Summary of proposed improvements for future versions of Prius
Discussion in 'Gen 3 Prius Main Forum' started by CivicQc, Jan 9, 2010.
  1. DetPrius
    DetPrius Active Member
    545
    92
    Southeast Michigan
    The Detroit manufacturers have traditionally offered options a la carte but they have been moving away from it. The reason is simple: $$$
  2. marcovi
    marcovi Junior Member
    31
    How about a smarter GPS! Fords Navigation from Microsoft blows the Prius Navigation System
  3. 3PriusMike
    3,100
    2,419
    Silicon Valley
    Maybe it is just me...but I would think that a complaint/suggestion like this would carry more weight (no pun intended) if you provided your height.
    3PriusMike
  4. violacgda
    violacgda Junior Member
    17
    New Haven
    1) A beep to remind me if I've left the lights on.
    2) A temperature gauge, not an idiot light.
    3) A lever next to the gas tank opener to allow me to pop the hatch back from inside the car.
    4) No bladder in the gas tank (I was told the 2010 has one, hence on empty I can only put in 9.6 gallons.)
    5) A sunshade for the back-up camera.
  5. violacgda
    17
    New Haven
    In the matter of seat heaters---button placement, and seat heater for cloth seats. I bought a III, but had the dealer install front seat heaters. (I really don't care for leather seats.) The buttons are located on the outer side of the seat. Voila---heated cloth seats, easy to find button!
  6. Tideland Prius
    16,556
    There is no bladder in the 2010. It has a regular gas tank.
    Also, no hatchback or wagon that i know have a internal release next to the gas cover release. Only sedans have a trunk release. All others use an external release (cable or power release) and of course some have power-operated hatches.
    2 people like this.
  7. Airbalancer
    Airbalancer Active Member
    892
    73
    Cobourg, On, Canada
    How much for you heated seats?
    In Ontario they are about $500 for the pair?
    I wonder if you can get heated/cooled seats, would it work fast enough for the wife?:D
  8. cycledrum
    cycledrum PSOCSOASP
    8,246
    1,202
    NorCal
    I'm 6'2" tall with long arms and legs.
  9. violacgda
    17
    New Haven
    Didn't know that about hatchbacks; this is my first.
    I am puzzled about the gas tank. When I asked the dealer why all 3 times I've refilled when the last pip was flashing (and the display says under 10 miles to empty) I've only been able to put in only 9.6 gallons, he said it was a result of the bladder in the tank, and claimed that this model has one. Isn't the tank over 11 gallons? My previous car was a Civic Hybrid. When I got near empty, I could put in close to what the manual specified for tank capacity.
  10. E-GINO
    E-GINO Active Member
    194
    206
    Rome, Italy
    These are some of the improvements I would like to see in the next Prius:
    A) easy to do
    - a better acoustic insulation
    - mirrors folding electrically
    - better quality plastics inside, better quality paint outside
    - a less imprecise speedometer (+ 8% speed indications here in Europe!)
    - a less optimistic trip computer (- 10% fuel consumption indications)
    B) just hopes
    - an invertible ("heat pump") A/C system for the cold season
    - a smaller (e.g. 1,4 L) but turbocharged engine with more torque (>250 Nm) at low regimes (<3500 rpm)
    - Li-Ion traction battery
    - a cheaper price ;)
    Regards
    Igino
  11. KreeH
    KreeH Junior Member
    Santa Clara, CA
    I actually use Power mode when I merge into traffic then switch it
    off once I in the flow. For me, it would be helpful to have this on the
    wheel.
    Another idea would be to copy Honda's approach where you can
    over-ride the CV transmission to "downshift" for extra acceleration.
    Alternately, maybe "B" mode also worked to increase acceleration,
    similar to downshifting a conventional transmission.
    Other wishes:
    1. I wish Toyota could eliminate squeaks and rattles. The car
    is very quite and any noise seems to be amplified, plus, I
    hate squeaks!
    2. I would wish the SKS (?) key sense was included in all options
    for the hatchback or if it was offered as a simple upgrade.
    3. It would be great if you could upgrade your battery to a larger or
    lithium-ion or if there was an option to add a 2nd battery and
    give up cargo space.
    4. It would be great to get a higher EV only max speed.
    5. I also wish the car would include an algorithm which could detect
    conditions where it would put itself into "EV coast" stealth mode
    automatically without driver interaction.
    6. I wish the resolution, contrast, brightness and colors used in the
    GPS and dashboard display were much better. It seems odd that
    portable gaming consoles (phones, cameras, ...) have better screens
    than the Prius.
    I keep hoping upgrades will become available for the 2010 gen III
    and we don't have to wait for the next version.
    Kevin.
  12. violacgda
    17
    New Haven
    I don't remember the exact figure, but I think it was $299 a seat. It warms up very rapidly, but does not have a seat cooler. I'm very glad I have them.
  13. cycledrum
    cycledrum PSOCSOASP
    8,246
    1,202
    NorCal
    Just a little bit more steering wheel telescope action would be nice. It is pretty good as is, but for the wheel to pull some amount closer, perhaps 1 to 2", would be nice.
    2 people like this.
  14. cycledrum
    cycledrum PSOCSOASP
    8,246
    1,202
    NorCal
    Add driver's seat mechanically adjustable lumbar support into the base model Prius' as well (II and III). Or power lumbar adjust if that's light enough and cost effective.
  15. AussieDave
    AussieDave New Member
    Melbourne Australia
    Cruise Control, when holding the lever to step in 5 kph steps give an audible clue at each step so you don't have to take your eyes of the road. Could even put up with the speed setting spoken
    Dump the power lumbar support, I cranked it up to full on Day 1 and have not chsnged it. Rather have power or continuous backrest rake adjustment.
    Better audio system.
    The turn signal clicker is a bit quiet, would like the arrows showing in the HUD as I tend to look at it often but main cluster very seldom.
    Get rid of the fuel economy guage, give me a temp gauge instead.
    Give Aussies LKA (might get the government to improve lane markings on our roads if no other benefit).
    Remote aircon keeps running until car started, not cutting out when door is unlocked.
    Only needs about an extra inch or two of ground clearance to solve that problem with scraping kerbs.
    David
  16. Tideland Prius
    16,556
    Be careful what you wish for Re: CC audible clue lol. Knowing Toyota, it's gonna be a beep and we've already have enough complains about beeps on the Prius.
  17. AussieDave
    Melbourne Australia
    Do not mind beeps when they are telling me something useful.
    eg Moon roof open and I get out and close the door - beep reminds me roof is open good.
    Get out and lock car. Lots of beeping and flashing of lights, eventually get back in to try to figure out what is going on and there on my display I am told key still in car. Duh, my key in pocket wifes key in handbag under the console.
    Beep as I am in drive heading for garage, wife has unbuckled seatbelt. Annoying so I planted my foot and accelerated into the rear wall of the garage to teach her a lesson. Result lots more beeping.
    (just kidding on the last one)
  18. Tideland Prius
    16,556
    hahaha. I'm surprised it doesn't say "MOONROOF OPEN" on the MID. Most Toyotas with an MID will say that.
  19. cycledrum
    cycledrum PSOCSOASP
    8,246
    1,202
    NorCal
    Make rearview mirror double jointed stalk longer and mount it higher to adjust mirror above driver's field of view.
  20. Tideland Prius
    16,556
    oddly enough, the mirror is shorter (the arm) on the 2010. I can't turn it upside down like I can in the 2005. (It could also be b/c of the cover that covers the wire vs. the exposed wires in the 2005)
