Suggested OBDII Tool to Customize Options?
Discussion in 'Prime Accessories and Modifications' started by pianohawk, Jan 28, 2017.
  1. Reverse Signal (buzzer) when the shift position is in R
    86.1%
  2. Vehicle speed linked seat belt reminder buzzer
    37.5%
  3. Duration of automatic lane change signal flashers
    26.4%
  4. Vehicle Proximity Notification System (volume of sound)
    19.4%
  5. Time elapsed before unlock- ing all the door when gripping and holding the driver’s door handle
    12.5%
  6. Open door reminder buzzer (when locking the vehicle)
    16.7%
  7. Remote button “A/C” control customization
    20.8%
  8. Simple Advanced Parking Guidance System customizations
    12.5%
  9. Intuitive parking assist customizations
    13.9%
  10. Power window customizations
    38.9%
Multiple votes are allowed.
  1. MagnusAG99
    MagnusAG99 Senior Member
    673
    521
    Norway
    Whats awesome abour carista is that they will update the features for all toyotas supported in january! new updates for 3rd and 4th gen i belive, aswell as the Auris/corolla iM.
    benagi likes this.
  2. dlegate
    dlegate Junior Member
    30
    16
    SF Bay Area
    What's the difference between a WiFI OBD and Bluetooth?
    I would think a WiFi one would need a WiFi network nearby to work? Or is it some internal WiFi in the device you connect to?
    Seems Bluetooth would work anywhere? Would love to hear.
    And are there any good pics or videos showing how/where we connect these in our Prius Primes?
    Thanks!
  3. jerrymildred
    jerrymildred Senior Member
    11,517
    14,167
    Tampa, FL
    My wifi adapter makes its own network.
  4. dlegate
    30
    16
    SF Bay Area
    Thanks Jerry! And yes, I found YouTube videos of where the port is (just above the parking break).
    My adapter arrives soon - can't wait to disable the reverse beep! (and see what other trouble I can get into! LOL)
  5. dlegate
    30
    16
    SF Bay Area
    Just a follow up... I got the ELM327 Wifi OBDII Scanner off Amazon for $15.99 since the Carista app said "which adapter do you have" and listed both theirs ($39.99) and the ELM327 Wifi.
    Worked like a champ! No more reverse beep, and no more passenger seatbelt warning beeps when there's a box in the seat. yay!
  6. DTS
    DTS Junior Member
    Bayarea
    I have a ELM327 WIFI and hoping for a free app??
  7. jerrymildred
    11,517
    14,167
    Tampa, FL
    iOS or Android?
    Torque Pro is about the best on Android.
    Or Engine Link on iOS.
    Engine Link isn't free, but it's cheap. Not sure about Torque Pro. Both will require custom PIDs. I don't know if they are available yet for Gen 4.
    Another possibility is Carista. Also not free. You rent it which I hate, but I'm thinking of giving it a try and if I really like it, I'll just rent it for special occasions.
    #27 jerrymildred, Mar 14, 2018
    DTS likes this.
  8. DTS
    DTS Junior Member
    Bayarea
    I have both devices, not to be cheap but $39.99 carista for a few clicks for sear belt and back up beeps is ridiculous. Darn just noticed the Bluetooth app is free
  9. jerrymildred
    11,517
    14,167
    Tampa, FL
  10. Ken Schwartz
    Ken Schwartz New Member
    Lincoln, CA
    jerrymildred likes this.
  11. benagi
    benagi Active Member
    525
    280
    Utah
    Be sure to cancel before the one free month is over or they will automatically renew you for one year.
  12. jerrymildred
    11,517
    14,167
    Tampa, FL
    I forgot to mention that. Thanks.
    :eek: Not nice at all! But all too common of a practice.
  13. DTS
    DTS Junior Member
    Bayarea
    If there's an option to use obd2 to overwrite navigation settings to play movies while driving for passengers to watch then I will buy carista ...
  14. Salamander_King
    Salamander_King Senior Member
    11,024
    8,980
    New England
    Can carista feed real time tire pressures from TMPS while driving? If not which OBDII adapter and app can I use for that purpose?
  15. quantumy
    quantumy Member
    55
    37
    I got a $10 Bluetooth OBD II to work with the Carista app, then selected "1 week free trial" and got it to work! Immediately discontinued the free trial. Still works. 2014 Prius Two and Android phone.
    Prius Tweak app would not work for me no matter what I tried...
    j12piprius likes this.
  16. illumiN8i
    illumiN8i Active Member
    184
    142
    Grand Rapids, MI
    2018 Prius Prime
    Carista cannot monitor live tire pressures but the free app Tire Assistant from the makers of Hybrid Assistant can. Unfortunately the app has a safety feature that makes it stop working when the vehicle is moving. While it only lists their supported OBD2 adapter, I got it to work with a cheap generic ELM327 Bluetooth OBD2 adapter.
    Tire Assistant - Apps on Google Play
    triggerhappy007 and john1701a like this.
  17. Salamander_King
    11,024
    8,980
    New England
    Thanks for the info. I think I am going with ScanTool 427201 OBDLink LX Bluetooth, so I can use Hybrid Assistant app. Cheap generic ELM327 Bluetooth OBD2 adapter may also work with Hybrid Assistant App, but they recommend ScanTool 427201 OBDLink LX, and it's only $30 difference.
  18. Lucifer
    Lucifer Senior Member
    1,014
    486
    Nh
    Scangauge2, tpms works on the prime.
  19. Salamander_King
    11,024
    8,980
    New England
    Thanks. I thought about that option too. Although Scangauge2 is very powerful tool, it is too pricey for this purpose. I simply want to monitor real time tire pressure without using physical tire pressure gauge.
  20. illumiN8i
    184
    142
    Grand Rapids, MI
    2018 Prius Prime
    Once you get your OBDLink LX, can you run a couple tests for me? Hybrid Assistant shows BAD OBD when used with my ELM327 v1.4 adapter. I want to see what data you get with the OBDLink LX
    Also, I tested my adapter with ELM327 Identifier and it's confirmed to be v1.4 which is the minimum needed for Carista advanced features to work. Does the OBDLink LX show v1.4 or higher when tested? ELM327 Identifier - Apps on Google Play
