Stumped on knock noise
Discussion in 'Gen 2 Prius Main Forum' started by Dalton Warren, Jun 13, 2019.
  1. TMR-JWAP
    TMR-JWAP Senior Member
    6,404
    6,091
    Columbia, SC
    Without being there in person, and we all know internet troubleshooting isn't worth a dang, I'm leaning toward vacuum leak. Then fuel system/delivery.
    Worn bearings are not at the top of my list. If you really think it's a bearing issue, then throw some 20w-50 in it and see what happens.
  2. Dalton Warren
    Dalton Warren New Member
    Utah
  3. TMR-JWAP
    6,404
    6,091
    Columbia, SC
    Here's a bit of info....
    RANDOM MISFIRES
    After reading that, I am leaning even more toward a vacuum leak.
    If the bottom end is shot, thicker oil isn't going to hurt it any............but it should make it less noisy.
    I don't think it would cause any problems, even if the engine were new. It would drop your mpg a little, but I don't think the 1.5L engine is full of tight clearances that would starve due to thicker oil, especially at 300k miles of wear.
    Many times it's the most simple answers that solve our problems. Replacing an engine doesn't fall under that category right now.
    #23 TMR-JWAP, Jun 14, 2019
  4. Dalton Warren
    Utah
    Also gonna go get some starting fluid and spray around the intake cause even with car in park and alittle gas the knock goes away going to see if i have a vaccum leak with some starting fluid
  5. Skibob
    Skibob Senior Member
    2,912
    1,505
    Northern California
    Starting fluid to look for a vacuum leak? Wouldn’t a spray bottle of water be a little safer?
  6. TMR-JWAP
    6,404
    6,091
    Columbia, SC
    In the old days of carbs and non-electronic idle control, starting fluid would cause the engine rpm to jump rapidly if sprayed near a vacuum leak. Made it easier to ID the location. I haven't had to do this in a long time, so I personally don't know if it's still as effective for a modern engine. I'm sure it would make some difference in the engine sound.
    SFO likes this.
  7. Dalton Warren
    Utah
    Yea no leaks anywhere sprayed every where for about two hours didn't find any leaks hmm I never heard of a Prius having a bad bottom end have you also it only starts when the battery for the hybrid is low and it starts to build battery back up but sometimes it stays running to keep heater warm
  8. Raytheeagle
    Raytheeagle Senior Member
    11,265
    15,520
    Bay Area, California
    2019 Prius Prime
    Have you checked the COPs (Coil Over Plugs) to ensure they aren’t an issue and the spark plugs have good contact?
  9. Dalton Warren
    Utah
  10. Raytheeagle
    11,265
    15,520
    2019 Prius Prime
    OEM?
    Skibob and SFO like this.
  11. T1 Terry
    T1 Terry Active Member
    929
    491
    Mine is an Australian build so has a fuel filter and that turned out to be the problem. I believe the US versions do not have an external fuel filter and everything is in the tank. Does the US model have a fuel supply and fuel return line? If so, disconnect the return line and put it into a suitable container. This is to see how much fuel is going back to the tank. Add a T piece and pressure gauge and slowly clamp off the return line while watching the pressure and fuel flow. You should see at least 40psi and still have good fuel flow through the return hose.
    T1 Terry
  12. Dalton Warren
    Utah
    Yes from toyota
  13. Patrick Wong
    18,210
    6,510
    No, the fuel return line was eliminated, hence one less source of hydrocarbon emissions.
    I agree that fuel line pressure should be checked, and the spec is 44 to 50 psi at idle.
    It is possible that a vacuum leak would allow excess air to enter the intake manifold and cause engine misfire; however I would then expect DTC P0171 (system too lean) to be logged by the engine ECU.
    OP says that the engine compression was checked. What was the method to check the compression, and what were the results? Since he does not have access to Techstream my guess is that MG1 spun the engine at the typical 1,100 RPM. That will make cylinder compression look pretty good compared to a test on a regular vehicle where the starter is spinning the engine at around 300 RPM.
    While using Techstream, the spec is 128 psi, 99 psi minimum, difference between cylinders should not exceed 14 psi.
    There is no problem with the use of 20W-50 except that in the winter months, the engine may have some difficulty starting due to the thick viscosity vs. 5W-30 oil.
    #33 Patrick Wong, Jun 15, 2019
