Stupidist Plan yet to save gas -- muzzling the alternator
Discussion in 'Fred's House of Pancakes' started by Stevewoods, Dec 1, 2025.
  1. Stevewoods
    Stevewoods Senior Member
    667
    1,268
    where I am
    So, forgive me if I have my facts a bit skewered, but late yesterday was waiting for some family members to arrive and was surfing the web with my phone.
    Came across a forum for Subarus, of which I am an owner, and the folks were talking about how to save a drop or six of gasoline, Subaru had done something -- like keeping the alternator from charging the starting battery too much?
    It was late I was tired, but it was something like that. And, to get around it, you should keep your headlights at full on, as then this new fuel saving system does not kick in.
    The past two weeks, we are getting some lower temps in the 30sF overnight and I had noticed the car seemed to have a very slight struggle starting first thing in the morning. I wondered if this is due to that "gas saving idea."
    Car is a 2024 Outback with 17K. During the rest of the day, no problem starting. I keep the auto stop system turned off. Guess I will drive with headlights FULL on for the next few days.
    This issue a known thing? Or were these forum folks a bit "out there." I can't find the site this morning....
  2. BiomedO1
    BiomedO1 Senior Member
    4,625
    2,425
    Left Coast
    Sorry; that sounds like some "tin-foil-hat" stuff. That seems like using a flame thrower to light a cigarette. While auto start-stop systems are mandated; putting a clutch on the alternator pulley seems a bit overkill and would never pay for itself. The math simply won't pencil out and would add to the overall price of the car. I do admit, strangers things has happened; like Bigfoot....:cool::D:eek::LOL::ROFLMAO:
  3. ChapmanF
    19,035
    My gen 3 Prius reduces the DC/DC converter output voltage to around 13.6 whenever it's in motion and the battery is above some threshold level of charge. It uses 14.7 or so when the battery is less charged, or when stopped/parked. (It is, apparently, making no effort to improve MPG-while-stopped, given that any percentage improvement of zero would still be zero.)
    So the idea's been around at least since model year 2010 for Toyota.
    fuzzy1 and futurist like this.
  4. Trollbait
    12,831
    For longer, and in non hybrids. The voltage fluctuated in the 2006 HHR. I think Honda was the first to use such 'smart' alternators. It helped a little with efficiency by not having the alternator be at full drag on the engine all the time.
    BiomedO1 likes this.
  5. Prodigyplace
    12,716
    11,848
    Central Virginia
    It likely just regulates the charge voltage and current to extend the life of the battery instead of overcharging it.
  6. Stevewoods
    667
    1,268
    where I am
    futurist likes this.
  7. Prodigyplace
    12,716
    11,848
    Central Virginia
    BiomedO1 and cyberpriusII like this.
  8. BiomedO1
    4,625
    2,425
    Left Coast
  9. futurist
    futurist Member
    57
    186
    United States
    2024 Prius
    Correct. One-way alternator clutches on pure-ICEs have been around a while now, which prevents the mass of the alternator rotor / pulley / belt affecting the crank only when power is applied... and not robbing energy from it when on trailing throttle.
    Makes sense and one of only a list of things which combined raise ICE mpg... but more mechanical complexity and more difficult fault diagnosis... but what else is new for pure-ICEs trying to get 40+ mpg combined. Having owned one... never again.
  10. fuzzy1
    10,713
    Huh? On normal generators (and thus alternators too), the torque on the input shaft is a function of the electric load on the output terminals. Reduce the electric load, and the mechanical torque is also reduced. That is how some gas should be saved.
    Trollbait likes this.
  11. ChapmanF
    19,035
    ^ This.
    We also get into the same subject in occasional threads wondering why the Prius MGs are a drag on the car when regen braking, but not just when spinning with no electrical load.
  12. PriusCamper
    PriusCamper Senior Member
    13,467
    5,436
    Pacific Northwest, USA
    The difference is so slight in energy efficiency its not worth it!
    Over at InsightCentral.net we had the same but oppostie conversation for Gen1 Honda Hybrids... There's a specifc wire that you can snip to send a continuous charge to the 12volt battery rather than letting the dumb computers decide when to charge the battery.
    It's been debated often as to the value of snipping this wire or not and because hybrids and EVs in general send a weak charge to 12v compared to what a standard alternator can do in an ICE vehicle, its fairly accepted to want to do all you can to keep your 12v.
    Whenever I put a new 12v battery in a Prius for someone I tell them that they need to put it on a worthy smart charger this time of year when days are so short because you need to drive your car for 12 hours non-stop to fully recharge with that weak charge signal to avoid the risk of a dead battery. So if you're reading this and you haven't charged your 12v in a long time, this is the month you'll want to do it!
