Summary of proposed improvements for future versions of Prius
Discussion in 'Gen 3 Prius Main Forum' started by CivicQc, Jan 9, 2010.
  1. cycledrum
    cycledrum PSOCSOASP
    8,246
    1,202
    NorCal
    The driver's seat in left hand drive 3rd gen Prius seems to be mounted slightly to the right, laterally from the controls (steering wheel and pedals).
    If they could put the seat and steering wheel / pedals inline laterally in the next generation Prius, that would be great.
  2. CivicQc
    CivicQc The world needs more prius
    233
    99
    Planet Carbon
    Improve the front defrost feature. At low temperature (< -15C), high speed (> 90 km/h) and humid weather, condensation accumulates on the top portion of the wind shield, and blocks the view. Increasing fan speed does help a bit, but cannot solve the problem - there still remains several cm of condensation which is very annoying, especially for tall drivers, as it blocks the view of the road.
  3. Tideland Prius
    16,556
    Hmm, I had something similar but it was -40 so it was ice on the top of the windshield rather than condensed water vapour. That never cleared and ice is harder to see through because it's frosty white rather than your regular fogged up window.
  4. Philosophe
    Philosophe 2010 Prius owner
    437
    72
    Montréal, Québec (Canada)
    +1. This is a serious turn down for me, especially as the 3rd gen Prius was tested in Canadian winter; they should have fixed this.
    The other big issue in winter is the lack of a windshield washer fluid gauge/light. I was stuck yesterday in heavy traffic, near the freezing point, without any fluid left. I had to pull off the road as soon as I could to fill up. This can be a security issue and I simply cannot understand why my $15,000 Echo/Yaris had a empty light while my $30,000 Prius doesn't.
    djasonw likes this.
  5. cycledrum
    cycledrum PSOCSOASP
    8,246
    1,202
    NorCal
    edit - floating bridge console not as obtrusive to front passenger legs as originally thought. I needed to slide seat back a little. Still, we all know the floating bridge should go in next generation.
    Sitting in the front passenger's seat with long legs, it's definitely little tight legspace with the floating bridge console.
    There's actually more legspace side to side on the driver's side for me.
    So, definitely open up the space in front of center console for 4th gen liftback Prius.
  6. Voltan
    Voltan Junior Member
    47
    Niskayuna NY
    Visibility to the rear, but most particularly the right rear quarter, must be improved.
  7. Tideland Prius
    16,556
    +1. The Low Washer Fluid light is one thing I missed and I have ran out before (Thankfully it was before I headed out on the highway to the airport so I had a chance to top it up). In the spring, we will go through lots of washer fluid.
    Also, I thought the washer fluid is good to -40°C? Cause I've had it freeze on the windshield to the point where I'd rather not wipe at all. Do the dealers water it down before adding the solution to the tank?
  8. 2k1Toaster
    6,035
    3,855
    Rocky Mountains
    I've never had an issue with the defrost not working. In fact, it works so well that once defrosted I can turn it off, wait for it to re-fog and then defrost the entire windscreen and front door windows in less than 10 seconds.
    (Canadian who knows cold and lives sometimes in the Rocky Mountains at 10000ft elevation and sometimes great lakes Ontario)
    That would be nice to have. Although it is recommended maintenance to pop the hood when you fill up with gas and do a visual check of your oil, windshield washer fluid, and other visible reservoirs. Also a good time to walk around the car and look for any damage and check the inflation of the tires by eyeballing how much they deform under load.
    I had a 1989 BMW that had an LCD in the dash that displayed the idiot lights. It had a low windshield washer fluid icon, except it was permanently turned on for some reason. So as you drove, no matter how you drove, you got this 8 frame image of windshield washer fluid being sprayed onto a windshield then it would go blank, then repeat the image forever...
    There are varying grades of washer fluid and varying additives. In the summer (which lasts about 2 months) I run the neon green coloured stuff that is only good to above 0C but has antibacterial additives as well as cleaning additives so that it gets bug guts off really easily. In the winter (the other 10 months) I run the deep blue stuff which is good down to -45C according to the bottle but I find that Toyota's pumps stop working around -35C until the engine compartment warms up a little. The blue stuff does not freeze as easily and has a de-icer built in so if you just have that haze of ice in the mornings or after being parked outside, you can just spray it on and it melts the ice.
    If you use the green stuff in the winter, it just smears and freezes instantly.
    I think it would be too general to say all dealers do or don't water it down. However it is much easier to just fill it with water or the much cheaper green liquid than the deep freeze liquid.
