Super cold (around 15 degrees) start this morning, engine started very rough
Discussion in 'Gen 3 Prius Technical Discussion' started by nivekonbass, Nov 19, 2022.
  1. nivekonbass
    nivekonbass Member
    91
    49
    illinois
    2013 Prius w/ 95k.
    So the title says it all, it started real rough. I turned it off immediately, ran rough again for a second and then was completely fine. Based on what I'm seeing online, this looks like I may need to clean or replace my EGR? I'm a little nervous to tackle that job because of that one bolt that's hard to reach and some of the videos they used to work on the shit they either had a lift or had tools w/ o links to them lol
    Also, this is more important. It's freakin 20 degrees outside. I do Uber and stuff like that and I absolutely need to work a lot this winter (guessing i will be putting around ~10k miles on my car in the next 4-5 months) Will I be fine for the winter? I'm really really not trying to be doing a 3 hour job in this kind of weather. I certainly can not afford to pay someone to do this. What are my options here?
    Any mechanics near chicago want to help a brother out? i will be eternally grateful and love you forever :p. it aint much but thats all i got rn
  2. Mendel Leisk
    42,271
    With the 3rd gen, EGR and intake manifold is like death an' taxes; just do it. First couple of links in my signature have some info and links.
    I dropped in on a local Priuschatter when he was doing his, in a driveway, sunny but around freezing point. I concur, not a fun time of the year to take this on. Do you have a garage, or can you get time in one?
    Some cold weather strategies:
    1. Remove the very-hard-to-access lower hold-down nut on the EGR cooler in advance, and leave it off (forever). Take off the stud too if ambitious: the latter requires an E8 socket. And you want to go slow, it may be stubborn, due to dissimilar metals.
    2. Remove the top/front nut and stud at the EGR valve. Apply a thin coat of antiseize on the stud, then reinstall.
    3. Check out the aforementioned links in my signature, get together all the stuff you'll need.
    4. If you have to, break the job up into two sessions: the EGR components one time, the intake manifold another time.
    I think you'll find it takes more than 3 hours. Myself, I think in all it dragged out over 3 days, due to learning curve, struggling to find an effective cleaner for the cooler, fighting with the lower cooler nut, and on and on.
    #2 Mendel Leisk, Nov 19, 2022
    m.wynn likes this.
  3. nivekonbass
    nivekonbass Member
    91
    49
    illinois
    Lets go with no, to that question. I live with family and it's just full of stuff that they like to hoard so literally our garage is not for cars anymore........................................................
    Do you think I will be fine until March? No CI light or anything, car ran totally fine after
    #3 nivekonbass, Nov 19, 2022
  4. Mendel Leisk
    42,271
    More than likely, just judging from the odo miles.
    I hear you about the garage: ours used to be two-car, but now the side typically unoccupied by a car has been filled with the "procrastination pile"....
    Don't waste time dumping cans of brake cleaner through the EGR cooler. Going the Oxi-Clean route, you can bring it inside, let it bubble out the carbon in laundry sink. (see links in my signature)
    Also, read the tips (in sig links) about coolant tactics; clamping hoses is ineffective and a mess. There's a few tricks that can avoid any spill, speed things up.
    #4 Mendel Leisk, Nov 19, 2022
  5. Tombukt2
    Tombukt2 Senior Member
    13,809
    2,504
    Durham NC
    Just go to LKQ or Chicago Auto parts and buy the cooler the intake manifold and I think that's all you need send that to the machine shop and have it tanked and cleaned when it's handed back to you that stuff will be whistle clean you'll be able to see daylight through all the parts and passages and ports throw that over in the corner until things get worse than they are now and it makes you more nervous then you just swap out the cooler and the intake manifold even in 20° weather it won't take you that long and you leave off that bolt that the nut that you're worried about and you're good to go for a long time generally speaking just buy the parts have them clean you'll get them cheap LKQ will almost give them to you and then the set you take off you get them cleaned put them up and if the car really makes it with you like mine and you're taking it to 600,000 you'll probably be doing it again. In the second time it will go quick as all get out
  6. ForestBeekeeper
    ForestBeekeeper Active Member
    780
    310
    Maine
    I had a talk with my mechanic. He saw his first blown head gasket, and since I own two Prius' he thought it was something I should be aware of. I told him that I am a member on PriusChat and I had seen hundreds of blown head gaskets [nationwide], and that it is loosely connected with a clogged EGR. he said that if the EGR clogs it 'should' trip a diagnostic code. I asked if it would be a good idea to pull and inspect the EGR once a year as a preventative. After checking the labor fees for pulling an EGR, he suggested instead to use 'SeaFoam' in the vacuum intake, that it should flush the EGR.
    I take each of my Prius' in every six months for an oil change and tire rotation. [We run summer tires in summer, and studded winter tires in winter] So for my next maintenance we have scheduled a SeaFoam flush.
  7. PriusCamper
    PriusCamper Senior Member
    13,407
    5,413
    Pacific Northwest, USA
    Rough starts with Atkinson engines, especially in cold weather is common. It doesn't happen consistently and if it does you have something more than normal to address, but please don't waste your time if nothing is wrong. And yes an EGR cleaning and tune up is wise, but keep it in perspective.
  8. ForestBeekeeper
    780
    310
    Maine
    We normally anticipate -20F temps in January and February. Our Prius' are not intimidated by cool weather.
    15F is T-shirt, shorts and flip-flop weather. :)
  9. Mendel Leisk
    42,271
    I doubt that'd do anything.
    Just clean everything every 50K miles.
    If it's down to say absolute zero, you say "It's nippy today, where'd my coat get to?".
  10. bisco
    52,784
    mid week looks great, start tuesday, finish thursday
  11. CR94
    CR94 Senior Member
    2,819
    1,238
    Northwestern S.C.
    Nobody can predict whether it will make it through the winter without major trouble, especially not without more information. 95 k is a bit early for bad EGR clogging, but not unknown. These cars have a history of occasional rough starts even when there's no clear cause.
    I suggest you clean out the EGR passages of the intake manifold (much easier than unclogging the EGR cooler, and likely more critical) and use the OBD2 port to ask the car whether the EGR path is badly clogged overall.
    #11 CR94, Nov 19, 2022
  12. CR94
    CR94 Senior Member
    2,819
    1,238
    Northwestern S.C.
    That makes zero sense.
  13. Grit
    Grit Senior Member
    6,577
    4,231
    Wilkes Land
    Bill norton said back while ago he did an Italian tune up and it took care of clearing the egr.
  14. Grit
    Grit Senior Member
    6,577
    4,231
    Wilkes Land
    Since knocking isn’t an on going issue and coolant level wasn’t mentioned, it’s just moisture in the combustible engine that formed over night and it’s just getting knocked around and sucked out to the egr.
  15. nivekonbass
    nivekonbass Member
    91
    49
    illinois
    Ok so there's a lot of different opinions here and I promise I am not trying to be combative when I say what i'm about to say.
    I just want to make sure I'm understanding correctly. The hype around these cars is that they are "very low maintenance and extremely reliable and they can easily go 250k miles with LITTLE maintenance ". 100k is just barely broken in." This is the stuff you hear about these cars, in that tone.
    But at the same time, you guys are telling me there is a $800-2000 dollar repair every 50k miles or 100k miles on the high end, unclear exactly. And if I want to do it myself it can span out to 3 days of work with a learning curve (which will likely exist since I've never done this on this car)?
    Meanwhile, I'm sure there's plenty of uninformed Prius owners who don't maintain their cars well at all and have never done this. I refuse to believe these taxi companies that have a fleet of Prius' dish out money like that to do this repair every 100k miles and I know damn well they don't do it themselves lol.
    Are we catastrophizing this whole scenario or are you guys being for real?? Like do I really need to do this on Wednesday? Is it likely that a vehicle with 95k miles, that has had oil changes every 4200 miles at Toyota (Never, ever late. Previous owner did it every 2k miles; was a lightly driven govt vehicle, way over maintained, it's why I bought it) would have this problem this early? I have my coolant checked/topped off every time I do an oil change + it was replaced like 15-20k miles ago. It was 15F outside and very very windy when I posted this.
    About 8 hours after this post, I started my car again and it started up just fine and I drove it 100 miles w/ no issues @ all. Including when I'd turn it off/back on. Avg'd 53.5 MPG today which is lower than normal but it's to be expected w/ the temps we're talking about. (On warm days 56-59). No hesitation, nothing like that.
    Please forgive me for questioning everything, I really appreciate all of the help.
    #15 nivekonbass, Nov 20, 2022
  16. CR94
    CR94 Senior Member
    2,819
    1,238
    Northwestern S.C.
    [Duplicate post; see #18 below.]
    #16 CR94, Nov 20, 2022
  17. Grit
    Grit Senior Member
    6,577
    4,231
    Wilkes Land
    A one time start up cold soak knock can sure create an avalanche of posts :ROFLMAO:
    Doug McC likes this.
  18. CR94
    CR94 Senior Member
    2,819
    1,238
    Northwestern S.C.
    The truth is likely between those extremes. The "hype" of your first paragraph started with the previous (2004-2009) generation, which didn't have as many head gasket and EGR issues. Certain members do have a slight tendency to "catastrophizing." Your car might go another 94k with no serious problems---or might not. Your odds will be better if within the next several thousand miles, you clean out the EGR passages of the manifold (under half a day, including generous learning curve, if you're modestly mechanically inclined) and check overall restriction of the EGR system (5 minutes with a scan tool or other OBD device).
    At over 136k, my car has had none of the hyperexpensive problems, although clear coat is pealing off its roof already. I haven't bothered tackling the dreaded EGR cooler yet, because the EGR restriction number still looks good.
    #18 CR94, Nov 20, 2022
    Montgomery and Doug McC like this.
  19. Grit
    Grit Senior Member
    6,577
    4,231
    Wilkes Land
    I wouldn’t buy this car again if cost fuel efficiency price of gas and maintenance values were constant when I first bought mine. In fact my next car won’t be a Toyota, that’s how untrustworthy this vehicle is.
  20. nivekonbass
    nivekonbass Member
    91
    49
    illinois
    At the moment I only have one of those cheap amazon BAFX $20 bluetooth scan tools. Will that do? Will this show up in the live data streams or what am i looking for specifically?
    In the past when I had dealt with an EGR code on my old buick, i just threw the part at it. it was like 4 bolts and done lol, so i never really looked for data on this end.
    As for the intake manifold cleaning i'll do that probably after the holidays, cause these are my busy months and I want to work my balls off right now
    #20 nivekonbass, Nov 20, 2022
    CR94 likes this.
