Suction Cups on Paint?
Discussion in 'Gen 3 Prius Technical Discussion' started by Baryonyx, Nov 10, 2019.
  1. Baryonyx
    Baryonyx New Member
    United States
    Where I live, we get a lot, a lot, a lot, of snow.
    I was given these windscreen covers as a gift, but I'm not quite sure if the suction cups will wreck my paint. What do y'all think?
  2. Leadfoot J. McCoalroller
    8,270
    7,775
    Pennsylvania
    2018 Prius c
    Suction cups on clean paint is fine.
    On dirty paint it will work like a sanding block, giving you much greater leverage to grind the dirt in and scuff the paint.
  3. Pluggo
    Pluggo Senior Member
    608
    534
    Folsom, Pennsylvania
    Tie a short extension string to each end, then attach the suction cups to the door windows.
  4. Kenny94945
    Kenny94945 Active Member
    863
    439
    Sausalito
    2016 Prius v wagon
    They won't wreck, but can mar painted surfaces.
    One key is to make sure the cups and the surface attaching to are 100% clean & pristine.
    For research on the marring, one could search Harley Davidson suction cup rider pillion seats on some Harley forums.
    FWIW if silver or white paint, I would not be too concerned if you follow my advice about pristine surfaces & cups.
    If black, well, you may see marring, yet a good machine polishing upon resale may work well to remove the marring.
    Good luck in your decision.
    Baryonyx likes this.
  5. RMB
    RMB Senior Member
    406
    642
    Oakland, CA
    If the length of the windshield cover is long enough, why not use the suction cups on the interior of the windshield?
    If the tongue/suction cup hole area are not long enough to reach the inside of windshield, will the tongues wrap around the A-pillar? You just close the door and have the door seals hold the cover in place.
  6. Baryonyx
    Baryonyx New Member
    United States
    Following @Kenny94945's advice, I ended up nixing the suction cups. I'm using extensions to shut them into the door. I'll let y'all know how it goes when I test it (and it actually snows lol)!
