Suggest a navigation - android head unit?
Discussion in 'Gen 3 Prius Audio and Electronics' started by franzfume, Aug 19, 2016.
  1. cproaudio
    cproaudio Speedlock Overrider
    2,401
    762
    CA
    How quick does the reverse camera come on after powering up the car and shift to reverse right away? The stock nav takes less than 2 seconds
  2. franzfume
    franzfume New Member
    28
    Italy
    Not mounted yet
    Inviato dal mio F5121 utilizzando Tapatalk
  3. CosbyComedy
    CosbyComedy Junior Member
    46
    52
    Columbus Ohio
    Mine comes on very quickly, even before the unit is ready.
  4. franzfume
    28
    Italy
    Just to know. You mean how much time the rear image appear after shifted to r? Why ask ? Isn't immediately available ? Btw tomorrow (Sunday) I mount my unit 8)
  5. cproaudio
    2,401
    762
    CA
    I mean how long does the rear camera image come on when you first power up the Prius and shift to reverse, not just shifting to reverse after you've already powered up the Prius for a while. I ask because I need that reverse cam image to show up as soon as possible. I can't wait 5 seconds or 10 for the reverse cam to show up. I need it as soon as I'm ready to back up. This usually less than 3 seconds.
  6. booke02
    booke02 Active Member
    391
    415
    Israel
    I had iGo on my 2010 Prius. Was quite happy with it. It is not limited to USA - they have maps (and languages) for most of the world. Only downside was having to periodically update the maps - but once every couple of years was enough.
    franzfume likes this.
  7. franzfume
    28
    Italy
    Why this long time ? is usual ?
  8. cproaudio
    2,401
    762
    CA
    Which part is long? Can't get any faster than powering up the Prius, shift to reverse and the get the reverse image to come up in less than 3 seconds. I don't understand your question and I don't think you understand what I posted either.
  9. booke02
    391
    415
    Israel
    I understand exactly what he is asking as I have exactly the same problem with my factory-installed system. The reverse camera is not immediately available after you power up the car.
    I have a 8GB USB stick permanently plugged in - I wonder if that slows down the initialization of the system???
  10. booke02
    391
    415
    Israel
    I figured out why the reverse camera was not immediately available. I power up the car, shift into reverse, reverse camera is displayed for a moment, and then goes away. The reason that it goes away is that the audio system (which was busy reading my USB stick) now takes over the screen, and places itself over the view of the backup camera.
    The problem doesn't happen if you wait a second or two after powering up the car before shifting into reverse. I don't get the problem after I power up the car, finish fiddling with my seat belt, and put on my driving glasses - by the time that I have done those few things and shift into reverse, the audio system is up and running so the reverse camera picture remains on top of the display
  11. franzfume
    28
    Italy
    Sorry. This is the antenna cable in Prius ? Strange. The head unit has standard plug. An adapter exist ? Any suggestion ? Seem a strange antenna cable....
  12. CosbyComedy
    46
    52
    Columbus Ohio
    I think I have this adapter. I didn't need it but thought I would. I'll try and locate it...
  13. franzfume
    28
    Italy
    Maps on iGo are a little old... But software is nice.
  14. ratedK
    ratedK Junior Member
    Indianapolis, Indiana
    Not sure if the provided cable will reach or not, but there is a great location for the GPS unit directly above the rear view mirror where the roof line meets the windshield (Directly in front of the sunglass storage compartment). The trim piece can be pulled off by hand and exposes a small empty space... I used the same space to install my radar detector https://priuschat.com/posts/2200611/
  15. saltdiscus
    saltdiscus Member
    198
    89
    US
    I got 2 sd card and 1 usb sticks all the time but it doesn't delay my reverse camera.it takes 1 sec to display ,even if the head unit is turned off.
