Stupid Question of the Month: How can I safely rotate a front tire?
Discussion in 'Gen 2 Prius Technical Discussion' started by Robert John, Jul 19, 2025.
  1. rjparker
    rjparker Tu Humilde Sirviente
    10,130
    6,293
    Texas Hill Country
    How to shift to Neutral for wheel bearing testing or towing?
    Not hard when virtually anyone with a Prius can test it in one minute.
    It's also useful information when the car has to be moved out of a tight spot for towing and won't go to Ready. It worked for me even when the Inverter failed.
  2. Hayslayer
    Hayslayer Active Member
    394
    226
    No, you're just that stupid. You prove it over and over and over again every time you post with no other goal other than starting an argument where you can then try to claim being a victim. You're just a pitiful example of a person, great example of a troll.
  3. Robert John
    Robert John Junior Member
    61
    Montreal, QC
    My sincere apologies to everyone, I did not intend to start such a sh*it storm. As the header in my post stated, it was the "Stupid Question of the Month."
    To answer ChapmanF's question: my 'deduction' on how to unlock the transmission was gleaned from reading as many posts as possible trying to find an answer. I did not find my deduction posted anywhere in this forum - it was distilled from what I had read... therefore my 'Stupid Question' post... I felt my deduction was unsafe, and there had to be a safer way.
    ChapmanF's detailed response on the correct & safe procedure was much appreciated... illustrating why 'crowdsourcing' the collective braintrust in this forum is such a valuable resource. I wouldn't be able to own, maintain & drive a 17-year-old Gen 2 Prius if it wasn't for this forum. I have a Gen 2 Volt now, but I'm keeping my Prius - it's a great car. Thanks again to all contributors for sharing their knowledge, experience, expertise & opinions.
    "I don't have all my ducks in a row; I don't know where most of them are; and I'm not sure they're all ducks" ;-)
    T1 Terry likes this.
  4. Robert John
    61
    Montreal, QC
    Failure! I finally got around to trying to trouble-shoot an annoying noise in/on a front wheels of my Gen 2 and executed the prescribed procedure to put the car in 'ON' but not running: (Pressed the 'ON' button twice without touching the brake pedal). But, although the car is not in 'Ready', it will NOT shift into Neutral, and the display remains in 'P'. I've tried varying the timing between the first & second pressing of the 'ON' button; holding the shift arm in 'N' or repeatedly moving it to 'N'; doing both simultaneously; running the car, placing it in 'N', shutting it off, etc. But no 'N'... nothing... de nada... rien... crickets. The transmission remains locked and the car will not go into 'N' ...unless it's in 'Ready' (i.e. running with the motor turning on & off periodically).
    Obviously, I'm doing something wrong. Any suggestions?
    Thanks!
  5. ChapmanF
    18,146
    Nothing in your question needs any apology. The storm started without you.
  6. xliderider
    xliderider Senior Member
    8,140
    3,276
    Honolulu, HI
    Robert John, after you turn the car on by pressing the Start button 2x without touching the brake pedal, you can and must press down the brake pedal before the car will let you shift out of Park to Neutral.
  7. Robert John
    61
    Montreal, QC
    Thanks for GBTM. After making a list of all the variations I had tried, I noticed I had never pressed the brake pedal to place the car in Neutral AFTER the first two steps WITHOUT the brake pedal (incorrectly assuming that NOT pressing the brake pedal was a necessary part of the sequence).
    D'oh! ;-)
    xliderider likes this.
