Super noisy blower fan 2017 prius V
Discussion in 'Prius v Care, Maintenance and Troubleshooting' started by Kpeeling, Jan 2, 2025.
  1. Kpeeling
    Kpeeling Junior Member
    30
    South Central PA
    2017 Prius v wagon
    It suddenly sounds like a roar and bits of stuff flying around or something broken. I need to get to it to see what is going on. Does anyone have a good video of how to access the fan?
    Thanks
  2. rjparker
    rjparker Tu Humilde Sirviente
    11,054
    6,926
    Texas Hill Country
    Open up the glove compartment and pull out the cabin filter (see manual). You will find the problem most likely is a nest.
    Kpeeling likes this.
  3. Mendel Leisk
    42,307
    Aka rodent nest.
    fix is to remove the $@#?! wipers and cowl, and cover cabin air intake opening securely, with anti-rodent mesh (1/4” mesh spacing, galvanized steel mesh, readily available at hardware stores etcetera).
  4. Kpeeling
    30
    South Central PA
    2017 Prius v wagon
    Thanks for the replies. I will do this as soon as I can. I have suspected a rodent nest from the first thing I heard. It doesn't appear like it will be too difficult to get to it.
  5. Mendel Leisk
    42,307
    Just empty out glove box first (so it’s easier to handle. I’m only familiar with Gen 3 hatchback but assuming it’s sim: you need to flex the glove box end walls inward, to get them by stops. There’s also a pneumatic piston on one end wall you unhook. Then lift the glove box a bit and it comes out of its hinge points and off.
