Featured sudden speed loss
Discussion in 'Prime Care, Maintenance and Troubleshooting' started by dayanara b, Dec 15, 2022.
  1. dayanara b
    dayanara b New Member
    antelope valley
    hi i have a 2020 prius prime, i have been experiencing sudden loss of speed when driving on freeway. if i am at lets say 72 it will all of the sudden stop dropping down even thou i have not let up on the accelerator, it may slow down to lets say 64/65. now i am having to drive on the farthest lane to prevent back up. the speed does come up again after a few minutes but driving on the carpool lane makes this a scary situation when you are the one holding back traffic. has anyone experienced this? i have taken it down to autozone to get the scan to see if any issues come up but nothing comes up on the report.
    i would appreciate any feedback.
    #1 dayanara b, Dec 15, 2022
  2. Stevevee
    Stevevee Active Member
    821
    224
    Vermont
    That's a tad scary. I would not hesitate to take that to the dealer.
    dayanara b likes this.
  3. EdPalmer42
    EdPalmer42 Member
    135
    75
    2020 Prius Prime
    Are you using cruise control? If so, the car will automatically slow down if it catches up to a slower vehicle in front of it, or if it gets confused and *thinks* it catches up.
    52,404
    if you press harder on the pedal does the speed not change?
  5. dayanara b
    antelope valley
    No i usually never do cruise control, its weird it does not do it everyday but at least 1-2 times and it started maybe a few weeks ago...
  6. BiomedO1
    BiomedO1 Senior Member
    4,180
    2,185
    SacTown, Ca
    I really don't understand the question. You're not using cruise control and the car is slowing down. When that happens to me, I just push down on the accelerator. A car will slow down for various reasons; increased wind resistance, slight grade increase, change in road surface, even heavy humidity. I know my Prime looses a few mpg's when it's raining vs my ICE cars gain a few mpg's in the rain.
    OH; forgot the EV to HV switchover. I always have to start mashing the pedal when the car slips into HV mode.
    fuzzy1 likes this.
  7. fuzzy1
    10,603
    ^ The slight wind or grade increases can be quite unexpected and unobvious. For someone holding a fixed pedal position without cruise control, the effect is certainly significant.
    Changes from dry to wet roads, or damp to more wet roads, also add up. Or even from in- to out-of-tire ruts, which significantly alters the water layer thickness.
    #7 fuzzy1, Dec 17, 2022
  8. dbstoo
    dbstoo Senior Member
    1,397
    752
    Near Silicon Valley
    2024 Prius Prime
    XSE Premium
    Nope, never had that activity on a Prius Prime. You have, however, described what the car does when using the dynamic cruise control.
  9. dayanara b
    antelope valley
    NO. not using cruise control.
  10. dayanara b
    antelope valley
    hi , NO the even when it starts to slow down if i press try to accelerate it will not speed up or maintain it keeps dropping speed
  11. bisco
    52,404
    i'm wondering if the radar cruise control sensors are acting up, sensing there's a vehicle in front of you, although i think the throttle should still work, idk
  12. BiomedO1
    4,180
    2,185
    SacTown, Ca
    What mode is the car in when this happens? EV or HV
    If it's in HV mode, does the engine rev-up or nothing happens when you mash the pedal? How do you resolve this in traffic; pump the pedal or it just starts working all of a sudden? I wouldn't be driving a car in that kind of condition - take it to a mechanic ASAP. This would be a good way to get yourself T-boned in traffic; if it cut-out while trying to cross an intersection.
  13. MikeDee
    MikeDee Senior Member
    1,581
    597
    San Francisco Bay Area
    Fuel pump?
  14. FuelMiser
    FuelMiser Senior Member
    1,349
    929
    Monument, CO
    While not a Prius, we had a similar issue on a Isuzu Trooper many years ago. You mash the gas pedal and the car barely responds. Very dangerous. It turned out to be a clogged CAT! The exhaust simply could not escape, and back pressure would not let the engine wind up. I don't know how you'd diagnose this in a Prius, though. You seriously need to get your car to a qualified shop.
  15. MalachyNG
    MalachyNG Active Member
    304
    225
    Northern NY
    2022 Prius Prime
    This sounds like how the accelerator remaps when you run out of EV range. It's pretty noticeable especially if you've got the drive mode set to ECO. If I was at say 3/4 throttle (or whatever you call it) driving EV and it switches to hybrid mode (HV) the throttle drops gradually over a few seconds to below 1/2. Often I find myself pushing into the red prw zone to maintain speed when it switches to HV like that going up an incline.
    But if you're putting the pedal to the metal and still losing power then something is quite wrong.
    FuelMiser likes this.
  16. bisco
    52,404
    how many miles on her? i wondering about the egr circuit, throttle body and maf, cat, etc. things that aren't considered normal maintenance
  17. MikeDee
    1,581
    597
    Are you in EV mode when this occurs? EV mode is downright enemic at high highway speeds.
  18. bisco
    52,404
    but it should still accelerate or kick the engine on
  19. BiomedO1
    4,180
    2,185
    SacTown, Ca
    While these are good guesses, the problem would be persistent rather than intermittent; unless the OP doesn't know which mode the car is in when the problem occurs. Issues above would only occur in HV mode.
    Now if there's a "flat-spot"/defect on the accelerator pedal; this would occur in all modes. That's the reason for my questions above.
  20. MikeDee
    1,581
    597
    No, it doesn't. It stays in EV mode. It shouldn't slow down though, but if you are at max power for the electric motor, if you push the pedal to the floor it won't go any faster.
    iPhone ? Pro
