Sunvisor metallic clip (celiling)
Discussion in 'Gen 3 Prius Accessories and Modifications' started by Tomas Greene, Mar 8, 2021.
Tags:
  1. Tomas Greene
    Tomas Greene New Member
    Santiago
    hi there, any clue where to purchase the metallic clips for the sunvisor that insert into the ceiling?
    kind regards from Santiago, Chile
  2. Team_Geek
    Team_Geek Member
    62
    32
    MN
    I needed one of these but couldn’t find any. Ended up with a GM trim panel clip from the local auto parts store. It was very close in size but not perfect. I took a couple minutes with a file to make it a little narrower and used a needle nose pliers to spread the ends out. It’s been holding up great so far.
    Part was from Dorman part number 963-211D.
  3. ASRDogman
    ASRDogman Senior Member
    8,067
    4,089
    Have you tried Toyota?
  4. Team_Geek
    Team_Geek Member
    62
    32
    MN
