Suggested work during head gasket fix
Discussion in 'Gen 3 Prius Technical Discussion' started by Frontporch, Nov 11, 2025.
  1. Frontporch
    Frontporch Active Member
    547
    127
    Nj
    It’s compelling if they are a direct swap
  2. Frontporch
    547
    127
    Nj
    I took advantage of Toyota’s 25% off and ordered a head gasket kit,head bolts/washers and a thermostat. Thanks for all the suggestions. Will look into a “repair” this winter
  3. JC91006
    16,930
    8,640
    Well if the car is running fine without any issues, it may be better to do it in the spring. Why do you want to work on a car in near freezing temperature? it's not even broken
  4. Frontporch
    547
    127
    Nj
    I guess it’s just prep time now. Clean the garage, find a good weekend and get it done. It might actually wait till spring but I will post here if it get it done
  5. Mendel Leisk
    42,242
    It was maybe +4C this morning, which is a bit of a drop over the last few days. Even that felt like I'd exceeded my threshold for cold tolerance: I'm doing some tidying/rearranging in the garage, and was starting to feel it this morning. One or two decent heaters helps, electrical is safer than propane for sure, but may kick breakers if you're using other heavy electrical loads, say a table saw.
