Super cheap mods are sometimes the best
Discussion in 'Gen 2 Prius Accessories & Modifications' started by iron-icman, Jun 23, 2017.
  1. 69shovlhed
    69shovlhed Surly tree hugger
    2,170
    751
    Delaware
    you need to find oem fog lights; the aftermarket ones don't fix well.
  2. The Electric Me
    The Electric Me Go Speed Go!
    9,083
    5,801
    Undisclosed Location
    Sorry it's so common I did not think a picture was necessary.
    There's a little variance from store to store, but basically I'm just talking about the "console" plastic cup holders. Usually 2, adjustable, mine has some Storage space behind it.
    I just keep it in the passenger seat when I have no passengers, throw it in the back seat when I do.
    Even though my Fit...like the Prius, does come with some cup holders, I actually like the console better. Then I can use the built in cup holders for other things.
  3. Justdidit
    Justdidit LVNPZEV
    1,880
    710
    75
    Carrollton, Texas
    Four Touring
    Super bright, I'd say so. Cut off was awesome.
    What do you mean, easy to fix?
    Don't buy aftermarket fogs as they don't have the bulb shield.
    http://m.ebay.com/itm/2004-09-Toyota-Prius-Highlander-Echo-Fog-Light-Bumper-Lamp-Kit-Chrome-TY014-C-/351835462977?fits=Model%3APrius&hash=item51eb071d41%3Ag%3APMYAAOSwd0BV5fQY&_trkparms=pageci%253A0bddceed-5a3d-11e7-8083-74dbd1804d6e%257Cparentrq%253Ae33300f915c0a9c0b1cae473fffcdc92%257Ciid%253A3
    Get OEM part #81221-52070 much better quality.
    download_20160112_144536.jpeg 20130129_220204.jpg 2017-06-26%2002.03.13.png 2017-06-26%2002.07.33.png
    SM-G870W ?
    Kevin_Denver and m.wynn like this.
  4. iron-icman
    iron-icman Member
    130
    43
    Leeds UK
    ----UK----
    Are these just a easy swap for old ones not very good with electrics etc
  5. Justdidit
    Justdidit LVNPZEV
    1,880
    710
    75
    Carrollton, Texas
    Four Touring
    Either OEM or aftermarket snap into the bumper with a little bit of effort. Obviously much easier if you take the bumper off, but people have done it without. Probably a thread here on PC if you search that walks you through the steps.
    iron-icman likes this.
  6. Kevin_Denver
    Kevin_Denver Active Member
    581
    425
    Denver, CO
    I installed the cheap ebay Winjet's in my car (was cheaper than buying replacement covers haha). Directions are here: 06-09 prius winjet foglight install | PriusChat. You just access the back of the left and right side of the grills by removing two 10mm bolts on each side under the bumper and folding a very a thin plastic panel out of the way. Can remove more panels down there for easier access.
    iron-icman and Justdidit like this.
  7. iron-icman
    iron-icman Member
    130
    43
    Leeds UK
    ----UK----
    And are these easyy to wire in then just plug and play
  8. ChuckDavis666
    ChuckDavis666 Junior Member
    Durham, NC
    Any particular cellphone holder you used/recommend? How did you route/fasten down the cable to the aux port?
  9. Kevin_Denver
    581
    425
    Denver, CO
    I have this guy: Amazon Linky
    Who is mounted to the top of a flat GPS pad for a Garmin. It would be easy enough to mount to the windshield though. I would also say - there's probably a lot better solutions out there; this just works well enough for me.
    I have an aftermarket CD player, so I ran the wire through the dashboard down to the CD player. If you don't have an aftermarket and are going to the stock connector in the center console, I would buy a 10 ft+ cable and run it from the top of the dash to the left driver's footwell, in the cable tray that's under the left door, and then pop out and go under the driver's seat into the center console. Look up on youtube how to replace the CD player in a 2nd gen Prius, and you'll see how to take apart the dash. It's pretty easy actually.
