Summary of proposed improvements for future versions of Prius
Discussion in 'Gen 3 Prius Main Forum' started by CivicQc, Jan 9, 2010.
  1. bwilson4web
    16,212
    By 2017, the cooled exhaust tap was put AFTER the catalytic converter cleaned up the gas. The 2010 tapped the exhaust before the catalytic converter which led to the subsequent problems.
  2. Mendel Leisk
    41,442
    Presume you mean third gen: fourth gen EGR access is reportedly even worse, but it's also proven more-or-less immune to carbon build up. In other words, the fixed it...
    Still, with 3rd gen first Toyota would need to first acknowledge it's a "maintenance item". In the EGR Warranty Extension document I got (May 2017 SOSH-W11=1A), they say, Italicized and underlined thus:
    While the majority of vehicles will not experience this condition
    chuckiechan likes this.
  3. chuckiechan
    chuckiechan Member
    172
    53
    Roseville
    2020 Prius
  4. chuckiechan
    chuckiechan Member
    172
    53
    Roseville
    2020 Prius
    Someone in this thread mentioned plastics being used somehow in preventing head gasket failure.
    Or am I "mis-remembering"?
    I would like to know more...
  5. Mendel Leisk
    41,442
    Maybe @rjparker, regarding plastic sleeves in the blocks coolant passages, with intention of keeping coolant temps more uniform.
  6. bwilson4web
    16,212
    I think the YouTube channel "Project Farm" used JB Weld to repair a cracked cylinder head. But if you used it instead of a head gasket ...
