Summary of proposed improvements for future versions of Prius
Discussion in 'Gen 3 Prius Main Forum' started by CivicQc, Jan 9, 2010.
  1. macmaster05
    macmaster05 Senor Member
    4,050
    730
    Some of you girls are within reason, but some of you are asking for gold with your car. Heated seats, lumbar, adj seats with memory, tachometer??? HAH! Does Holly Housewife even know how to read a tachometer? You will never see these things in a Prius. Not in your wildest fantasies ladies!!! Just buy a Lexus.
  2. macmaster05
    4,050
    730
    Hey Eoinstein you swipe your finger across the groove on the handle to lock it.
  3. CivicQc
    CivicQc The world needs more prius
    233
    99
    Planet Carbon
    A gauge, close to the instant fuel economy gauge, that provides the value of instant "electricity economy" - in kwh/km or some equivalent unit, when in EV or stealth mode.
  4. dbldbl
    dbldbl Junior Member
    34
    Midwest
    The "Auto" climate control needs to be Automatic EVERYTHING (as on Volvo, and other luxury cars). Set the temperature and Automatic features - and will automatically adjust heat and/or AC to maintain that temperature. (This will use more power, but is designed for ONLY when the engine is on.)
    Similarly, safety needs to include an indicator when the exterior temperature allows Black Ice to exist (about 36-26 F).
    Mentioned prior, the exterior temperature is of greater interest than the interior temperature and should be the larger of the 2 temps displayed (and should be on the steering wheel or HUD).
    Again, a nod to Volvo- the pass through on the folding seat that allows grabbing something in the "trunk" region or placement of a longer item (doesnt have to be cross country skis, e.g. lumber) without the entire seat down. And, like the Volvo, the passenger seat should be adjustable to be entirely down. (In the Volvo, the seat back can go forward sufficiently to be fully down.)
    And, I learned to hypermile from the Digital Read Out from my Volvo's engine (every 5 seconds). The display can change to instead demonstrate the immediate mpg, average mpg, average speed, exterior temperature, mileage range of the remaining fuel at current average mpg and ...
  5. Tideland Prius
    16,556
    It is fully automatic. It will adjust the fan speed, mode and turn on/off the A/C (if the A/C light is on) as needed. That same temperature will turn on the heater if the exterior temperature dips.
    The Prius had an "ice" indicator in the Gen 2 (it's called the snowflake symbol here on PriusChat). It was on the 2004-2005 models then ppl complained it was stupid and useless and for 2006, it was reduced to just a drop-down warning on the MFD when it dropped below 3°C (~36°F)
    I agree with the pass-thru. A 40/20/40 seat would be quite useful
    Scangauge covers that....
  6. pri-mordial
    pri-mordial Junior Member
    Uk Surrey
    I'm being lazy and haven't read the whole thread.
    Couple of bug-bears for me (aside from creaking plastics)
    1. Passenger-side mirror: it doesn't have the extended angle provided by the driver-side mirror (here in the UK), so I've been caught out a couple of times not realising a car is sitting in a blind spot. I usually set them out wide to stop that happening, but don't seem able to on this car. I know there are mirror attachments, but it shouldn't be necesary
    2. Style. I'm not too taken with the Prius' style. I think there's a new Merc out with a LOWER CD! And it DOESN'T look anything like a Prius! OK I guess it's probably got a 2m hood/bonnet, and costs a bit more. But it still says: I can look sleek AND sexy.
    3. OK, I know I said a couple. The metal feels like it's a product of amazing technical advance: the new 'spray-on' metal, just below the spray-on paint. I've never had an arm resting on the window-sill before where I can feel every note of the door speakers. Toyota/Lexus used to be famous for their solid feel.
  7. geeky teacher
    geeky teacher New Member
    393
    West Suburban Chicago
    I'd like a light or medium gray dashboard that doesn't heat up in the sun as much as the black dash.
  8. jmbrendel
    jmbrendel New Member
    West Michigan
    I drive a 2009 Prius and barely fit as it is. I'm not exceptionally tall (6'2") and already can't see the traffic light while sitting upright, because the roof blocks my view. I need to lean forward and/or hunch way down to be able to see a traffic light if I'm at the light ..................................... Anything that even SLIGHTLY lowers the front headroom will cause us to cross the next Prius off our list.
  9. Eoin
    Eoin Active Member
    593
    116
    Long Island
    Yes, it does feel tinny. I think this is due more to the need to save weight than being cheap. The materials used in cars now are so advanced that they can be made very thin and still last 15 years. I am not concerned about it.
