Sudden unnecessary revving while downhill
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Andres V, Nov 27, 2018.
  1. Andres V
    Andres V Member
    71
    34
    Queretaro, Mexico
    Hi. I am noticing a new problem on my car, the usual 2010 Gen3 Prius I have been talking about on various posts. I have to remind you it's been diagnosed for a battery replacement with P0A80 code. While I'm saving to buy a new battery it stays parked at home but once a week I try to drive around my residential area to keep it moving. Lately I'm noticing that while I'm cruising downhill and braking, or just free falling, the engine tries to rev for no reason, I am not using B mode. I am not experiencing extra acceleration just unnecessary revving and while on downhill I have tried to push a little bit on the gas and most of the times the revving disappears.
    It just happens sometime for the moment but it's been reccurent. Do you know anything about it? What is going on?
    #1 Andres V, Nov 27, 2018
  2. Leadfoot J. McCoalroller
    8,288
    7,802
    Pennsylvania
    2018 Prius c
    It's not for no reason. When the hybrid drive can't dump energy into the battery (as would be normal while driving downhill) it is forced to prevent the production of excess electricity- so it forces the engine to spin instead of the motor-generator. In effect it is going into a variation of B mode for you.
    That should normal up (along with all the other odd behaviors) once you have a new battery in.
    Lightning Racer likes this.
  3. Mendel Leisk
    42,345
    Yeah there's been a few comments here, that the car will take it on itself to do some B-mode.
  4. fuzzy1
    10,706
    Is the battery meter full when this happens? If so, it is expected and desirable behavior. It revs for minor engine compression braking. Slightly pressing the gas pedal overrides the engine braking, slowing the engine.
    In D mode, this behavior is similar to B mode but at a much lower level, e.g. just 2000 RPM in D, where B mode might hit 4600 RPM.
    If the battery gauge is NOT showing full when this happens, then you have a real issue.
  5. Andres V
    Andres V Member
    71
    34
    Queretaro, Mexico
    I haven't noticed the battery meter when this happens I'll try to be carful next time. I don't know from what your explanations it makes sense but it doesn't feel right when it happens a it's not a constant. I haven't explained everything. The route that I usually take when "exercising the car" goes all around my residential total area and at the end there's a moderate slope downhill that ends in a stop sign and from there it's close to home. I like to take this route to give the battery the last big pump of energy before parking it home. When I'm free falling and the engine starts revving, even when I about to stop the engine keeps revving. Is it normal even when the car almost still?
  6. bisco
    52,854
    just another symptom of your battery dying.
    Andres V likes this.
  7. Andres V
    Andres V Member
    71
    34
    Queretaro, Mexico
    I imagined it could be related. Hope by the end of the year I'm getting the new one as Christmas gift to myself
  8. bisco
    52,854
    i hope so too!
  9. fuzzy1
    10,706
    Normally when coasting or mild braking downhill, there will be some battery charging from regeneration, so the engine doesn't 'rev' or spin up. In D mode, only after the battery is full and can not longer accept any regeneration, will the engine 'rev' or spin up in its place.
    As Bisco mentioned, this could also be a symptom of the battery capacity diminishing with age and wear, thus filling up quicker than when it was young.
  10. jack black
    jack black Active Member
    225
    142
    I
    it just happened to me today. i went down the hill and stopped at a red light. noticed battery completely full (I rarely see it). then ICE started when standing still for no reason. It happened to me only once before, don't remember the battery state back then.
  11. FuelMiser
    FuelMiser Senior Member
    1,349
    929
    Monument, CO
    It is normal for the Prius to use regeneration charging to rev the gas engine when the traction battery is already fully charged to prevent overcharging it. When the Prius is coasting, it is still producing regen charge by virtue of the forward motion, and it has to go somewhere. It is also normal for the car to continue to spin the gas motor when you come to a stop until the traction battery returns to a normal level. If you are experiencing this sort of engine revving, it is important to monitor the state of charge of the traction battery to confirm what is going on. Also, keep in mind there is no gas being burned, the electric motor is simply spinning the gas motor to burn off excess battery charge.
  12. kurtscash
    kurtscash Junior Member
    Los Angeles
    Did you get your new battery yet ???? I'm shopping and its like $1000 or $1900 at Hybrid Battery shop vs $5000 dealer
  13. Dan05979
    Dan05979 Member
    181
    101
    New York City/Upstate NY
    I've always wondered why my engine is roaring like that after coming down a steep hill. And I love looking at a full hybrid battery charge because the very last bar is always darker than the rest of the bars on the screen. Now I know. Carry on.
  14. Prodigyplace
    12,712
    11,848
    Central Virginia
    You do not want a refurbished battery. That is jus a failed battery repaired with modules from other failed batteries. @2k1Toaster here sells a kit of new cells for $1600 shipped which basically gives you a new battery. You can recoup part of the cost by selling your old modules.
  15. ChapmanF
    19,020
    which nobody wants
  16. Prodigyplace
    12,712
    11,848
    Central Virginia
    I have heard people buy and sell them on eBay.
  17. ChapmanF
    19,020
    I've heard they're just modules from failed batteries.
