Suitable substitutes for the Toyota ATF-WS transmission or transaxle fluid?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Rocketboy235, Aug 27, 2017.
  1. Simtronic
    Simtronic Active Member
    290
    116
    Surrey, UK
    2017 Prius PHV
    Business Ed. Plus
    300,000 miles without WS and the car is as good as ever another 40,000 in my plug in now too and there is such a thing as exceeds specifications I would never put an unknown or dubious quality oil in.
  2. Mendel Leisk
    41,425
    I'm changing every 6 months (months component for Canada 3rd gen). Km's is around 3000. Still, my oil costs $2.80 (CDN) per liter, Toyota 0W20. To be fair, it was $4.95 per liter. Then they got a new invoice system, and I think they just want to be shut of me, it literally takes longer to do the invoice than to get the oil, so they just rubber stamp the amount I paid a few times back, for a lesser amount. I think. I don't think they even know.
  3. douglasjre
    douglasjre Senior Member
    2,179
    718
    Null, NL
    Maxlife LV says it supercedes WS. What does this mean?
  4. edthefox5
    edthefox5 Senior Member
    10,096
    4,833
    Clearwater, Florida
  5. Simtronic
    290
    116
    Surrey, UK
    2017 Prius PHV
    Business Ed. Plus
    To superceed WS it must at least meet the requirements of WS I suspect it exceeds the specifications.
  6. Mendel Leisk
    41,425
    No comment...
    m.wynn, Raytheeagle and ASRDogman like this.
  7. Raytheeagle
    Raytheeagle Senior Member
    11,265
    15,520
    Bay Area, California
    2019 Prius Prime
    The red cape is waving:p.
    No time to throw in the towel;).
    Go get 'em(y).
    m.wynn and Mendel Leisk like this.
  8. Simtronic
    290
    116
    Surrey, UK
    2017 Prius PHV
    Business Ed. Plus
    We are chatting about the transmission oil not engine oil but Toyota engine oil changing at 3000kms seems overkill, Toyota make a very good engine oil
  9. Grit
    Grit Senior Member
    6,573
    4,226
    Wilkes Land
    :ROFLMAO::ROFLMAO::ROFLMAO::ROFLMAO::ROFLMAO::ROFLMAO::ROFLMAO::ROFLMAO:
  10. Umar Ali
    Umar Ali Member
    274
    91
    Dallas, TX
    i have done about 3 changes in almost 170k miles and i only used this oil for transmission since it is not regular toyota transmission, first of all it is cvt and secondly it is ecvt thats why i didnt put regular toyota ATF-WS or any CVT oil. this container was freaking expensive, i think it was around $80 if i remember correctly.
  11. Elektroingenieur
    2,515
    3,283
    Three Touring
    Toyota has several types of automatic transmission fluid, and they’re not interchangeable. Toyota Genuine CVT Fluid FE, as in your photo, is meant for belt-type CVTs, such as the K120 and K313 transaxles used on certain Corolla models. For Prius cars since model year 2004, Toyota specifies ATF WS; earlier models used ATF T-IV.
  12. Umar Ali
    Umar Ali Member
    274
    91
    Dallas, TX
    well, then probably stealership has been giving me wrong type of fluid. (n)
    first time i bought the guy swore this is the right one with the explanation i gave you that since prius is eCVT thats why this one goes in
  13. Mendel Leisk
    41,425
    Yeah up here there's one liter bottles, say ATF-WS.
  14. Umar Ali
    Umar Ali Member
    274
    91
    Dallas, TX
    reason why toyota recommends not to change the transmission oil over the life of car is because the oil is almost mainly refined mineral oil and has high viscosity index @ 100F very low natural por point of -25F and also with a harmless chemical reaction removes oxygen leaving inert gas nitrogen in sealed transmission. that is the reason it should last for the life of car.
    having said that i would still replace it every 60k miles for peace of mind :)
  15. Grit
    Grit Senior Member
    6,573
    4,226
    Wilkes Land
    You mean the oil will only last 100,000 miles.
    Umar Ali likes this.
  16. roccostud
    roccostud Junior Member
    Seattle
    I don't know if I can post links since I'm a fairly new member. but his deep dive on a gen 3 transmission he does specifically talk about cooling the stator of mg1 by the way of transmission oil at about the 45-minute mark. both mg1 mg2 are not sealed compartments within the transmission. I may have been wrong saying they are submerged in oil but they do come in contact with it. I may have said this because I work with submersible pumps that have the stator and rotor submerged in oil. and assumed that's the way it worked after watching the deep dive video he doesn't specifically say that they are sealed from oil.
  17. Peter123
    Peter123 Active Member
    131
    128
    Toyota WS is cheap enough and easy enough to change that I just do that.
    The problem is that I need to get a round tuit.
    ASRDogman likes this.
  18. qmanqman
    qmanqman Active Member
    428
    146
    CO
    From who?
  19. Mendel Leisk
    41,425
    1. Around here my dealership parts department sells it for $9.14 (CDN) per liter. That's currently around $6.05 USD per US quart. They have the fill/drain bolt washers too, for around $3 CDN apiece, which is kinda larcenous...
    Don't know why the heck there's a "1. " at the beginning of my post, can't delete it.
    Raytheeagle likes this.
  20. Raytheeagle
    11,265
    15,520
    2019 Prius Prime
    Maybe the AI thinks you have more than one point:p.
