Success Stories - Share your experience.
Discussion in 'PriiDash (TM)' started by 2009Prius, Jun 26, 2011.
  1. Britprius
    Britprius Senior Member
    5,194
    1,921
    Herefordshire England
    I am sorry this gives you problems, does Steve's car do the same? As his car is same year and trim as mine and we are using the same Cheap ELM clone devise.
  2. 2009Prius
    2009Prius A Wimpy DIYer
    2,705
    511
    63
    Yes it could have been Steve's car but I don't remember for sure. Here is a version that I added the workaround. Please give it a try and let me know how it works out. Thanks!
    Update: sorry the file needs to be changed. Please download again.
  3. 2009Prius
    2,705
    511
    63
    Was the f: drive full?
  4. Britprius
    5,194
    1,921
    I am running tight on space but, F: drive was not full. I only run Priidash for a few minuets at a time for testing then download the files and clear F; drive.
    I will give the work round version a go tomorrow and let you know how I get on.
    I imagine you must be up to your ears in requests but one suggestion for improvement would be to make the vertical bars representing the various drive sources in the PSD graphic the same colours as the RPM scales below. Thanks again for you help and patience.
    John.
  5. 2009Prius
    2,705
    511
    63
    Good idea! Let me put that on the to do list.
  6. SteveDH
    SteveDH Junior Member
    47
    London UK
    In windows it can be read like a file, but you cant dir it.
    you could just grab the code I did.. I let you enter a port number and did
    sprintf(buffer,"\\.\\COM%d",portNum);
    o->value(buffer);
    which worked and saved the user having to correctly format it..
  7. Britprius
    5,194
    1,921
    Tried the work round version today and I'm afraid it did not work.The only thing that ran was the clock. Check system using the two previous versions and they ran ok apart from the cat temps as before. Please do not treat this as urgent it is not. I appreciate you must have a considerable work load.
    I am trying to find a larger hard drive (bigger than 6gig) for my old lap top but it's not worth spending to much money on, but seems foolish to chuck it out when it will stand being use as a tool for the car.
  8. 2009Prius
    2,705
    511
    63
  9. Britprius
    5,194
    1,921
  10. 2009Prius
    2,705
    511
    63
    Click on the link that should bring you back to post #22. Download the attached file. It has the same file name but contains a new version. Give that a try. Thanks!
  11. Britprius
    5,194
    1,921
    Thanks Wimpy I'll let you know how it runs.
  12. Britprius
    5,194
    1,921
    I have loaded the new files on my lap top and given it a dry run (not connected to car) and everything seems fine. Like the new colour bars on the PSD graphics, much moor intuitive.
    I have a very busy day today so will not have time to check it on the car till tomorrow, but will have a 100mile plus round trip to do so should be a good test. I will keep you informed of the results.
    By the way thanks for the email, only got it today because of server problems with my provider.
    John
  13. Britprius
    5,194
    1,921
    Success everything working as it should for approx 130miles. I have the log files for approximately 50miles of spirited driving along English country lanes. If the log files are of use I can zip and post them.
    Thanks again to Wimpy and Steve for your help.
    John.
  14. 2009Prius
    2,705
    511
    63
    Great to hear it worked! Sure please zip and upload both the txt and csv files as I am still trying to figure out why the Windows version only sees about half as many messages as the CygWin version does.
  15. Britprius
    5,194
    1,921
    Wimpy files as requested.
  16. 2009Prius
    2,705
    511
    63
    Windows says "the compressed file is invalid or corrupt"?
  17. Britprius
    5,194
    1,921
    Will re zip the file and try again
  18. Britprius
    5,194
    1,921
    Wimpy second attempt. Have re zipped original file and unzipped it ok so should work now.
  19. 2009Prius
    2,705
    511
    63
    Thanks it works now. Could you also upload the corresponding csv file?
  20. Britprius
    5,194
    1,921
    Sorry I have deleted the file due to lack of space, however hear are matching files from today.
    I have just bought a 60gig hard drive for my lap top, should clear my storage problem when I get it all loaded with OS and Priidash.