  13. ChapmanF
    19,035
    The "weak charge" being sent in a Prius is, at least in part, the result of the exact behavior described here (since model year 2010 for sure, I don't know for sure about the earlier gens). Before programming that behavior on purpose, Toyota must have mulled over the "is it worthwhile?" question and arrived at an affirmative answer.
    Maybe the jury's still out on how worthwhile it has proven to be in practice, or whether they paid enough attention to the risk of inadequate charging in low-usage situations. But it seems unlikely they'd have gone to the trouble without seeing some numbers big enough to catch their interest.
    Trollbait and fuzzy1 like this.
  14. BiomedO1
    4,625
    2,425
    Left Coast
    Sorry, are we still talking about a Subaru alternator? I don't see how a reduced load would all of a sudden reduce the mass of that alternator. It's just wires spinning around in a magnetic field. As the Subaru engine accelerates, it needs to drag that alternator mass with it. I'll give you that a higher load may require slightly more turning force. Unless you disengage the alternator and your just spinning the pulley = no additional mass to slow down the engine = more gas saved. Think old AC compressor clutch. Building on this example, wouldn't a car tuning an AC compressor burn more gas than one that has it's compressor disengaged? That's a measurable difference not a theoretical one.
  15. PriusCamper
    13,467
    5,436
    I read an article a year ago that most all auto makers have made less than robust decisions regarding how hybrids and EVs distribute 12v power via the DC to DC converter. The amount of power you can generate from an alternator in an ICE car is so much more than what a DC to DC converter does and most all auto makers have underestimated the value of this.
  16. fuzzy1
    10,713
    I don't remember anyone claiming that it reduced alternator mass. And this effect is not specific to a brand, it is universal.
    I must challenge the "slightly" part. Any generator will have bearing and windage friction losses, but it will also have a drag element that, at minimum, reflects the electric load. The electric power of the load (plus associated electric resistance losses inside the generator) should directly translate to added mechanical force (in this case, a torque) dragging on the generator's shaft and pulley.
    This isn't "just wires spinning around in a magnetic field", this is the First Law of thermodynamics: conservation of energy. Energy is not created or destroyed, only transformed. When spinning around in a magnetic field, the wires sending out electric energy also experience drag from the magnetic field, a mechanical force resistance that is reflected at the spinning shaft. Disconnect the load, and this magnetic drag vanishes.
    I'm not thinking about AC compressors. Instead, I'm think of the big generators in powerhouses such as at Grand Coulee Dam that power our homes and businesses and streetlights. The load-induced torque is both theoretical and measurable, and very strong. And it doesn't go away no matter how much smaller you make the load and generator. It can only be swamped by other drag losses in the most inefficient devices. It is in car makers best interests to not make inefficient alternators.
    FWIW, I am a retired electrical engineer. After some classes and labs and looking around, I went in a different direction, but my career was still based around things like this.
  17. BiomedO1
    4,625
    2,425
    Left Coast
    Thanks; got it - big Hover Dam turbines same as itity bitty car alternators....
  18. Trollbait
    12,831
    The alternator is a tiny regenerative brake being applied whenever the engine is spinning. Reduce its electrical output, and that will reduce the braking force it is applying. The savings from it alone are tiny, but the manufacturer is chasing savings from all over the car design to meet regulations.
  19. fuzzy1
    10,713
    The physics is indeed the same.
    The primary difference between them is scale. But even at car alternator scale, though it may be small, it isn't "itty bitty". Even the smallest car alternators can consume a full horsepower in the electric drag portion "from wires spinning in a magnetic field" alone, not counting the bearing and other frictions.
    Though that isn't the operating point where Subaru is "muzzling" it.
    #19 fuzzy1, Dec 1, 2025
  20. T1 Terry
    T1 Terry Senior Member
    972
    551
    The "Smart Alternator" has been around for a very long time, I closed my mechanical workshop in '98 and they were already showing up outside new vehicle warrant periods, with all the problems they create.
    The first idea was to fast charge the battery to replace the over night losses and the starter drain, then throttle the voltage back to 13v to "maintain" the battery at the "fully charged" state. The problem was, no one who knew anything about lead acid batteries were listened to while this "great new idea for fuel saving" was put out there for technical adoption.
    A lead acid battery required that high end voltage to continue until the current acceptance drop to a low percentage over consecutive hrs, 5 mins isn't going to do that, but it does sulphate the plates so they can't store as much capacity and then access it when needed ...... the slow cranking in cold weather is the telltale this is what has happened.
    The other problem was rapid fan belt deterioration, that "squeal" when first started .... then finally, the flat battery. Who looked at the alternator belt being the cause?
    I'll cut this into two posts, just so no one drops into a comma
    T1 Terry
    Prodigyplace likes this.
