Sudden increase and then drop in MPG
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by priusphan, Jul 14, 2025.
  1. priusphan
    priusphan New Member
    Gainesville, FL
    I was torn between posting this in the fuel economy area or here so please let me know if I should move it.
    I have a 2013 prius with 133000 miles.
    I normally get about 47 MPG (Calculating at the pump, not with the onboard computer). A couple of tanks of gas ago I suddenly got about 51 MPG. Then the next tank it suddenly dropped to 37 MPG and has remained low for the past 3 tanks.
    This seems to be mostly for city driving. It still gets 47 MPG on long trips.
    Any help on what might have caused this spike and then drop would be greatly appreciated.
    52,784
    all recommended maintenance done? have you cleaned the egr circuit? tyre pressure at or above spec?
    might be worth checking all the wheels for brake drag, and getting a free 12 volt load test at many auto parts stores
    priusphan likes this.
  3. Grit
    Grit Senior Member
    6,577
    4,231
    Wilkes Land
    Maybe more AC use now were in middle of
    Summer. Or late night driving with stock headlamps on. Each lamp
    Is about 55 Watts
  4. ASRDogman
    ASRDogman Senior Member
    8,047
    4,078
    Is it the same pump everytime? Or a different one?
    Pumps cut off at different time. They "should" all be the same, but they are not.
    It happens to me sometime. I try to use the same pump at the different stations I go to.
    But it's not always possible. This past few weeks the Prius said I was getting 48mpg.
    When I filled, it calculated to 51mpg.
    The next week it said 47 something, calculated, 43 something.... both times I used a different
    pump then I usually used. It happens from time to time.
    When each time you fill it it lowers, you have an issue. You should look for consistency.
    #4 ASRDogman, Jul 15, 2025
  5. Mendel Leisk
    42,271
  6. priusphan
    Gainesville, FL
    Thank you! Tire pressure is good. I haven't cleaned the EGR circuit or checked for brake drag so I might try that. It came on suddenly so brake drag seems like a possibility. I'll also check the 12 volt load. It's a fairly new 12 volt battery (about 6 months old).
    Thank you. I've gone through several tanks from different gas stations so I'm guessing it's not the gas.
    Thanks. I'm calculating based on actual gas used and milage rather than the dashboard info. I've gone to different stations and it's consistently bad milage except when I've gone on longer highway trips at 45 mph or more.
    #6 priusphan, Jul 15, 2025
  7. priusphan
    Gainesville, FL
    Thank you. I've thought about AC use. I definitely have it on more right now but I think last summer was just as hot here in Florida and it definitely didn't drop 10 mpg back then.
    Headlight use is similar to my normal usage.
  8. ASRDogman
    8,047
    4,078
    All those are good to check and can reduce mpg.
    Since it's not just sometimes you get less mpg.
  9. DirkAshburn
    DirkAshburn Member
    161
    66
    Virginia
    Mine did the same thing. I get 37-38MPG now in my commutes, been steady like that for a couple years now I guess.
  10. priusphan
    Gainesville, FL
    Did you investigate the cause or just decided that is the new normal?
  11. douglasjre
    douglasjre Senior Member
    2,246
    751
    Null, NL
    Somebody joyriding it while u sleep
  12. priusphan
    Gainesville, FL
    Seems like the most likely scenario! lol
  13. DirkAshburn
    DirkAshburn Member
    161
    66
    Virginia
    Yes, tried several different things of varying results. I've chalked it up to a weak hybrid battery. Once it finally dies the plan has been to replace it and see if the MPGs go back into the high 40s. But who knows, getting tired of the Prius and have my eyes on a HR-V or similar.
  14. priusphan
    Gainesville, FL
    So far I've done both of these (even had the brakes redone) and I also had the engine tuned up. Still searching for the answer.
    I'll probably try cleaning the EGR circuit next.
  15. Grit
    Grit Senior Member
    6,577
    4,231
    Wilkes Land
    What if the hv battery dies while your
    On
    A busy highway and your car starts a pile up
  16. douglasjre
    2,246
    751
    Null, NL
    Kids live w u?
  17. DirkAshburn
    DirkAshburn Member
    161
    66
    Virginia
    I guess the saving grace is I only use the car for commuting where the average mph is about 22. If it dies I just pull over, most of my commute it shouldn't be a problem. But I get your point... have a decision to make soon I guess.
    #17 DirkAshburn, Jul 28, 2025
