Sudden Oil Consumption
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Noahdoge, Oct 24, 2022.
  1. douglasjre
    douglasjre Senior Member
    2,227
    743
    Null, NL
    I was using 15w50 in an oil burning engine until a planned engine replacement date. The 15W50 burst the oil pressure switch. I then switch to 0w40 and the Chinese oil pressure switch still only lasted a month. I'm at the point where I'm convinced there's no such thing as good aftermarket anything. I've had enough of cheap Chinese junk. I suppose if you want to tinker with Chinese parts you can on your own car but if you do this for a living you will quickly get a bad reputation buying Chinese crap. And if you value your time you'll realize that your labor is worth more than the difference in price for parts. You didn't buy a Chinese car why? So why do you buy Chinese parts for your car? I rest my case
  2. PriusII&C
    PriusII&C Active Member
    432
    146
    San Jose, California
    Wow, 15W50 in place of 0W20. That's a big change. How much reduction in oil burning did you see? Any other side effect?
  3. ASRDogman
    ASRDogman Senior Member
    7,954
    4,043
    The cold engine will work a LOT harder causing more stress on the parts because it's
    so think. And will still have to work harder because it's still thicker than it's designed to run.
  4. douglasjre
    2,227
    743
    Null, NL
    15-50 is extreme and I did it just riding out the remainder of what I could with a bad motor. It's def too thick of an oil for this engine.
    Awhile back I put an oil press guage on a turd gen w 0w-40 and w engine not yet fully warmed up I found pressures to be in normal range. Since I pull trailers I couldn't imagine using 0w-20 but if I lived in sub freezing temps and didn't pull a trailer I might. No wrong answer here except 0w-20 in summer w trailer and full throttle, and 15-50 at temps under 100f.... Just my opinion. Feel free to debate. I'm not asserting my opinion to be the only right answer
  5. douglasjre
    2,227
    743
    Null, NL
    Oh yeah, sidefx: press so high oil press switch ruptured. It made oil consumption go from 1qt/1k mi on 0-40 to 1/4qt. It's a bandaid til the motor was finished. And not a good bandaid. I don't recommend that thick of an oil unless ur planning on ditching the motor in the end
