Sudden death of hybrid battery??
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by greyprius2008, Jan 3, 2017.
  1. mr_guy_mann
    mr_guy_mann Senior Member
    3,985
    1,930
    NJ-USA
    What does Dr Prius show for block voltages? In particular the "Voltage Diff" value. If you have a typical bad module, then the affected block voltage will be 1.0-1.5V lower than others (often only when the battery is being discharged at 20-30 amps or more). Voltage will go higher than others when charging (such as regen braking).
    If one block has wildly different voltage then it could have a problem with the small wires that connect the HV battery to the battery ecu- or there could be corrosion damage to that connector and the ecu.
    Need more data to be able to advise you.
