Sudden drop in mileage
Discussion in 'Prius v Fuel Economy' started by david.pool, Jan 25, 2014.
  1. david.pool
    david.pool Junior Member
    Admittedly, this is one of my infrequent visits here...I'm just not in the same situation I was in when we bought our 2004 right off the truck!
    Fact is, this question is about our 4th Prius in ten years...our 2013 Prius v, which we've had for about a month. This is actually our second "v" and we had that car, a 2012, for 18 months.
    What I want to establish is that we are by now a) quite familiar with the Prius family and b) even familiar with the "v" and its mileage, since during those 18 months we took the same 400-mile round trip each weekend (save for two), using the same route each time. On those trips, if there weren't any severe headwinds, we got 42-44 mpg (I call 43 the typical number). On Friday nights, the first 100 miles of the trip are on Interstate 25 at the posted limit of 75 mph. Most of it is flat or gently undulating, with a net elevation *drop* between Albuquerque and the offramp for Hwy 380 of about 350 ft. After that, we turn east on 380 and stay (where permitted) at the posted 65 mph limit.
    We've made this trip with the new 2013 3 times now and for the first two trips, its mileage pattern mimicked that of the 2012 exactly...until last night. For about 80 of those 100 miles south on I-25, the trip mileage was about what I expect it to be for that 75 mph stretch....something around 42. But just north of Socorro last night, quite suddenly the trip mileage average started to drop...and I mean by a tenth every minute or so. It dropped under 40 and, ultimately, got as low as 38.5 before stopping and recovering slightly, to get the average over 200 miles up to 39.8.
    This isn't all that troubling....other than the fact that it's never happened before with either of our "v" cars and it all happened so suddenly.
    As an aside, I also have a 2001 Honda Insight and the reason I bring that car into the discussion is that I'm aware that the Insight has battery software that, under certain circumstances, will deplete the hybrid battery (well, not entirely, of course...it just takes the IMA battery meter down to an indicated "0") and then charges it back up again. I'm not saying this episode last night with the "v" was battery related (no indication on the meter) but, is there any sort of similar pre-programmed "conditioning" of the current Toyota system that would explain such a sudden drop in a trip average over a span of about 15 minutes, then a bottoming out?
    52,761
    no offense, but i'm still trying to figure out what the problem is.:)
  3. rdgrimes
    rdgrimes Senior Member
    1,740
    448
    New Mexico, USA
    2018 Prius Prime
    Cold temps, low tire pressure could account for it. In any case a one-time event isn't significant.
  4. david.pool
    Bisco, I don't know that I classified it as a "problem," per se...but after making this same trip on the same road 70+ times with our 2012 v and then 3 more times with our new v -- in every season and in all types of weather -- I'd never seen this happen before. So....it got my attention.
  5. The Electric Me
    The Electric Me Go Speed Go!
    9,083
    5,801
    Undisclosed Location
    The sudden mileage drop you never noticed before in your other Prius v.
    I have to agree that your sample size here isn't big enough to red flag this yet as a problem or just a happening.
    This could be an experience, where YOUR experience is backfiring.
    I personally try NOT to worry about the mileage I may get on any one given trip, or at any one given moment. It's how I average for the entire tank/month.
    How's your overall mileage for a month in comparison to how it use to be?
    Prius are great. But I think to make a generalization a majority of us are more attentive drivers than many of our auto driving brethren. So sometimes the amount of information The Prius actually affords us, about our driving, can lead to a level of undeserved paranoia about what is or is not happening on any single given drive.
    I'm not saying you might not have a problem, but what I am saying....is see how it manifests over an average of a month or a few tanks, not just a single drive and a single section of a drive.
  6. kithmo
    kithmo Couch Potato
    2,404
    2,776
    47
    South Yorkshire, UK
    Headwinds, crosswinds, ambient temperature, heater temperature setting, tire pressures, load carried, humidity etc. can all have a small effect on mpg.
