Summary of proposed improvements for future versions of Prius
Discussion in 'Gen 3 Prius Main Forum' started by CivicQc, Jan 9, 2010.
  1. Srsingsalot
    Srsingsalot Junior Member
    71
    nocal
    Everblades has heated blades for Prius ;)
  2. wintechsw
    wintechsw Junior Member
    36
    Vic Australia
    Wth!!?? Are you so incapicitated that you would rather drive 100 ft than walk this small distance? Perhaps a delivery service would suit your situation better.
  3. Srsingsalot
    71
    nocal
    or... www.electriccartwarehouse.com :p
  4. Roadking2003
    Roadking2003 New Member
    Tennessee
    Exactly. I call my Prius a poor man's Lexus.:D
  5. Roadking2003
    Tennessee
    Move the brake pedal to the left at least one (1) inch. My foot gets caught under the brake pedal at times.
  6. Chaz
    Chaz Junior Member
    27
    New York
    2010 NAV:
    Option to speak "Name of Point of Interest". You have to pull over if you want to find a POI by name. While driving you can only find POI on route or close to here.
    I have 9.0 version of map DVD
  7. odaigle
    odaigle New Member
    35
    Canada -- Montreal
    I have not seen it in the summary, so I am posting it (did not check if somebody else thought about it):
    - Electric heater for the passenger compartment. So, you have immediate heating upon start up, and your engine does not have to idle stupidly to heat-up the inside of the car. Of course, once the engine is warm, the heat comes from the engine and not from the electric heater. I think this will be in the plug-in version of the Prius. It would be cool to have it on the "standard" Prius as well.
  8. odaigle
    odaigle New Member
    35
    Canada -- Montreal
    ... and one other thing:
    - Have the Hybrid System Indicator always visible. It could be just a thin line at the bottom of the display, which would show the HSI line, even if we are looking at the FE/FC histogram. So, we would always know if we are going into the PWR zone, into the "ICE kicks-in" zone, or in the "possibly EV mode" zone.
  9. synq
    synq White, black, red
    Dordrecht, The Netherlands
    I think you mean that it will be 'hot' rather than 'cool' to have it on the standard Prius. :p
  10. CivicQc
    CivicQc The world needs more prius
    233
    99
    Planet Carbon
    Interesting. I believe the purpose of having controls on the steering is to let the driver control the various features of the vehicle without moving his eyes away from the road for too long. Are the 3 buttons used that often whilst driving that would justify having them on the steering? (I don't know - I am asking, as I dont have a Prius).
  11. CivicQc
    233
    99
    Planet Carbon
    Interesting idea - but I believe the current generated by the panel is most likely far too weak for that. In addition, engine heating is mostly required at night (when there is no sun).
    Thanks for your input!
  12. DetPrius
    DetPrius Active Member
    545
    92
    Southeast Michigan
    The Prius already has this! It has electric heating elements that are used under specific conditions. I've smelled the electric heat a couple of times in my Prius. Remember though, that heating this way is not very efficient and will draw down the HV battery rather quickly.
  13. liskipper
    liskipper Member
    374
    79
    Long Island, NY
    Re: Shifter position
    In my twin engine boat (anti-Prius), you push the shift levers forward to go forward and pull them back to go astern.
  14. tlthompson
    tlthompson New Member
    33
    Northeast Ohio
    I'd really like to see some of the features of the V broken out into individual purchase options. Actually, I think it would be great to get most of the features on an a la cart basis. The III came the closest to the feature combination I was looking for, but there are a few things on the V I would have spent a little extra for.
  15. bighouse
    bighouse Active Member
    822
    126
    Guerneville, CA
    Here's what I want:
    1. Built in hot spot device that allows my car access to the internet...so...
    2. Then if I wanted to do a remote AC trick, I could do it via the internet and not from just 10 feet away...and...
    3. I could also have my car send its service record and stats to my dealer for review should I need it to...or...
    4. Surf the web on the Nav interface when the car's parked...and...
    5. Others riding along with laptops or smartphones could have wifi access to the internet through my car's WEP enabled built-in access point...also...
    6. If I didn't like the way my Nav screen looked I could download SKINS to change the interface a bit to my own liking...or..
    7. If I grew weary of Navlady, I could download a new voice avatar for the Nav system and have CylonCenturion, PeeWee Herman or Monique instead...
  16. Tideland Prius
    16,534
    Another great thread by CivicQc!
    Add me to another member that wants a heated steering wheel.
    Also, I think you listed lower rear window wiper twice.
    For those that do want a colour-keyed spoiler, it is available as an accessory in Japan. Naturally, it's not a cheap option but it's available.
  17. Airbalancer
    Airbalancer Active Member
    892
    73
    Cobourg, On, Canada
    The bottom ledge of the body by the door should be narrower, finding the back of my pant leags are getting dirty from rubbing on the location getting out
  18. cycledrum
    cycledrum PSOCSOASP
    8,246
    1,202
    NorCal
    I'm 6'2" tall, long arms and legs.
    I took a quick sit in a 2010 Prius today. After sliding the seat all the way back and cranking it down almost all the way, I thought the steering wheel was pushed mostly into the dash. Well, it wasn't. It was actually pulled all the way out towards me, but IMO, not enough.
    In an edmunds.com video put out last year, Erin Riches, a Sr. Editor mentions "... but unfortunately the (2010 Prius steering) wheel has a very limited range of adjustment, so it's still not perfect"
    The steering wheel should be able to telescope a little more towards the driver, perhaps 1 to 2 inches (2.5cm to 5 cm) more.
    3 people like this.
  19. hampdenwireless
    hampdenwireless Active Member
    1,104
    86
    Baltimore MD
    Backup power system option ($2000 or less cost)
    2000-5000W capacity near sine wave inverter running off of the HV battery. Automatically turns on and off ICE to keep HV battery in best state. Ideally a standard 220V connection like generators have for connection to breaker panel switchover boxes as well as a set of 120V plugs.
    The first (mild) hybrid GM pickups could do this and run for a day on a tank of gas, making far less emissions and noise then a portable generator.
    3 people like this.
  20. Tideland Prius
    16,534
    Or just incorporated into the door like some Lexus models
