Suitable substitutes for the Toyota ATF-WS transmission or transaxle fluid?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Rocketboy235, Aug 27, 2017.
  1. edthefox5
    edthefox5 Senior Member
    10,096
    4,833
    Clearwater, Florida
    I haven't seen a negative post about that either.The G2 trans is a bullet proof trans. Engineering marvel really. Only thing it doesn't like is steep hills on a bad hybrid battery..
  2. edthefox5
    10,096
    4,833
    Clearwater, Florida
    Yeah Chip your done on that fluid changes. It will look nice and red from here on out so don't bother on any more changes. . This Trans is very very easy on fluid after the initial break out fluid is removed. Its very very easy on fluid like Redline as its a superior lubricant. No wear.
    After my third change with 50,000 miles on it it looked brand new.
  3. The Critic
    The Critic Resident Critic
    3,193
    2,333
    CA
    iPhone ? Pro
    edthefox5 and Raytheeagle like this.
  4. Raytheeagle
    Raytheeagle Senior Member
    11,265
    15,520
    Bay Area, California
    2019 Prius Prime
    But on your Prius:whistle:?
    The Critic and Mendel Leisk like this.
  5. capolihu
    capolihu Member
    101
    76
    Mont
    How is you MANNOL oil goes? I am also considering buying it, but got second thoughts seeing the price compared to other brands..
  6. TheChip
    TheChip Senior Member
    388
    1,210
    Misissippi
    Pretty much what I figured. I need to send a sample out for analysis but I'm not too concerned with it. The last analysis showed very minimal degradation. I do a lot of autocross and forced charging so I tend to change my oil and other fluids more often than I need to just to be extra safe. I know it's a bit of a wast of money but to me the peace of mind is worth it.
    edthefox5 and Tim Jones like this.
  7. Fred_H
    Fred_H Misoversimplifier
    558
    482
    28
    Germany
    Updated summary of alternative ATFs used by people in this thread:
    Column 1 Column 2 Column 3 Column 4
    0 Member Name ATF Brand Type Total Distance with Alternative Brand ATF
    1 danlatu Valvoline MaxLife 76000 mi. (2005 Prius 129k~205k)
    2 danlatu Valvoline MaxLife 57000 mi. (2010 Prius 60k~117k)
    3 danlatu Valvoline MaxLife 8000 mi. (2011 Prius 297k~305k)
    4 Fred_H Ravenol T-WS Lifetime 153000 mi. (2007 Prius 157k-310k)
    5 edthefox5 Redline D6 150000 mi.
    6 tvpierce Aisin WS ?
    7 TheChip Redline D6 80000 mi.
    8 4md Yacco ATF X FE ?
    9 Simtronic Millers Millermatic fully synthetic 50000 mi. + ?
    10 stanny101 Redline D6 ?
    11 mjoo Redline D6 8000 mi.
    12 @douglasjre and friends Valvoline maxlife 300000 mi.
    13 Tim Jones Wallvoline Supertechmax 16000 mi. (2013 Prius v)
    14 nssdiver Amsoil FE SS 230000 mi. (2007 Prius 100k-180k-250k-330k)
    15 nssdiver Amsoil Std ATF .…. mi. (2007 Prius 330k-.....)
    16 @The Critic Idemitsu TLS-LV ?
    SFO and kerbear54 like this.
  8. roccostud
    roccostud Junior Member
    Seattle
    the fluid is non conductive. the windings are in fluid that is how it gets rid of heat and lubricates the bearings.
  9. The Critic
    3,193
    2,333
    CA
    douglasjre likes this.
  10. ASRDogman
    ASRDogman Senior Member
    7,565
    3,903
    I don't understand WHY you would want to use anything except the Toyota fluid?
    It is the same price, or in some cases, it cost less.
    I just bought 2 gallons for $20.24 each gallon....
  11. jzchen
    jzchen Newbie!
    3,316
    1,021
    Arcadia, CA
    While I respect the engineering that went into developing WS, it’s quite old now and newer/better formulas are signs of progress.
    Just like I believe the Mobil 1 Annual Protection I use is a better oil than Toyota oil.
    Tim Jones likes this.
  12. douglasjre
    douglasjre Senior Member
    2,177
    717
    Null, NL
    Isn't LV merely fully synthetic where WS isn't?
  13. jzchen
    jzchen Newbie!
    3,316
    1,021
    Arcadia, CA
    I know LV stands for Low Viscosity. I do not know the viscometrics of the two beyond that...
  14. ASRDogman
    7,565
    3,903
    I understand that. But since the system was designed to use WS, doesn't mean it would make it better for it.
    It certainly won't hurt it. :)
    I also use Mobil 1 or Castrol oil. Both are good. My van called for standard oil, but it ran better, and longer
    with the synthetic.
  15. Aaron Vitolins
    Aaron Vitolins Senior Member
    1,612
    1,144
    Franklin TN
    I use Maxlife full synthetic in all the Ford and Toyota/Lexus hybrids I own and maintain for friends and family. It’s $17, fully synthetic, and I don’t have to drive 40 mins to a Toyota dealer. I’ve been using maxlife for years with no issues.
  16. Mendel Leisk
    41,386
    $17 a quart??
    Considering the dire consequence warning in the Owner's Manual, I'll stick with Toyota ATF WS. Something else "may" be ok, but I'm not bright enough to second guess Toyota.
    jerrymildred and ASRDogman like this.
  17. Mendel Leisk
    41,386
    It's a little absurd to say some alternative is "newer", or "synthetic". How about "does it meet spec"? And the spec is "is it Toyota ATF WS".
    Toyota doesn't pussy foot around with this one. Motor oil, no problem. Coolant, sure if it meets this that and the other. But the transaxle fluid, they're firm: just use our stuff, or risk damage.
    Which brings the libertarians out of the woodwork, lol.
    ASRDogman likes this.
  18. Aaron Vitolins
    1,612
    1,144
    Franklin TN
    $17 for a gallon
    douglasjre and Mendel Leisk like this.
  19. Aaron Vitolins
    1,612
    1,144
    Franklin TN
    You know WS is nothing special, and was used on many other Toyota models for 20+ years. It works great, but so do other fluids.
  20. Grit
    Grit Senior Member
    6,573
    4,226
    Wilkes Land
    I know 2 fellers in here use amsoil signature series in theirs. $13.30 per quart and that’s excludes shipping fees. One of them changes every oil 3,000 miles :eek:
