Suggestions needed regarding engine installation
Discussion in 'Gen 3 Prius Technical Discussion' started by donzoh1, Oct 24, 2019.
  1. donzoh1
    donzoh1 Active Member
    450
    153
    Lenexa, KS
    I removed a complete engine/transaxle assembly from a junkyard Prius. I believe it is a good power train. The Prius I am using it for has a broken engine block but good power train otherwise. I am debating whether to swap entire power trains or to remove and replace the engine only.
    On a related question, I was trying to separate the new engine. I have removed all eight bolts but the engine block does not want to be separated from the rest of the drive train. Any hints here are also appreciated.
  2. Mendel Leisk
    42,368
    Look around the underside seam between engine and transaxle, there's a little recess: tap a small chisel in there.
    Learned this vicariously from watching @Ragingfit videos, pinned in Prius v accessory forum.
    SFO likes this.
  3. donzoh1
    450
    153
    Lenexa, KS
    I will give that a try. Also, I was considering replacing the bolts and then backing them out a half turn or so, then tapping on the bolt heads. I'm sure this would work but would also need to tap uniformly around the circle to gradually separate consistently. The seam is so tight it almost has disappeared, due to what I'm sure is normal oxidation or weathering.
  4. PriusCamper
    PriusCamper Senior Member
    13,472
    5,439
    Pacific Northwest, USA
    In the interest of knowing the health of your extra transaxle fo rthe purposes of resale, I'd replace the engine with it's transaxle... Risk is you might have to swap out the transaxle with your old one at some point, but if not you can sell your original transaxle as something you know is in good working condition, which means getting more money for it and less worry about screwing the person buying it.
  5. Mendel Leisk
    42,368
    What's the miles on the donor engine/transaxle*, and on your car?
    * If you have that info
  6. donzoh1
    450
    153
    Lenexa, KS
    my car is 135K and it has the complete original power train. donor car has 100K although so that's the max on that whole power train. i assume that's all original. donor car appeared to be broken into with hybrid battery stolen? donor is 2010 while existing is 2013.
  7. donzoh1
    450
    153
    Lenexa, KS
    i turned the donor motor thru 2 revolutions manually and the compression seemed good. but, that was not an actual compression test with a tool. that doesn't really help though since it doesn't say anything about the other power train components. my guess is that the power trains are both good except for the existing broken engine block. donor power train is about 30 percent newer by mileage but 2 years older.
  8. Ragingfit
    Ragingfit Active Member
    189
    249
    Aurora, IL
    There are 9 bolts.
    Raytheeagle, SFO and Mendel Leisk like this.
  9. Mendel Leisk
    42,368
    Who says we don't have fun here... :ROFLMAO:
  10. donzoh1
    450
    153
    Lenexa, KS
    can i pull the complete drivetrain from the top? i removed the donor drivetrain by dropping the subframe and removing the radiator, etc from the front end.
  11. Landon51
    Landon51 Member
    190
    63
    US
    i read that and immediately thought, "I saw three lights!"
