Stumped by P0301 and P0302
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Jeff80465, Jul 24, 2016.
  1. Jeff80465
    Jeff80465 Junior Member
    I did spray some ether around the general vicinity some time ago thinking there may be a vacuum leak near #1. No such luck. Also used a tube to try to listen for a vacuum leak. Didn't make any difference
  2. goku9384
    goku9384 Member
    47
    37
    Hello just wondering if you were able to fix the problem. My car sounds exactly the same I have confirmed all my spark plugs and coils are working fine.
    SFO likes this.
  3. Angel209
    Angel209 Junior Member
    Stockton
    Which one fixed the p0302
  4. edthefox5
    edthefox5 Senior Member
    10,096
    4,837
    Clearwater, Florida
    On a 200,000 + mile car misfire's that move around from cylinder to cylinder sometimes reflect engine damage and is mechanical.
    You may want to put the engine in inspection mode and listen to the bottom end of the engine by crawling under the front of the car when the engine is running. In inspection mode the engine runs continuously.
    Go on youtube search
    Prius inspection
    it will show you the chicken dance to get into that mode. harbor Freight sells a real nice mechanics stethoscope. It works great. Probe the engine while running listen for bad lower end sounds and injector firing. Listen for misfires.
    On my car the engine runs very very smoothly in inspection mode.
    #24 edthefox5, Jul 31, 2019
