Suitable substitutes for the Toyota ATF-WS transmission or transaxle fluid?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Rocketboy235, Aug 27, 2017.
  1. OlympicPNW
    OlympicPNW New Member
    Sequim, Washington
    Hello All:
    I just joined PriusChat but have read numerous forums on the site for years which helped me with my 2017 Prius’s maintenance program. There seems to be a lively discussion regarding the use of other sourced WS-rated ATFs in the Prius CVT other than the genuine Toyota WS or Toyota’s CVT FE.
    A quick check for other sources of WS-like fluids revealed that Redline has a fluid (D6 ATF) that has been successfully used in Prius CVTs for years.
    And, a call today to Valvoline directed me to a recent update from Valvoline regarding their recommendations for various vehicles.
    Information about Valvoline’s ATF on the website states the following: “Maxlife Multi-Vehicle transmission fluid is recommended for use in most belt and chain-driven continuously variable transmissions* and will not void new car warranties."
    This source page references CVTs on page 4 - it states the Maxlife ATF works for both Toyota’s CVT FE and CVT TC. It’s my understanding that Toyota now recommends their branded CVT FE for the 2017 Prius.
    NOTE: If you research, a photo of the Toyota’s CVT FE 4 liter can (08886-02505) states that the product is manufactured in Japan, but Exxon Mobil is also listed on the side of the 4 liter can. Interesting.
    So, what to use? Use Toyota’s branded ATF if that makes you happy. I’ve used both Castrol’s WS-rated ATF once (couldn’t find the Valvoline ATF at Wally Mart) and used Valvoline’s Maxlife Multi-vehicle ATF three times in my 2017 Prius without any issues. On my next fluid change, I’ll think I’ll try Redline’s D6 just for fun.
    NOTE: I’ve changed the Prius’s CVT fluid approximately every 25,000 miles (or about every 2 to 3 years) with the first change at about 5,000 miles. I changed it more often than most because my Prius was formerly driven in the 100+ degree summer heat in Texas.
    NOTE: my 2017 has 96,000 miles to date.
    Do your own research and use what makes you happy. And, no offenses intended to anyone regarding their Prius CVT fluid recommendations.
    OlympicPNW
  2. ASRDogman
    ASRDogman Senior Member
    7,862
    4,004
    Since you have a 4th Generation Prius, it would probably be best to go to that forum
    because you get better information for your Prius.
    There is NO point in getting aftermarket transmission fluid. The cost difference is only
    a dollar or two. So why risk using something that is supposed to be compatible when you
    can get the correct fluid designed for you vehicle?
  3. OlympicPNW
    Sequim, Washington
    A dollar or two? Really.
    I was quoted $18.95/quart for Toyota’s WS at a Toyota Dealership in Washington this week. The CVT requires 3.8 quarts. So, that’s $75.80 for 4 quarts; Wally Mart has a gallon of Valvoline Maxlife ATF for $25.92.
    If my ciphering is correct, the Toyota brand costs $49.88 more for a CVT change not including state and local taxes.
    And, the maintenance information on 3rd Generation Priuses is also beneficial for those than own 4th Gens as well.
    Have a Good Day.
    johnHRP likes this.
  4. Mendel Leisk
    41,969
    How much is a toasted transaxle going to cost? Probably reduce the car to scrap value. Not saying it's going to happen, but Toyota directly warns against using anything else, saying it may damage the transaxle. In the Owner's Manual.
  5. OlympicPNW
    Sequim, Washington
    Mendel,
    Agree to disagree.
    It seems several posters seem to believe that Toyota’s WS is more precious than Holy Water and cannot be replicated without an Act of God. That’s not only incorrect but also ludicrous.
    Many reputable companies including Valvoline (wholly owned by Saudi Aramco), Redline, Amsoil, Castrol (wholly owned by the UK energy giant, BP), and other aftermarket producers of ATF-related products will state that they often have specific products that are formulated to meet or exceed Toyota’s WS fluid specifications.
    That also includes the Japanese company, Aisin, because that company has the only actual WS branded fluid other than Toyota. As you are likely aware, Aisin manufactures Toyota’s Prius CVT along with most of Toyota’s traditional automatic transmissions.
    So, are all of these well-known companies, including Aisin and a wholly-owned subsidiary of BP and a wholly-owned subsidiary of Saudi Aramco, falsely stating that their products meet or exceed Toyota’s WS specifications? Of course not. That’s not only highly prejudicial but also highly inflammatory to insinuate that their products don’t meet Toyota’s WS specifications when they state that their products are compliant.
    Why is this even an issue, you may ask? Well, in the U.S., we have the Moss-Magnuson Act of 1975, and U.S. residents have certain rights including the following:
    "Warrantors (in this case: Toyota) cannot require that only branded parts be used in order to retain the warranty.”
    According to my Prius’s Warranty and Maintenance Guide, the powertrain is warranted for 60 months or 60,000 miles whichever comes first.
