Sub and Amp install
Discussion in 'Prius c Audio and Electronics' started by Njimpt, Sep 22, 2019.
  1. Njimpt
    Njimpt New Member
    2016 Prius c
    I drive a 2016 Prius c One. Would it be okay to use a 1200w rms DC Audio amp and 2 DC Audio1200 watt subwoofers. Is it possible with the stock stereo to even install this? I grabbed the amp specs, any help with this would be truly amazing. I just dont want to damage the car.
    General Features:
    • DC Audio Competition Series 1.2K
    • Class-D Full-Range 1-Ohm Stable Monoblock Subwoofer Amplifier
    • RMS Power Rating:
      • 4 ohms: 350 watts x 1 chan.
      • 2 ohms: 700 watts x 1 chan.
      • 1 ohm: 1200 watts x 1 chan.
      • 16V system, 1 ohm: 1450 watts x 1 chan.
    • Total power output: 1200 watts RMS (12V)
    • Strappable for up to 2400W of power
    • Wired remote bass level control included
    • Pulse Width Modulated MOSFET power supply
    • LED power (green) and protect (red) indicators
    • Soft start turn-on
    • Preamp RCA outputs to daisy chain multiple amps
    • 3-way protection circuitry (thermal, overload, and speaker short protection)
    • High-density split-dome convection heat-sink for extreme heat dissipation
    • Input sensitivity: ~ 200mV ~ 6V
    • Frequency Response: 15 - 270 Hz
    • Total Harmonic Distortion (THD): <0.1%
    • Signal to Noise Ration: 100 dB
    • Variable low-pass filter: 35 - 250 Hz, 24 dB/octave
    • Subsonic filter: 10 - 50 Hz , 24 dB/octave
    • Variable Bass Boost: 0 to +9 dB bass boost
    • Variable phase: 0 - 180°
    • Fuse Rating: 40A x 3
Loading...
