Subcodes Reader
Discussion in 'Gen 2 Prius Main Forum' started by Don402, Feb 24, 2021.
  1. Don402
    Don402 Member
    50
    29
    Omaha, NE
    I have P0A78 & P0A94.
    What would I look for on a scanner to know if it could read the subcodes? Hoping for something on Amazon for under $200.
  2. SFO
    SFO Senior Member
    5,302
    4,250
    Northern California
    Not aware of a standalone toyota hybrid OBD2 scanner that can supply INFs (subcodes) for under 200. If you do find such a device please post the make and model in this thread so that others have the option to purchase as well.
  3. ChapmanF
    18,526
    I seem to remember the list of PIDs that vincent1449p reverse-engineered for Gen 1 included where the HV ECU inf codes were stored, so they could be programmed in to an app like Torque, or as XGAUGEs in a ScanGauge, and used to read the codes. The same would work if the corresponding info is in the Gen 2 PID lists floating around. I haven't checked that.
    SFO likes this.
  4. SFO
    SFO Senior Member
    5,302
    4,250
    Northern California
    If purchasing, you would look for mention of 'detail code', INF, subcode. If you already have an OBD2 scanner, then look for the above terminology, or possibly a "snow flake", a flower, or smoke cloud icons within the user interface or near the DTC displayed.
    After doing a quick search using the search feature here on PriusChat, I found this thread :
    Which mentions using Autel Elite scanner and INFs. P3000, no low block voltages, car is run and drive | PriusChat
  5. dolj
    dolj Senior Member
    8,553
    4,344
    Wellington, New Zealand
    You need a scanner that will read freeze frame data.
