Summary of proposed improvements for future versions of Prius
Discussion in 'Gen 3 Prius Main Forum' started by CivicQc, Jan 9, 2010.
  1. Britprius
    Britprius Senior Member
    5,194
    1,921
    Herefordshire England
    A fixed cruise control lever (one that does not vanish every time you turn the wheel) and then gets broken when you get out of the car and catch your knee on it.
  2. Tideland Prius
    16,556
    Sure about that? I hate the position of Mercedes' cruise control stalk. It's fixed like you described but sticks out like a sore thumb (or an after-thought)
  3. Troyroy
    Troyroy Member
    373
    30
    Troy, NY
    Anything we add here should be to make the Prius a better automobile.
    There seems to be a problem keeping the 12 Volt battery charged when left idle for a time. I have not experienced this, but others have. Why ????? Lets design it so that when the computer senses that the 12 V battery is low on power that it has the HV battery recharge it,as it now does normally....if the HV battery should get low...... lets have the ICE start and recharge the HV battery .......all on it's own. The parts are in place to accomplish this.....lets use them. !!!
    Make this a consumers choice !!!!!
  4. mainerinexile
    mainerinexile No longer in exile!
    403
    73
    Maine
    You can do this now. Just leave the car on in ready mode, in park, all the time. The batteries will charge.
  5. Tideland Prius
    16,556
    I don't think this was mentioned but it would be nice if the rear doors opened at a slightly wider angle.
    Rear passengers keep kicking the door panel.
  6. cycledrum
    cycledrum PSOCSOASP
    8,246
    1,202
    NorCal
    CivicQc, thanks so much for compiling this list. Here's one or two to add to the steering section of main list -
    1) Increase the steering wheel tilt range a little bit, especially in downward direction and a little more telescope to the driver.
    why? I always have to lift up a couple to four pumps on height adjuster since the wheel doesn't tilt down enough to me, but then my head gets closer to roof than I'd like. If I lean back an extra notch to compensate, then the steering wheel is tough to reach cause it needs more telescope range. I can get it to work, but it could be a little bit better.
  7. cycledrum
    cycledrum PSOCSOASP
    8,246
    1,202
    NorCal
    Make the driver's door armrest just about the same height as the center console armrest.
    why? I sit in quite a few new cars. Pretty much everyone of them has door and center console armrests fairly even height. gen3 Prius' is noticeably low. Yes, I took a yarkstick, level and small ruler to determine the door armrest is indeed about 3/4" lower than center console.
  8. Tideland Prius
    16,556
    The rear door armrests are too low and the front passenger is barely adequate for me (definitely designed for shorter people).
  9. joneswebb
    joneswebb New Member
    US
    A few adjustments in the rear seating should barely adapt for a more expansive space.
  10. CivicQc
    CivicQc The world needs more prius
    233
    99
    Planet Carbon
    When front wipers are on, rear wiper should wipe once when car is put to Reverse.
    (I drove a citroen recently, it had that feature, and I thought it was nice)
    Edit: Only when temperature is above 0 C, to avoid damaging the wiper motors when stuck in ice.
  11. Tideland Prius
    16,556
    Yeah my smart had that feature too.
  12. flyrevs
    flyrevs New Member
    Akron, Oh
    need larger aux. battery, the stock one is really small
  13. Turbobooster
    Turbobooster New Member
    Belgium
    Rear wheel drive or like on the Lexus RX450h front wheel drive + elektric motor that powers the rear wheels ?
  14. Turbobooster
    Belgium
    engine RPM-meter for the ICE , the new Lexus CT200h has this feature and displays RPM when the car is in Sports-mode .
  15. Turbobooster
    Belgium
    Lightweight Lithium batteries , the option to choose between normal frontseats and lightweight bucket seats .
    Alloy spare wheel .
  16. Turbobooster
    Belgium
    replace all halogen lamps by LED-lighting .
    ICE with elektronic activated supercharger in power mode
    Factory option off LPG-instalation
  17. skilbovia
    skilbovia Member
    400
    91
    Massachusetts
    How about a little gizmo that keeps the rear camera lens clean. Now accomplished by a rather large gizmo...me.
  18. civicdriver06
    civicdriver06 Active Member
    797
    324
    Germany
    Better scratchresistant and touchfriendly Interior
    Power folding mirrors ( you get them in Japan so why not in the US and Europe ? )
    An Indicator light or even better a notice in the MFD so one can see if the windshield washfluid container is empty or not ( every car at this price range has a warning so why not a Prius ? )
    Illumination of the rearview mirror controlls ( why allmost everthing is illuminated besides those beats me ! )
    More colorfull displays
    I hope you´ll get the HUD in the 2012 Facelift !
    Greetings from Germany
  19. Tideland Prius
    16,556
    The best one I've seen so far is on the Golf. The back up camera is hidden behind the logo and the logo pops up when the driver shifts into reverse, revealing the camera. it keeps the lens clean. Of course, that requires a motorized rear logo.
  20. Shrike
    Shrike New Member
    Mercer Island, WA
    I would really like to see a Prius with AWD or a variant of the 4WD-i system that's used on the Highlander.
    My wife and I currently own a BMW 330i (which is great fun and gets driven mainly on the highway) and a Subaru Outback sedan (which is the jack-of-all-trades AWD car that's great for normal errands, bad weather, and roads too rough for the BMW). We'd like to replace the Outback with a hybrid or diesel vehicle, but the closest vehicle currently on the market is the Escape Hybrid, which doesn't offer enough of a mileage improvement to justify its cost over an Outback of a similar model year. The TDIs are also appealing, except they don't have AWD (unless you step up to the Touareg TDI, which gets worse fuel economy than our Outback).
    Hence, I'm hoping to see an AWD Prius (or a Subaru product with Toyota's hybrid system) introduced in the next few years.
