Stump the Chump!
Discussion in 'Gen 2 Prius Main Forum' started by ZC1, Jun 6, 2008.
  1. ZC1
    ZC1 Junior Prius Owner
    711
    Metro Detroit
    Purpose: EVAP purge line (connects to the Purge flow switching valve)
  2. Patrick Wong
    18,210
    6,517
    Hi Galaxee,
    Your DH's fuel tank dissection efforts and photos are well known throughout the various Prius online communities! I studied them closely in the past when I was a PriusChat lurker. The Hybrid13 Fuel and EVAP System.pdf file stored at autoshop101.com is also a good reference document.
    If your challenge referred to the short rubber hose that is secured with two cheap hose clamps, then it appears that the hose is attached to the charcoal canister. Please see the second page of the attached exploded parts diagram; note the drawing of the charcoal canister located on the right side of the page, and see the rubber tube with the cheap hose clamp.
    Hi ZC1,
    Well, the official name of the unit is the Brake Control Power Supply Assembly. The name may be misleading, but it is what it is. See attached page for more info.
  3. patsparks
    10,664
    569
    Adelaide South Australia
    Sort of global this interweb thingy, even Aussies if they pedal hard enough <reference to flying doctor radios used it the outback before power was available> can see some of the stuff on it.
  4. galaxee
    galaxee mostly benevolent
    9,810
    471
    MD
    you know there are lots of short rubber hoses in that area that are secured with two cheap hose clamps. ;) the hose in the picture is not the same one as the hose you refer to in the pdf.
    in that case, the location is also wrong. i incorrectly interpreted your response. and i gave a big hint away in the process.
    lol... ok so i should have worded that a little better. :p
  5. Patrick Wong
    18,210
    6,517
    OK then...
    Purpose: Pipe that connects bladder to fuel pump/fuel level sending unit
  6. galaxee
    9,810
    471
    MD
    location now precisely correct.
    purpose incorrect.
  7. Patrick Wong
    18,210
    6,517
    Purpose: Pipe that provides fuel pumped by the fuel pump, to the metal nipple mounted on the tank's exterior
  8. galaxee
    9,810
    471
    MD
    clue:
    no liquid-phase substance should be inside this line.
  9. Patrick Wong
    18,210
    6,517
    Sigh...
    Purpose: Pipe that facilitates flow of fresh air into space between bladder and fuel tank shell
  10. ZC1
    711
    Metro Detroit
    Edited post, .......because we are and have been having problems with accessing and posting to this supposedly new site.
    sigh...
    check my next post for the real entry...
    ZC1
  11. ZC1
    711
    Metro Detroit
    Are the following documents not acceptable?
    Check page 6-6 of the brake Toyota training document and page 5-11 of the chassis Toyota Training document.
    In both documents, it is called the Power control backup unit
    and
    if that is it's purpose and actual function, then I'd perfer the correct naming structure and usage, despite one replacement page shortening the name or overlooking the proper name.
    I'm open to correction, anyway.
    :D
    ZC1
  12. ZC1
    711
    Metro Detroit
    Darn it Pat, quit guessing so much...
    That was my next guess.....errr... answer
    if the EVAP line wasn't accepted.
    :D
    ZC1
  13. galaxee
    9,810
    471
    MD
    next clue:
    look carefully at what it connects to on the right side of the picture. not many connections to that part- narrows down the field a LOT.
    ZC1 is on the right track but did not give the right destination.
  14. ZC1
    711
    Metro Detroit
    Purpose: EVAP purge line (connects to the Charcoal cannister)
    ZC1
  15. ZC1
    711
    Metro Detroit
    Correction: According to the document I have the EVAP does not connect to the Charcoal cannister.
    Purpose: EVAP purge line (connects to fuel tank level thingy)
    ZC1
  16. patsparks
    10,664
    569
    My guess
    Location: - inside steel casing of fuel tank left side.
    Purpose: - allow fuel vapour to escape to the filler neck when refueling.
  17. galaxee
    9,810
    471
    MD
    location inside fuel tank housing above bladder is correct.
    it is indeed one of the evap lines.
    next clue: it comes from the white box on the right side of the pic- which is the sub-tank assy that contains the fuel pump.
    if you have the diagram of the fuel system, and read previous answers, this will rule out all other possibilities.
  18. ZC1
    711
    Metro Detroit
    Purpose: EVAP purge line (connects to fuel tank level thingy, also known as the fuel pump)
    (The documents/photos I'm looking at don't seem to be consistent and show what seems to be an older style of fuel tank. Oh well...)
  19. Patrick Wong
    18,210
    6,517
    Purpose: Recirculation line from fuel pump assembly to entrance of fuel filler tube.
  20. patsparks
    10,664
    569
    Inside the fuel tank steel housing
    takes vapor to the VSV for CCV