  7. kithmo
    kithmo Couch Potato
    2,404
    2,776
    47
    South Yorkshire, UK
  8. Munpot42
    Munpot42 Senior Member
    1,391
    544
    Santa Monica, Ca. 90405
    My vote is on the winds, head and or cross.
  9. skwcrj
    skwcrj Member
    278
    68
    Gig Harbor, WA
    David,
    I have owned my v for a little over two years and now have 26K mi on it. On a very few rare occasions, I have noticed some very odd behavior on my Scangauge. The computer will continue to charge the hybrid battery past 60% to around 65-68% while cruising on a fairly lever road at a constant speed of 60 mph. At the same time, the instant mpg on the the SG will jump to 9999. This lasted for a couple of minutes and the things returned to normal (mpg around 50-60 and the SOC back to ~60%). While this was going on, pressing the gas pedal did not increase the engine rpm (which was around 1400 rpm).
    Based on my rare experiences, I guess it is possible that you had some momentary odd computer behavior that caused the mpg to drop on that particular trip.
    Keep us posted.
    Do you have a Scangauge? Did you see any unusual parameters?
    Also.... Off the wall idea ... Is it possible you might have pushed slightly on the emergency brake by mistake by resting your left foot on it?
  10. lonninsj
    lonninsj New Member
    We are the happy owners of a new Prius V. We're just getting to know the car and have not even used a full tank of gas, yet. The last several times we've taken it out when I check the average fuel consumption, I'm seeing 24 or 25 MPG. We are in Minnesota and it is February, but still, this seems low. Do I need to drive in 'Eco' mode all the time to get the 40 - 44 MPG as advertised?
  11. fuzzy1
    10,687
    Eco mode will help a little, not a lot. Winter has a huge impact, MPG will improve significantly when warm dry spring weather arrives. It also takes a while to get accustomed to driving a hybrid. On top of that, there are many things drivers do that sabotage their MPG on regular cars, and it takes some time learn to learn better habits.
    To give us more clues to help, read this questionnaire, then start a new thread, answering as many of these questions as you can:
    Fuel economy complaints/queries? Please copy, paste & answer these questions, esp. if you're new
    The first link in the post leads to a dead end, so try here: Why Don't I Get The EPA Mileage?
  12. rdgrimes
    1,740
    448
    New Mexico, USA
    2018 Prius Prime
    Adding that in Minnesota, you really need a block heater.
  13. Stevevee
    Stevevee Active Member
    821
    224
    Vermont
    I've had issues this season more with the winds, plus long idles during major icing. But I don't think my mileage has ever dropped below 32 or so, and that was short-lived. It's well below zero here this morning, so short trips would definitely impact mileage. 24-25 would indicate short trips with winds and very cold, or possibly a problem. My current tank is almost 40 average, and the cold has definitely returned.
  14. tom s
    tom s New Member
    with my 2010 Prius II, living in southern New Mexico at about 4300 feet elevation I receive a consistent 50 MPG, however on several trips into southern Arizona and California, as soon as I leave New Mexico the mpgs start dropping and bottom out at just over 40 mpg. As this happens on the same tank of fuel, same temps, same wind conditions, etc, and not being the fuel, why? As soon as I get closer to the New Mexico border the mpgs start back up to just over 50 mpg. The only thing I can see different is the altitude... The dealership couldn't come up with a answer... Anyone have this problem or an answer...
  15. fuzzy1
    10,687
    High altitude has helped mpg on all my cars, hybrids and nonhybrids alike. The thinner air produces less air drag, and also reduces 'air pumping loss' in traditional Otto cycle engines in nonhybrids. But the difference should be less than what you are observing.
  16. rdgrimes
    1,740
    448
    New Mexico, USA
    2018 Prius Prime
    Yes, mileage always improves at higher altitude. Has to do with drag and thinner air (less fuel used, less horsepower)
  17. Munpot42
    1,391
    544
    Short trips in cold weather are mileage killers. One simple tip, when doing more than one short errand at a time, go to the one that is farthest from where you start and work your way back, this gives the car more time to warm up, hence better mileage.
