Stump the Chump!
Discussion in 'Gen 2 Prius Main Forum' started by ZC1, Jun 6, 2008.
  1. efusco
    efusco Moderator Emeritus
    19,891
    1,196
    Nixa, MO
    Location is correct. I believe the part is incorrect.
  2. ZC1
    ZC1 Junior Prius Owner
    711
    Metro Detroit
    What it is: A Brake Control sensor
    Where is it located?: Attached to left side rear axle and to the left side undercarriage.
    ZC1
  3. Bill Merchant
    Bill Merchant absit invidia
    4,096
    87
    Is that the HID level sensor attached to the left rear axel? This is attached to the axel, the arm goes forward and slides/pivots on the underbody, I think.
  4. patsparks
    10,664
    567
    Adelaide South Australia
    It's above the left rear axle and it is a brake balance ride level, load sensor.
  5. Patrick Wong
    18,210
    6,515
    Where: Above rear axle, the part is mounted to the body while a sensor arm is mounted to the rear axle
    Its purpose: This is a "height control sensor subassembly rear", and its purpose is to help HID headlights remain properly aimed as load is added to (or removed from) the rear hatch.
    <Evan's photo was great - who would expect such a small part would look so big in the picture.>
  6. efusco
    19,891
    1,196
    Nixa, MO
    Bill was the first to get it right. I picked that part b/c it's one that a DIYer can fix him/herself should the need arise.
    See this article with pictures for more info....
    Bill, TAG, you're it. Post a pic.
  7. ZC1
    711
    Metro Detroit
    I think I'm gonna win the award.....
    for being Chump the most. :(
    ZC1
  8. patsparks
    10,664
    567
    No you won't.
  9. Patrick Wong
    18,210
    6,515
    Hi Evan,
    In the first photo that you provided, note that the left rear shock is leaking oil.
  10. efusco
    19,891
    1,196
    Nixa, MO
    Thanks, but that's not my car, that's a photo from the linked site...and about 3 years old!
    BTW those of you who were stumped....I'm disappointed you didn't pick up on my "Shed some light" clue in my second post!!!
  11. Bill Merchant
    4,096
    87
    What and Where?
    OK, here's a part you've probably seen, though maybe not from this angle.
  12. Bill Merchant
    4,096
    87
    Come on, Chumps! Almost 12 hours...
  13. efusco
    19,891
    1,196
    Nixa, MO
    No scale huh. I think it's a hinge for the glove box.
  14. Bill Merchant
    4,096
    87
    Nope. :heh:
  15. V8Cobrakid
    V8Cobrakid Green Handyman
    3,790
    152
    i've been trying to think of it all day long...
    not sure... at first i was thinking rear wiper.. but that's wrong...
    so far i'm thinking it's the parking brake arm :whip:
    *fixed the typo since i can't spell brake correctly*
  16. Bill Merchant
    4,096
    87
    I don't even know what a parking break arm is. :noidea:
  17. V8Cobrakid
    3,790
    152
    or the normal brake arm
  18. Bill Merchant
    4,096
    87
    No. Here's a little clue: if you could straighten it out, it would be about 5" (127mm) long, but this part isn't flexible.
  19. V8Cobrakid
    3,790
    152
    i assume it's part of an arm... because it looks like it may swivel by that attached clip.. or something..
    steering column adjustment?
    I can't think of any strips of metal... or hard plastic... that look like that.. except the strange ones in the air intake.. but they are all bigger pieces.
  20. ZC1
    711
    Metro Detroit
    Darn it Bill..
    I should be eating lunch, not like I am, crammed into some small spot in my Prius upside down with a flashlight in my teeth..
    It's all your fault..
    ZC1
