Sudden wiper failure, passenger side
Discussion in 'Gen 3 Prius Main Forum' started by donzoh1, Jul 9, 2020.
  1. donzoh1
    donzoh1 Active Member
    450
    153
    Lenexa, KS
    Any guesses on the likely cause of wiper failure...front only, passenger side. I don't have the car here but my guess would be motor failure.
    52,854
    i would think the motor drives both sides. maybe the splines are worn?
    or could there be a lock mechanism that has come undone?
    Johnny Cakes likes this.
  3. ASRDogman
    ASRDogman Senior Member
    8,066
    4,086
    If the drivers side works, it's not the motor. Something in the linkage.
    Or maybe the nut was/is loose. It's easy to take the top part of the housing off to look inside.
  4. Johnny Cakes
    Johnny Cakes Senior Member
    1,065
    789
    Virginia, USA
    My money is with Bisco, but maybe its just the wiper arm nut that's become loose. You will probably get answers from a visual inspection when you get the car back.
  5. 3PriusMike
    3,101
    2,421
    Silicon Valley
    Is that a wise place to keep your money?
    Just asking
    Mike
  6. Raytheeagle
    Raytheeagle Senior Member
    11,269
    15,528
    Bay Area, California
    2019 Prius Prime
    Mrs. Bisco has placed her bet there:).
    I think it's been for a significant period of time too;).
    Certain traits must be redeeming(y).
    3PriusMike, bisco and jerrymildred like this.
  7. Leadfoot J. McCoalroller
    8,288
    7,802
    Pennsylvania
    2018 Prius c
    One motor drives both wiper arms through a transmission linkage assembly.
    The "usual" failure point is the splined union between the driving shaft coming from the transmission and the root of the wiper arm itself. The locknut can come off, and the arm pops free.
    With any luck, there is still enough meat on the splines on yours so that you can re-seat it, and lock it back down with a new nut. If not, you'll probably need to replace the wiper transmission assembly. Usually cheapest to do with a junkyard part.
  8. jerrymildred
    jerrymildred Senior Member
    11,517
    14,167
    Tampa, FL
    I sometimes need to remind my friends that I'm not totally useless. They can always use me as a bad example. Perhaps Mrs. B. has found that to be true with her hubby. :D
    Edit to add: Almost forgot the original question. I would agree that it's either a loose nut (not related to my previous paragraph) or the splines. Or even bad splines AND a loose nut.
    3PriusMike, bisco and Raytheeagle like this.
  9. bisco
    52,854
    if you like your money in a stock market that is probably gonna implode at some point, and cd's that probably won't be worth the paper they're printed on, this is the place to come.
  10. 2014
    2014 Member
    30
    31
    MA
    Not sure if this feature is on the Prius, but I bet it is. Wipers have a disengage feature if the wiper arm is restricted so you don't shear the splines. If so, the wiper will be free to move if you try to sweep it by hand over the windshield. Open the cover over the base of the wiper arm, should be a nut there, place wiper in the park position you want, tighten the nut and the arm will be re-engaged.
  11. fotomoto
    fotomoto Senior Member
    5,639
    3,815
    So. Texas
    Another vote that the locking nut has worked loose.
  12. BZzap!
    BZzap! Senior Member
    1,607
    878
    The wiper linkage arm to the passenger side has probably popped off because of a worn bushing.
    ASRDogman likes this.
