Stump the Chump!
Discussion in 'Gen 2 Prius Main Forum' started by ZC1, Jun 6, 2008.
  1. galaxee
    galaxee mostly benevolent
    9,810
    471
    MD
    and patrick does it again. way to go!
  2. Patrick Wong
    18,210
    6,515
    Thanks, Galaxee!
    I will post a new photo later today. In the meantime, in the interest of promoting Prius technical knowledge, I attached a couple of excerpts from the 2001 and 2004 NCF that provides details of the fuel system for the benefit of members who have been following the discussion about your most recent photo.
    I have to admit that this system is quite complex and I have not taken the time to fully understand it; fortunately it has worked without problems on both of my Prius.
  3. Patrick Wong
    18,210
    6,515
    What is the location and purpose of the flat plate in this photo?
  4. patsparks
    10,664
    567
    Adelaide South Australia
    Oil filler hole.
    Inside the rocker cover. Or more correctly, the cam box top. (I don't think there are any rockers.)
  5. patsparks
    10,664
    567
    Well done Patrick, by the way. Oops where are my manners?
    Hey, how many Patricks are there on Prius Chat? We seem to be a little over represented. I remember seeing 4 yesterday, in person I only know 1 other Patrick but I don't get out much I suppose.
  6. Patrick Wong
    18,210
    6,515
    Hi Pat,
    The location is correct. What is the purpose of the flat plate?
  7. ZC1
    ZC1 Junior Prius Owner
    711
    Metro Detroit
    Purpose: To eliminate oil splashback while the engine is operating.
    ZC1
    (most oil covers have this, since the early 60's at least)
  8. Patrick Wong
    18,210
    6,515
    Hi ZC1,
    Well...there are no rocker arms, but I assume that you mean the valve cover; and will give you full credit. Congratulations!
  9. ZC1
    711
    Metro Detroit
    Pat,
    You assume correct, the rocker arm cover is the valve cover is the shiny rectangular boxes on each side of the engine (in my show car).
    No rocker arms in the Prius, how is variable valve opening performed?
    ZC1
  10. Patrick Wong
    18,210
    6,515
    Only the intake valves have variable timing. The intake camshaft sprocket contains a hydraulic mechanism that allows the camshaft to vary its position with respect to the sprocket, based upon engine oil injected under pressure.
    I am looking forward to seeing your next photo!
  11. galaxee
    9,810
    471
    MD
  12. ZC1
    711
    Metro Detroit
    Okay, Boys and Girls....Time to put on your thinking caps.
    No...!! not the tin foil ones you normally wear, the "other" one.
    That is right.
    Pat...!!! Put down that pocket protector.
    Galaxee...!! Stand up straight...sheesh.
    (little rascals....)
    ZC1
  13. patsparks
    10,664
    567
    Looks like an electrical component but I have a funny feeling I'll be a chump on this one.
  14. efusco
    efusco Moderator Emeritus
    19,891
    1,196
    Nixa, MO
    Your camera has a hot pixel....no idea what that is, something must pivot on it from the looks.
  15. ZC1
    711
    Metro Detroit
    Yeah, the hot pixel comes and goes depending on the back ground color. I have a couple pics where it's not showing.
    I wondered why everyone kept getting red-eye....pffttt..
    Great guessing guys, keep it up ....c h u m p s .. :D
    ZC1
  16. efusco
    19,891
    1,196
    Nixa, MO
    the hot pixel is always there, just won't show as much with lighter backgrounds. If it's a good camera you can get it mapped out by the manufacterer, if it's a point and shoot it isn't worth it.
  17. ZC1
    711
    Metro Detroit
    A slightly wider shot.
    ZC1
  18. patsparks
    10,664
    567
    Is it a disc brake caliper slide pin?
    I doubt it though.
  19. patsparks
    10,664
    567
    Battery cable attached to the traction battery inside the steel casing.
  20. ZC1
    711
    Metro Detroit
    Okay Sir, thank you for playing toss the rings atop the tall coke bottles, where there's always a stuffed animal for a prize.
    Try again Sir? or please step back, there's other people trying to get in.
    [puts down carnival barker microphone]
    ZC1
