Success! Replaced Water pump and Thermostat
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by alltherightpills, Jun 19, 2023.
  1. alltherightpills
    alltherightpills Junior Member
    26
    42
    St. Louis, MO
    Today I swapped the water pump & thermostat (as preventative maintenance) on my 2011 w/ 166k.
    Not the most fun repair, but not terrible. I took off the passenger front wheel and pulled the cover back to expose the bottom bolt(s) - made that part much easier to accomplish.
    I use Torque Pro on my aftermarket head unit, so I've been able to watch my temps for the past 40k miles.
    Interesting observation: before the swap, my engine coolant temp averaged between 193-195, peaking at about 200 when I was pushing up a hill or something.
    Post-swap, the coolant is averaging 185, and only getting up to 192-193 when I'm pushing hard.
    I don't think 195 was damaging the engine, but I do like seeing a slightly lower average temp. Happy with the result!
  2. Mendel Leisk
    42,355
    Did you check how the old pump turned, compared to new?
    How did the old thermostat look, compared to new? Was there gasket fraying? One thing you can do is suspend both in a pot of water and bring the it up nearly to a boil, watch how they compare.
  3. Brian1954
    Brian1954 Senior Member
    2,689
    1,076
    South Central PA, USA
    Were the new water pump and thermostat Toyota OEM parts?
    The lower engine coolant temperatures may be due to the thermostat opening a little earlier and/or quicker than the old thermostat.
  4. alltherightpills
    26
    42
    St. Louis, MO
    Old pump was still turning freely, but I pulled the impeller and could see a hairline crack starting to form. I think I got to this just in time.
    The thermostat looked alright and seemed to move alright, but had a bit of small debris buildup on the inside.
    Yep, OEM parts straight from the dealership. That seems like a logical explanation!
    Mendel Leisk and CR94 like this.
  5. CR94
    CR94 Senior Member
    2,832
    1,243
    Northwestern S.C.
    Yes, that's interesting. Does anyone know whether Toyota lowered the thermostat opening temperature since 2011? My coolant temperature runs about the same as yours did with the old thermostat. That's hotter than expected, when the thermostat is supposedly specified to open at 82°C (180°F), as I recall.
    Of course, the engine temperature rapidly drops much lower when descending hills in fuel-cut mode in cool weather.
