Subwoofers?
Discussion in 'Prius c Audio and Electronics' started by Ali T, Aug 10, 2015.
  1. randy8876
    randy8876 Junior Member
    45
    17
    seattle, wa
    2015 Prius c
    20150820_193223.jpg this is under the carpet. I can get a pic tomorrow. Or check my build thread om here.
    OldNo7 likes this.
  2. OldNo7
    OldNo7 Member
    72
    26
    CT
    2014 Prius c
    Fiberglass?
  3. OldNo7
    OldNo7 Member
    72
    26
    CT
    2014 Prius c
    Nevermind, just saw your install thread. Nice! I thought about glassing a box (not under the mat though) but decided too much work. Lol.
    My budget was also much less. Bet yours sounds sweet. Thanks for the pics, I took none while I did mine.
  4. Sergiospl
    Sergiospl Senior Member
    3,938
    1,351
    28
  5. randy8876
    45
    17
    seattle, wa
    2015 Prius c
    It wasn't too expensive do the box.
    You need:
    2'×2' 3/4" MDF
    1'×2' 1" MDF
    1 GALLON RESIN
    CHOPPED mat
    I think it could be done for $120 and a days labor.
  6. Zuko89
    Zuko89 Junior Member
    34
    Holland
    Randy
    What for sub is that?
    Its not a sub for low frequentie.
    I needed al the Space of the spare tire and its bareley enough for the sub.( Poorted)
    Where you have the sub is the cooler for battery, or not at priusC?
  7. Zuko89
    34
    Holland
    My solution in prius 3
    Sergiospl likes this.
  8. randy8876
    45
    17
    seattle, wa
    2015 Prius c
    There's nothing installed in that space other than foam and the tire jack. Plenty of room for a 10" shallow mount sub while leaving the spare.
    The 10tw3 is very clear and hits hard. My crossover is set at 50hz and the sub handles everything below that easily.
    JL Audio has the full specs on their site.
