Sudden Acceleration Verdict Is in - its not a electronic issue
Discussion in 'Gen 3 Prius Main Forum' started by s1njin, Feb 8, 2011.
Thread Status:
Not open for further replies.
  1. qbee42
    qbee42 My other car is a boat
    18,058
    3,082
    Northern Michigan
    The mere fact that you compare an embedded firmware control system to a desktop operating system suggests you have no understanding of how these systems work, or how they differ.
    Tom
    5 people like this.
  2. Politburo
    Politburo Active Member
    971
    208
    It's really nothing like Windows.
    Consider that Windows has to run on a wide range of hardware and run a wide range of software, both of which Microsoft has no control over. And to add another layer of complexity, the software has to talk to the hardware using drivers typically written by a third-party (this is where most Windows bluescreen errors occur).
    In a firmware application, the manufacturer (in this case Toyota) has complete control over the hardware that the code will run on, and has complete control over the inputs that the software sees. That doesn't mean that firmware debugging is a trivial task, but it just isn't in the same realm as a general-purpose operating system.
    ETA: I see that Tom made the same point while I was typing this.
  3. lolder
    lolder New Member
  4. KK6PD
    KK6PD _ . _ . / _ _ . _
    4,003
    946
    118
    Los Angeles Foothills
    Next we will have the gremlins that Shatner saw on the wing of the airplane in Twilight Zone.....
  5. SageBrush
    SageBrush Senior Member
    11,627
    2,533
    Southwest Colorado
    SUA is a religious experience: either you have faith, or you do not.
  6. Roland1555
    Roland1555 Senior Member
    282
    69
    Vancouver BC
    While I am certainly happy for Toyota and always felt that there was nothing wrong with the cars, sadly, I think the memory in people's minds of the recalls and fines paid by Toyota will linger for a longer time that news of the vindication.
  7. 2to4
    2to4 Wherever we end up
    67
    Southwest, Indiana
    What matters to me is what I experience and not what other people think. I have never experienced any sudden acceleration problem with my Prius.
    On my Honda Valkyrie, I did experience sudden acceleration many times. There was a design flaw, and it was in my wrist. :thumb:
  8. evpv
    evpv Active Member
    692
    341
    West Coast
    2019 Prius Prime
    FYI, none of the vehicles tested in the NASA study were Prius. They tested 6 Camry's.
  9. RRxing
    RRxing Senior Member
    2,564
    1,842
    NEPA
    All I can say is they certainly took long enough. At least I know I can drive my car again. I hope the battery didn't die after 10 months in the garage.
  10. 32kcolors
    32kcolors Senior Member
    5,683
    954
    124
    Redondo Beach, CA
    And your point is? I hope you're not trying to imply that the problem only affects Prius and not other Toyotas with SUA claims.
    My god, some people are a paranoid bunch :rolleyes:
  11. DataWrangler
    DataWrangler Prius Owner (finally!)
    128
    West Houston, Texas
    Definately not a Prius-relevant document:
    Page 8
    If the driver depresses the brake pedal before turning on the ignition, then a voltage is instantaneously applied at an input of both microcontrollers before their 5V power supplies turn on. This can cause latch-up of the microcontroller input circuits.
    Can't start a Prius without depressing the brake pedal. :cool:
  12. Skoorbmax
    Skoorbmax Senior Member
    2,641
    265
    Western NY
    haha
  13. SageBrush
    11,627
    2,533
    Southwest Colorado
    I was just thinking about the class-action lawsuits. Maybe Toyota should offer a settlement: $100 voucher towards the purchase of a new Toyota.
  14. JimboPalmer
    12,470
    6,879
    Greenwood MS USA
    I am not sure it is fair to tarnish every programmer ever simply because Microsoft does shoddy work. This would be like blaming Toyota for Yugos.
  15. Pri4Us
    Pri4Us Junior Member
    82
    Tierra Buena, CA
    2 people like this.
  16. evpv
    evpv Active Member
    692
    341
    West Coast
    2019 Prius Prime
    My point is they didn't test a Prius. A Prius with Hybrid Synergy Drive is a lot more complex than a standard 4cyl/6cyl Camry. Brake force simulation alone makes the Prius much more complicated. Add two electric motor/generators to the equation. Add regenerative braking. Add the latest generation of traction control and stability control. Power inverter, etc.
    But if it makes you feel good, go ahead and assume everything is OK because they tested a few standard 2005 Camry's and didn't find anything. That won't help the people who've experienced problems.
  17. impact10
    impact10 Junior Member
    44
    Tennessee
    So, you lied when you said you'd accept the NASA report? Knock me over with a feather!
  18. bisco
    52,891
    well, that's disappointing.:(
  19. Engineer
    Engineer New Member
    37
    East Coast
    Man, you don't give up, do you? Still tilting at wind mills when it comes to the Prius? :eek:
  20. socalev
    socalev New Member
    31
    mission viejo
    :rolleyes:my god, some people are a defensive bunch
Thread Status:
