Stupid cheap plastic hubcaps...
Discussion in 'Gen 3 Prius Main Forum' started by MikeDS, Jan 5, 2010.
  1. Tideland Prius
    16,680
    Yeah what he said ^
    better the plastic covers than the alloy.
  2. web1b
    web1b Active Member
    817
    52
    The hubcaps are a problem. I noticed when I got my car back from service, the paper work was marked with "cracked hub cap."
    I checked it and it was cracked. Cracked, not scuffed and dented and cracked like it would be if the tire scraped a curb.
    Looks to me like the dealership damaged it during the tire rotation when they pulled them off to access the lug nuts. Of course, I didn't look at them right before I turned the car over to them, so there is no way to prove that they are the cause. All I know is that I haven't hit a curb or handled the hub cap in any way and it's cracked now.
    Even if the dealer caused the crack, the hubcaps should not have been so delicate as to be cracked by normal service.
    If the dealer didn't do it, that means the hub cap just spontaneously cracked with normal driving. That would be even worse than if a cracked during removal.
    Will removing all the hub caps and adding a center crome cap instead have any negative consequences such as additional wind/tire noise, reduced fuel economy from more wind drag or damage from getting debris inside the wheel and brakes where the hubcap would have protected it?
  3. cycledrum
    cycledrum PSOCSOASP
    8,246
    1,202
    NorCal
    Many people are saying it doesn't effect FE, but I haven't seen a rigorous test on it yet. I don't think debris into brakes would be a problem - so many wheels out there are open.
    I asked a service advisor at T Sunnyvale if any negatives for removing wheelcover and he just said no.
    Personally, I don't like the wheelcover or the wheels underneath much.
  4. web1b
    web1b Active Member
    817
    52
    I looked up 2010 Prius wheel covers on eBay and found them selling for as low as $44.99 shipped for a set of 4 brand new hubcaps. At that price I guess I can consider them disposable. That's cheaper than buying chrome center caps. I can buy a set and keep the extras as spares.
  5. web1b
    web1b Active Member
    817
    52
    I double checked eBay and the $44.99 set of 4 is aftermarket hub caps that look kind of similar, but not exactly and have no Toyoto logo, so you need to use all 4 or they won't match. The cheapest OEM new I saw were $55 each shipped.
  6. Tideland Prius
    16,680
    It shouldn't. I've put them on and off without issue. They have decent flexibility in them. I've been running without them for a year now (And the 2005 for about 3 years. I got my record tank without the covers on).
  7. Bassic
    Bassic New Member
    Essex County MA
    You could do one side of the car:)
  8. Dark_matter_doesn't
    Dark_matter_doesn't Prius Tinkerer
    692
    151
    Seattle, WA
    No negative consequence on FE as far as I can tell, and I've checked. No increase in wind noise, no impact on brakes.
    I like the alloy wheels without the hubcaps.
  9. beantowncruiser
    beantowncruiser New Member
    Boston
    Call me crazy - I like the wheel covers.
  10. adamace1
    adamace1 Senior Member
    1,403
    193
    Charlotte, NC
    I'm not that smart but plastic in between concrete and a 3,000 pound car. i think the plactic will fail every time.