    You always need the best tool for the job, and bringing summer formula to below freezing temps is a recipe for disaster in any vehicle (except the newer luxury cars with the steamed spray, but then you are stuck with the possibility of it freezing over before being wiped off if cold enough).
  9. jerrydelrey
    jerrydelrey Member
    111
    22
    Honolulu Hawaii
    Knobs/sliders vs buttons.
    I believe knobs and sliders should be used to adjust things.
    And switches to turn things on and off, or select modes.
    So, I suggest to make the temperature, and fan speed into Knobs or Sliders. Buttons do not make sense to me when you adjust how high or low something is, you have to look down. Knobs you know where it's at, by it's position.
    I think Prius went upscale to Lexus style controls, but in this case, I think Knobs are better.
  10. Tideland Prius
    16,556
    Be careful what you wish for as knobs don't necessarily point to a spot on a dial. With automatic climate control and a digital display, the temperature knob is a freely rotating knob.
  11. bisco
    51,932
    i like knobs. but with positive stops. never use climate control.:)
  12. jerrydelrey
    jerrydelrey Member
    111
    22
    Honolulu Hawaii
    Yeah, my civic is free rotating. But i never had to look down to get my hand in the right spot. With the big knobs on the civic, i can get to the control i want right away.
    With the prius, i know where the button is, but i have to fumble and feel around to get to the fan adjustment. A toggle, or knob would be better.
    Look at the corrolla and yaris controls. I suggest knobs like those.
    The prius's is nice looking, but harder to adjust:
  13. Tideland Prius
    16,556
    Yeah but those are manual climate controls. The Corolla's automatic climate control (we have it in Canada) is a push button affair as well.
  14. cwerdna
    cwerdna Senior Member
    12,544
    2,124
    SF Bay Area, CA
    On my former 350Z, there was no display at all for the HVAC system but the temperature and fan speed knobs had positive stops. Its HVAC system did have an auto setting.
  15. yeldogt
    yeldogt Active Member
    810
    313
    NE
    I have not owned a car without climate control in almost 30 years -- I rarely change the settings ..... 72 in winter and 70 in summer. In the few days I have had the P I have had to change it many times .... So at least mine does not work as well as they normally do.
    Also, I prefer ACC units that automatically turn on the AC -- Toyota I guess did this for MPG -- You need the AC "on" in the winter to eliminate the fog. Like the "auto" and "econ" better.
    Thanks for the info on no washer fluid level -- should have that!
  16. Tideland Prius
    16,556
    Yeah but I don't think Toyota does (maybe in their SUVs like the 4Runner).
  17. Xjaddiction
    Xjaddiction New Member
    43
    TN
    I haven't read all the replies here, but there are some good ones. Please forgive me if I repeat something that's been mentioned.
    Performance and MPG can be improved with a diesel hybrid version of the Prius. Diesel is expensive, but I think Toyota could near the MPG of their plug in with diesel, especially a turbo diesel. That would remove the extra cost of "plugging in", as well as the inconvenience. At the very least, an option for a turbo on the petrol Prius will answer any need for increased performance. As long as you keep your foot out of it, you would see similar MPG's as the current Prius does. If you want to scoot, well power would be there. The Gen III Prius is not slow, and the looks have improved IMOP. This car is seeing a aftermarket boom, and with the addition of performance,,, well this car will change the Hybrid scene forever. Now that Toyota is racing the Prius, I'm sure we will see a boost... pun intended... in performance.
    Keep up the great work Toyota. I love the Prius Gen III 2 I currently own!
  18. cycledrum
    cycledrum PSOCSOASP
    8,246
    1,202
    NorCal
    We've heard this before and hopefully it's highlighted on the list ....
    Pad the door and center armrests!!! Not that my elbows are aching but good grief, it's only a thin layer of fabric over hard plastic. Come on now.
  19. Tideland Prius
    16,556
    They've improved it on the Gen 3 (though I can't speak for the cloth upholstered models). On the Gen 2, the door armrest is extremely thinly padded (ours is worn to the backing). It's also one reason why I went with leather on the Gen 3 after seeing how quickly the armrest and centre console lid wore out.
  20. CivicQc
    233
    99
    Planet Carbon
    In the instruction manual of the PlugIn Prius, we can read that the charging operation can be used with a "timer" function to ensure battery is fully charged just before using the vehicle, therefore minimizing battery deterioration. (Having the battery fully charged for prolonged periods of time is not recommended). Apparently, to save time, the last programmed "charging start/stop time" is retained, so one does not have to re-set it every evening when plugging the car, he just have to push on the charging timer switch and the previously programmed time will be used.
    My suggestion would be provide 2 such programmed timer values, for those who will have access to charging facilities at their office in addition to home.
