Summary of problems reported on Prius 2010
Discussion in 'Gen 3 Prius Main Forum' started by CivicQc, Aug 15, 2009.
  1. tumbleweed
    tumbleweed Senior Member
    4,067
    692
    Eastern Oregon
    Re: UN Regulations?
    Toyota sells cars all over the world and they do need to comply, I suspect it's really not a U.S. issue.
  2. clueless_buyer
    clueless_buyer New Member
    houston
    i was at the dealers today, and he could have been trying to talk me out of getting the solar roof. but he said that the roof the way that it is installed after 4-6 years, the rubbers become loose and you may hear the roof. the roof design is the same as something in the scion. has anyone heard anything about this? i plan on driving my car until it dies, so obviously, if this was true, i wouldnt want a jiggling roof after 5 years.
  3. tumbleweed
    4,067
    692
    Eastern Oregon
    I think he has trouble getting cars with the solar roof and he's trying to tell you it's no good so he can sell you a car without one. Typical car dealer stuff. Go to another dealer if he tries that there is no way to tell what else he will do.
    Besides that why would he care if it becomes loose after 4-6 years? He's the one that would get paid to fix it.
  4. TheSpoils
    TheSpoils Member
    304
    49
    New Jersey
    I noticed that too and thought that a tire or tires were out of balance. Turns out it is caused by air turbulence in the back hatch. Try doing it with both back windows half way. It's even worse.
  5. jburns
    jburns Senior Senior Member
    829
    111
    Archdale, NC
    I did it once. I corrected it by not doing it again.
    Seriously this is characteristic of every hatchback car I have owned. Kind of gives you the feeling of standing right in front of the biggest bass speaker at a heavy metal concert without the sound.:rockon:
  6. CraigCSJ
    CraigCSJ Active Member
    287
    144
    San Bernardino, CA
    Possible fix: My 2004 had the same problem, and it disappeared when I turned my rearview mirror 180 degrees. I don't know if the 2010 will do that, but in my 2004 it does, and the rear view improves as well as the auto-dimming feature.
  7. Jon S
    Jon S Member
    185
    84
    The Aloha State
    Linky to thread here ...
  8. Buckeye
    Buckeye New Member
    16
    This air pressure variance occurs in just about all vehicles when a single window is opened while traveling at speed limit pace. Similar to blowing across the top of a coke bottle and getting the fog horn sound. It is often reduced or eliminated when another window (opposite location) is even cracked a bit. Varies with different car models. The vibration sound can be a head shaker.
  9. TheSpoils
    TheSpoils Member
    304
    49
    New Jersey
    With both rear windows open it creates an almost sub sonic impulse. The rear view mirror starts distorting from the vibrations, almost like a subwoofer.
  10. Dark_matter_doesn't
    Dark_matter_doesn't Prius Tinkerer
    692
    151
    Seattle, WA
    Coincidently, the Car Talk guys answered this question from someone on the air within the last two weeks. You might try their website to hear the actual discussion. Their explanation was kind of lame, but the bottom line is that ALL four-door cars do this, some worse than others.
    Lemons into lemonade: If you have the sunroof, try opening the sunroof when only a back window is open. The oscillation will stop, and I've experienced a wonderful swirl of air thru the vehicle that can be very nice on a hot day. This happened in a '92 Integra and some other vehicles - haven't tried it on my Prius. The direction of the swirl depends on which side rear window is opened.
  11. cpatch
    cpatch New Member
    383
    81
    Carlsbad, CA
    I think it has to do with the spoiler blocking the headlights of the car behind you.
  12. windstrings
    windstrings Certified Prius Breeder
    6,280
    378
    Central Texas
    I like your thinking!... suspicious with common sense... I think your spot on! :rockon:
    Anyway.... Once the dust settles and if Toyota decides to do some software updates.... how will we know about it and how will it be done.
    A service bulletin?
  13. darkleafar
    darkleafar Member
    232
    Houston TX
    should this be added?
    Yahoo!
  14. tumbleweed
    4,067
    692
    Eastern Oregon
    Good question, but I would say no. The floor mat on the driver's side already has two hooks that prevent it from moving forward. I would say it's up to the driver to make sure the mats are properly secured before driving the car.
    There is a thread on this crash: http://priuschat.com/forums/gen-iii-2010-prius-main-forum/68851-gen-iii-prius-turn-off.html
    No one knows for sure if floor mats had anything to do with the crash or not. But regardless of the initial cause of the "stuck throttle" the real question in my mind is why didn't the driver put it in neutral or turn it off? and failing to do that why didn't he apply the brakes firmly and decisively to stop the car instead of applying them less forcefully to try (apparently) to slow down and letting them burnout before the car stopped?
    A terrible tragedy to be sure but there are to many unanswered questions to blame the car or the car company.
  15. Mitchellsprius
    Mitchellsprius New Member
    91
    monterey
    Lets put the interior front rattle down so maybe we can find a fix.
  16. CivicQc
    CivicQc The world needs more prius
    233
    99
    Planet Carbon
    Thank you both, darkleafar and tumbleweed. Indeed that is a terrible tragedy. However, as tumbleweed said:
    I suggest not to add it to the list until the investigation clears this up.
  17. CivicQc
    233
    99
    Planet Carbon
    The number of reported problems has stabilized - that's good! There is a good chance we might have a good proportion of the most common ones in this list, and one of them has already been solved by Toyota.
    The list has been referred to in a few places on the web. Including the Insight site. As cwerdna pointed out in http://priuschat.com/forums/gen-iii...y-problems-list-doesnt-get-out-hand-spun.html, there is a risk the list gives the Prius a bad reputation. That is certainly not my intent, though. So I want to be careful in what we add.
    So I would need your advice on the following:
    1- As Mitchellsprius mentionned above, we could add the rattle problem to the list. It has indeed been reported by several members. However, as you all know, rattles are quite common in cars.
    2- In a recent thread (http://priuschat.com/forums/gen-iii...5365-can-barely-hear-turn-signal-clicker.html), members have observed that the turning signal is very quiet.
    I fear that adding those to the list might just contribute to the reputation aspect of the car, whilst not adding a significant contribution to the list. You might have a different opinion.
    Let me know you think -All opinions are welcome!
  18. Orf
    Orf New Member
    414
    Devonport, Tasmania
    I think it is more important to add the turning signal being too quiet than to try and preserve the reputation of the car.
    As for the rattle, unless the cause can be identified it shoud be left off the list because it is not a defined problem.
    If the Prius cannot stand up to a few comments then it is not worth having and we all know that it is worth having.
  19. ggood
    ggood Senior Member
    2,436
    517
    Houston, TX
    A rattle? be serious.
    I guess the turn signal is quiet, since I don't notice it. If it is, I count it as a good thing. Next up, someone will insist the lack of engine noise is a problem.
    I liked the idea of this thread, but this list is mainly showing there are no real problems. Several of these items are design issues, that most people would not consider a problem or that are inherent in the tech being used or the sunglasses being worn.
    Why is hill assist even on this list. The thread it points to doesn't show any problem at all. If you mash the pedal to the floor, you get the alert. It's doing what it is supposed to do. Once you learn that, you just don't do it again.
  20. jburns
    829
    111
    Archdale, NC
    I pretty much agree. For a new model the list is amazingly void of any remotely serious problems and most of the items could be considered nit-picking.