    On page 729 of the 2017 Owner’s Manual, Toyota seems to be walking a very narrow line when the company states:
    “Using transmission fluid other than Toyota Genuine ATF WS may cause deterioration in shift quality, locking up of your transmission accompanied by vibration, and ultimately damage the transmission of your vehicle.”
    Wow, that’s a powerful and worrisome statement. That statement resonates almost like a requirement to use Toyota's WS or is it merely a recommendation in disguise? Or, is it a scare tactic by a auto manufacturer or possibly just a friendly warning?
    So, Toyota’s statements regarding the use of Toyota’s WS in your Prius should be construed as recommendations and not requirements; otherwise, they would need to provide their WS fluids free to all Prius owners according to the Moss-Magnuson Act. It would be cost prohibitive for Toyota to provide their proprietary WS fluid to every consumer with a Prius for the life of their vehicle. Therefore, we see the rise of CVT fluids that meet or exceed Toyota’s WS fluid specifications because Toyota’s WS is very pricey in most areas.
    The Moss-Magnuson Act encourages product competition by allowing consumers to use various aftermarket part sources, including those Brave Souls using non-Toyota WS fluids that meet or exceed Toyota’s WS specifications, which can be readily utilized without voiding Toyota’s manufacturer warranty.
    So, any Prius owner can use a non-Toyota fluid that meets Toyota’s WS fluid requirements and Toyota can’t say Bupkis during the warranty period. After the warranty period, Toyota shouldn’t care.
    Have a Good Day.
  6. ASRDogman
    7,862
    4,004
    Wow, you're getting ripped... from both places. Twice as high from Toyota....
    It's not like your changing that fluid every few thousand miles.
    Check ebay, amazon, it is less there....
    And maintenance is not necessarily the same....
  7. Mendel Leisk
    41,969
    I checked recently, when this ATF WS price topic came up. Can’t recall exactly, but I believe they quoted eleven something Canadian, per US quart. From a nearby dealership.
  8. ASRDogman
    7,862
    4,004
    blah blah blah..... o_Oo_Oo_Oo_O
    So defensive.....
    Use whatever you want.. use wd40, who cares?
  9. OlympicPNW
    Sequim, Washington
    ASRDOGMAN:
    How is it remotely defensive to state facts?
    Here’s what you stated in a previous post: "There is NO point in getting aftermarket transmission fluid. The cost difference is only
    a dollar or two.” Really. Is that a dollar or two difference per quart or a dollar or two difference for a pack of 4 quarts? Please clarify.
    As stated, WalMart sells Valvoline’s Maxlife ATF which meets Toyota’s WS specifications for $25.92 for a gallon. That’s $6.48 per quart not including state and local taxes. What sources have you have personally verified sell Toyota’s WS fluid for anything close to $6.48 per quart? Can you actually direct me to a source for Toyota’s WS fluid “…only a dollar or two” higher than WalMart’s calculated per quart price?
    And, I really enjoyed your flippant commentary: “Use whatever you want..use WD40, who cares?” That statement is particularly insightful into your internal deliberations and processes which result in not only thoughtful but also caring responses.
    Wow, this is fun. I should have joined this site years ago.
    Have a Good Day
  10. ASRDogman
    7,862
    4,004
    blah blah blah blah blah blah blah blah blah blah blah blah blah blah blah blah blah blah blah blah blah blah blah blah blah blah blah blah blah blah blah blah blah blah blah blah blah blah blah
    You should get a life...
  11. OlympicPNW
    Sequim, Washington
    It’s one thing to disagree but it shouldn’t be in a disrespectful way. Do you understand that meaningful concept or do you need me to explain it to you?
    You should really think about your comments and how they convey insights into not only your intelligence but also your empathy for others.
    Best to you as well.
  12. Mendel Leisk
    41,969
    According to who? Valvoline? I doubt Toyota’s vetted it.
    #492 Mendel Leisk, Nov 28, 2025
  13. johnHRP
    johnHRP Active Member
    645
    189
    KA, DE
    Excel
    I have never heard any problems using Valvoline Maxlife Dex/Merc as long as it is within the written spec compatibility.
    GM and Ford certified ATF for their spec and now they only certify Dexron VI or Mercon LV or newer, which is similar to Toyota WS. Many even believe that Dexron VI standard is actually more stringent than WS.
    GM does not certify Dexron IIIH, similar to Toyota T-IV, but replaced by Dexron VI although it has lower viscosity, Dexron VI still give a better protection than older generation ATF with more modern additives.
    Besides that, Dealership cannot proof what fluid is in the transmission.
    Newer Dexron VI is not the same as old dexron VI, the same applies to Valvoline Maxlife Dex/Merc too. Pre 2008, Valvoline Maxlife was only for Dexron IIIH, but after 2010, I remember that it was compatible with Dexron VI and similar lower viscosity for Nissan, Honda, Toyota WS, etc.
    #493 johnHRP, Nov 29, 2025
