Suggestions for all season tires
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by edh53, Aug 14, 2012.
  1. edh53
    edh53 Junior Member
    ohio
    Thanks for the tips everyone; am now working on finding the Nokian WRg2 locally. ALthough I run snows, sometimes I get snow before and after I have them in place. Snow where I live can hit from before thanksgiving through April. Also, my current Nokia Hakkapallettas (sp), which are great snow tires BTW, are a bit worn now, and if the WRg2's are as strong in the snow as I have been reading here and elsewhere, I may just stick with those this year.
  2. jdenenberg
    jdenenberg EE Professor
    3,941
    1,940
    Trumbull, CT
    2020 Prius
    LE AWD-e
    H,
    Attached is my carefully analyzed MPG data comparing the OE integrity, Michelin MXV4+ (no longer available), Nokian WR, and two sets of Nokian WRg2 tires on my 2004 Prius. Note that all 4 replacement tires got better MPG than the Integrity tires at 42/40 PSI.
    Jeff
  3. edh53
    edh53 Junior Member
    ohio
    Jeff--thank you for the detailed info and my apologies for the dealyed response. Bought the WRG2's and like them veyr much so far; will be interested in how they handle snow. Have noticed a 5-8% decrease in mileage with them and am wondering what pressures you run in yours (I am at 36F/R now). Thanks.
    Ed H
  4. edh53
    edh53 Junior Member
    ohio
    (please ignore this space, accidentally submitted my posting twice)
  5. jdenenberg
    3,941
    1,940
    Trumbull, CT
    2020 Prius
    LE AWD-e
    I run my Nokians at 42f/40r as I have all tires on my Prius. The Nokians are rated safe to 51 psi cold air pressure. Note that all new tires will get an apparently lower MPG than worn tires as they have a larger diameter till worn down. This accounts for a misreading of MPG by about 0.5/24 or 2%. The other factor to look at is that not all tires have the same revolutions/mile even if they are the same size and this also impacts your MPG measurements.
    Just an additional note. The Nokian WRg2 tires come in three varieties: T-rated, H-rated and Run-flat. I buy h-rated as they are stronger tires. The run-flat versions of ANY tires will get very poor MPG.
    JeffD
  6. edh53
    edh53 Junior Member
    ohio
    Thanks Jeff, I will run at the higher pressure and see how that feels. I went with the 195/60's, which run 858 revolutions per mile vs the 65 profile, which runs 851, so that is also a factor in my lower mileage.
  7. Mendel Leisk
    41,223
    A little late in the discussion:
    With our previous second gen Civic Hybrid we were alternating between Bridgestone Ecopia EP20 (3 season tire) and Nokian WRG2 (winter tire, on separate steel rims). There was a definite downturn in mpg with the WRG2. Obviously winter mileage suffers for multiple reasons, but transitioning from the last EP20 tank to first WRG2 tank there was a definite drop.
    Just seat-of-pants I'd say 5~10 percent. Our son still has the car, and when I start reminding him about it being snow tire time, he wants to delay install, citing poorer mileage.
    They're a softer rubber compound, fairly agressive tread, comes with the territory. A good, sure-footed tire though.
  8. jdenenberg
    3,941
    1,940
    Trumbull, CT
    2020 Prius
    LE AWD-e
    Mendel,
    Were both tires (Wrg2 and EP20) the same size? You have to correct for the revolutions/mile of each tire to compare them and that spec changes as the tires wear. Revs/mile is even different for the same size (eg: 195/65HR15) tires but different models/brands.
    JeffD
  9. Mendel Leisk
    41,223
    Sorry, meant to mention and forgot: yes, they were both 195/65R15. The EP20 were on the OEM aluminum (pizza plate) rims, vs the WRG2 on steel rims. So marginally more aerodynamic.
    Something I noticed: if I was in our garage, wanting to roll the car out into the driveway without startup, in Neutral: with the EP20 just releasing the parking brake would usually get the car rolling, with our slightly sloping slab. With the WRG2 you needed to put a put on the floor and push (a la Flintstones ;)).
    I'd say the WRG2 came closest to matching the EP20 on the highway, sustained higher speed runs. In stop-and-go slow speed not so good. It seemed like they had increased "inertia", reluctance for that intial getting going.
  10. jdenenberg
    3,941
    1,940
    Trumbull, CT
    2020 Prius
    LE AWD-e
    Mendel,
    WRg2 (new 195/65R15) revs/mile = 831 - From Nokian brochure
    EP20 (new 195/65R15) revs/mile = 833 - From TireRack
    So when new MPG overstates the EP20 MPG by only 0.25% vs the WRg2 which is only a small amount.
    The difference in MPG due to more revs/mile at tread life end is about 2% (0.5 inches/25inches) which is a noticeable difference.
    One other factor, The Nokians (T or H-rated, I only buy H-rated tires for safety) have a sidewall PSI rating of 51, whereas the EP20 (S-rated) sidewall rating is 44 psi so you should inflate the Nokians to a little higher pressure to make the comparison. It does make a difference.
    JeffD
  11. clifford
    clifford Member
    156
    Just bought my second set of cooper cs4 touring tires, T rated, 80k. Very quiet and I obviously been pleased with the traction in Illinois snow. Oh yes 85. per tire plus the usual stuff and my place has lifetime spin balance and tire rotation! I did consider the Defender though but it was not worth the extra 200. and the gamble that the tire would not be as quiet.
  12. F8L
    19,011
    4,083
    50
    Grass Valley, CA.
    The only problem with the CS4 is they are not very fuel efficient.
