Stump the Chump!
Discussion in 'Gen 2 Prius Main Forum' started by ZC1, Jun 6, 2008.
  1. ZC1
    ZC1 Junior Prius Owner
    711
    Metro Detroit
    O' my. I've done both and more, for sure, I never saw anything like your picture. It must be the cameraman.
    ZC1
  2. Bill Merchant
    Bill Merchant absit invidia
    4,096
    87
    left front wheel well/arch
    brake line and speed sensor wire
  3. galaxee
    galaxee mostly benevolent
    9,810
    471
    MD
    rear wheel well- what side has the fuel filler down there?
    fuel system vent tube
  4. patsparks
    10,664
    569
    Adelaide South Australia
    We have a winner!!!
    There are actually 3 pipes in the picture which was taken with the camera right under the wheel arch, that is why I had to cover the flash.
    On the far left of shot is the fuel filler pipe and centre and right are 2 vent pipes. The caked on dirt look is actually sound deadening material appied by Toyota although there are some brown spots of dirt from a recent trip. I put some lines on this picture to make it easier to see.
  5. galaxee
    9,810
    471
    MD
    ok- will get the next one up tonight when we've got a minute.
  6. galaxee
    9,810
    471
    MD
    ok. major and possibly dangerous disassembly required. you likely have not seen this in person.
    2 good clues to start off, have a shot.
  7. Patrick Wong
    18,210
    6,517
    Location: Interior of brake control power supply unit, located near the 12V auxiliary battery in the right-rear hatch floor
    Purpose: Electrolytic capacitors storing emergency power for brake system in the event of a 12V bus power failure
  8. galaxee
    9,810
    471
    MD
    that is correct! :)
    guess that was too easy... next time you guys are in for it.
  9. efusco
    efusco Moderator Emeritus
    19,891
    1,196
    Nixa, MO
    Cool, I hadn't seen pix of those before...nice.
  10. patsparks
    10,664
    569
    Now I won't need to electrocute myself pulling that apart to see what is in it.
    If it is an emergency brake power supply and the brake servo is in the front of the car why is this unit in the back?
    Sorry I know this is off topic.
  11. Patrick Wong
    18,210
    6,517
    OK, here's a photo out of my archives...
    What is the location and purpose of the cutout in the center of the photo.
  12. galaxee
    9,810
    471
    MD
    pat: DH says "beats the $%#^ out of me!"
    patrick: under windshield wiper cowling cover
    allows water to drain
  13. Patrick Wong
    18,210
    6,517
    Hi Galaxee,
    Excellent answer - now you can post your tough photo.
  14. patsparks
    10,664
    569
    Wooooh you are good!!!
  15. galaxee
    9,810
    471
    MD
    dang. now we have to come up with it :p
  16. galaxee
    9,810
    471
    MD
    another major disassembly item. the part in question is the line in the foreground.
  17. Patrick Wong
    18,210
    6,517
    Purpose: Vent hose connecting charcoal canister and fuel tank.
  18. patsparks
    10,664
    569
    Fuel filler hose inside the fuel tank from the subtank along side the bladder to the plate shown on the left of shot which allows the filler pipe to go through the steel outer housing of the tank.
  19. galaxee
    9,810
    471
    MD
    location is correct.
    purpose is almost correct. technically, this particular line does not connect to the charcoal canister.
    geez, i hope this was at least sorta hard. have our fuel tank dissection photos made it that far around the world, or has someone else done it?
  20. ZC1
    711
    Metro Detroit
    According to what literature I can find, the unit is not exactly the brake control power supply unit as stated by Pat
    but the "power source BACKUP unit." Unless it serves a dual purpose, it doesn't supply power to the brake control unit during normal operation.
    Of course, it's location is the same place as Pat mentioned.
    In the '04 & later Prius, the power source backup unit has been adopted as an auxiliary power source in order to supply power to the brake in a stable manner. This unit contains 28 capacitor cells, which store an electrical charge provided by the (12V) vehicle power supply.
    When the voltage of the (12V) vehicle power supply drops, the electrical charge stored in the capacitor cells is used as an auxiliary power supply to the brake system. The electrical charge stored in the capacitor cells becomes discharged when the HV system stops operating after the power switch is turned OFF.
    ZC1​