    In my opinion, the gen3 Prius is perfect except for 2 things
    1. The FM radio is sub standard.
    2. The Satellite radio is unreliable, always cutting in and out.
    The brake feel is also not quite as smooth and quiet as the gen2. A lot of clicks and pumps sounds going every time you step on the brake. But they work fine.
    I will be happy to drive my Prius for the next 15 years.
  10. Philosophe
    Philosophe 2010 Prius owner
    437
    72
    Montréal, Québec (Canada)
    I assume you already lowered your driver seat? I'm 6'1" and also thought this was an issue, until I lowered the seat. My only complaint would be that the rear view mirror mask my view to the right, but I'm not sure there would be an easy solution to this.
  11. 3PriusMike
    3,100
    2,419
    Silicon Valley
    That was on the 2001-2003 as well. But it was a thermometer icon.
    But are you sure that's what it indicates? On my 2001 it would show up when the "engine" was cold (not cool) not the outside air temp. Here in CA I saw it many dozens of times per year even though it only drops below 36 rarely. And after a few minutes of driving it would turn off. My wife drives the 2004 most of the time, but the snowflake would also show up then go off after the engine warms up. Seems to have a lower setpoint on the 2004.
    3PriusMike
  12. Tideland Prius
    16,556
    You're talking about a completely different icon. The icon you're describing (the blue thermometer) just means that the coolant (i.e. engine) is cold. The same icon shows up on the Yaris. Basically, be gentle while that light is on to maximise engine life and fuel economy. It's a poor man's water temp (in vehicles that don't have a water temp gauge)
    The symbol I'm talking about is a yellow snowflake with a road symbol.
  13. CivicQc
    233
    99
    Planet Carbon
    Change the color of the vertical central portion of the side ventilation grids from silver to black. Under daylight conditions, they reflect on the windows, and show an annoying ghost image aligned with the side mirrors.
  14. Morfeas
    Morfeas Junior Member
    greece
    Add a drive mode with a preset MPG or L/km limit(adjustable)
  15. mitcheli
    mitcheli Junior Member
    39
    2018 Prius Prime
    A feature that I didn't see listed in the area of improvement that I was somewhat shocked my Prius wasn't capable of.
    Automatic headlights.
    My 8 year old camry could do it, but this highly technically advanced Prius still has a switch I have to flick. ;)
  16. 2k1Toaster
    6,035
    3,855
    Rocky Mountains
    Just leave them on. Once you power the car off and open the door, the lights will go out. Then when you start the car again, they will turn on automatically.
    They are not automatic in that no light when the car is on headlights are on and it is daylight, but good enough. A simple photoresistor and accompanying circuitry could accomplish that for a few dollars though.
  17. Airbalancer
    Airbalancer Active Member
    892
    73
    Cobourg, On, Canada
    Buy the Prius in Canada :D
  18. Tideland Prius
    16,556
    ^ What he said. The US is the only place that I know of that has AUTO-OFF rather than full automatic headlights. Then againm the US is the only country that has LKA...
  19. Airbalancer
    892
    73
    Cobourg, On, Canada
    A force field around the windshield
    Got another stone chip yesterday:(
    Had the windshield replaced May 27, so that was 14 day with a perfect windshield
    I think we got the first stonechip a week after we got the car
  20. joe1347
    joe1347 Active Member
    669
    44
    AZ
    2-door Coupe Version. A little bit of a styling tweek wouldn't hurt - but try not to make it look any worse.
    Short range plug-in with lighter weight Lithium batteries. How about a 2.5Kw-Hr plug in option since the 5Kw-Hr battery-pack is both too large, heavy and costly. Ideally, you can also keep the spare tire with a 2.5Kw-hr plug-in battery option.
    Can you get rid of the dorky 15" wheel covers and replace them with either better looking wheel covers or just get rid of wheel covers and go to an alloy wheel. The stock 17" alloy wheel looks great, how about a very similar 16" version and call it a day.
    Four wheel independent suspension to improve handling.
    I guess what I'm looking for is a more 'sports car' like Prius that also gets a little better mileage.
    Granted, I'm making the assumption that the addition of a small 2.5 kw-hr lithium plug in battery doesn't add too much weight and hence slow down the car by very much because the NiMH traction battery would also be converted to lithium technology which would save a good percentage of the weight added by the plug-in battery and with the smaller plug-in battery, less cooling and support electronics are required.
