prius. The object in the center back is the post that goes down and sits on the HV battery air vent, furthest forward in correct orientation. Notice that the end is sloped to match the curve of the vent. The post on the left, at the front of the picture, has a kind of black velvet tape over the top; this post sits on the 12V battery.
    I didn't mean to kill the thread. I rather like guessing. :Cry:
  20. ZC1
    ZC1 Junior Prius Owner
    711
    Metro Detroit
    I know you guys won't believe me, but....
    I should of posted that answer hours ago, but second guessed myself thinking "Nah, he'll prove me wrong".
    Duh...I was right but I was wrong for not posting the answer of what it was.
    Sorry I didn't post earlier, but was quite busy with outside work.
    Anyways, Bill Merchant is a CHAMP and may be the first person whose object endured the entire 72 hours, but secretly we all know and love him as a Chump so there...!
    Bill, it's your perogative to either 1. Post another object, or 2. Hand it over to another well prepared cronie.
    As the Stump the Chump carnival barker I once was, "Step right up and test your luck sonny...."
    ZC1
